Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Light not working!
Replaced light Bulb now it make a rapaid clicking noise like it has a balast? Thank You
Ron
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
You sure is not the door switch making noise when open
Posted on Mar 31, 2009
My right side headlight not working on A4, 2007. Install new H7 bulb from Audi but it did not work. I install the right bulb into the drivers side and it work. I suspect an electrical problem. Possible no...
if it is a hid light system they are famous for the balast going bad. follow the wires from light bulb. if they go into a box then its a hid system and it is the balast box that needs to be replaced. also check the fuses, sometimes there are seperate fuses for each headlight.
Mar 09, 2013 | Cars & Trucks
I had the balast taken out of the Toshiba TV # 62HM15A. Reason being, there was no picture -- just black screen, after power on, green light appears then green light blinks then it makes cliclk and clack...
Hi, the word ballast is rather a misnomer in flat screen tv's, reason being flat screens have what are called cold cathode fluorescent lights in them, and there are usually more than one-it has been my experience that the power supplies that drive " ballast's " are what can go soft-and sometimes the power supply has the ballast right on the same board, you can try reducing the brightness to keep set from resetting-that'll tell you if power supply if " soft " on not. also-i have used a different piece of equipments " ballast " to power another-i once used a H.P. pocket pc to power flat screens bulb temporarily for just the same reason, to determine if bulb or ballast was in err. New " ballasts by the way run around 150 if i'm not mistaken they aren't cheap unfortunately. Hope this helps, PRODZILLA
Mar 31, 2011 | Televison & Video
Tv comes on for a minute and then I get the bulb failure light. If I unplug it and power it back on I get the same result, so it is not the bulb because it still works. What is causing this?
The would be the balast that holds the bulb that has give way, this would need to be replaced as its setting of a signal to shut your tv down.
I hope this helps
Aug 04, 2009 | Philips 50PL9126D/37B 50" DLP TV
2002 acura 3.2tl-s passenger headlight not working.replaced light
make sure that the bulb you are using is a 9005 ive seen people instal the wrong bulb and it doesnt work. Same plug different filaments. If thats not the problem maybe a headlight switch acting up. Hope this helps! ~Derek~
Jun 20, 2009 | 2002 Acura 3.2TL
NEW BULB INSTALLED FOR PANASONIC PT-50LC13 TV STILL NO LIGHT
close lamp door set will not work with door open. if not that listen for arcing sound in back if  don't hear that bad ballest
Jun 09, 2009 | Panasonic PT-50LC13 50" Rear Projection...
4-bulb flourescent fixtures flickers before coming on completely
The problem may be related to the balast unit in your light fixture. Check under the cover plate in the middle of the fixture and look for a rectangular (usually black) box. If it has any brown liquid leaking from it then it definately needs to be replaced. Read the label on the box and record the values. Take your stats to the local electrical shop and buy a replacement balast. Installation will require the breaker to be shut off to the circuit. Be absolutely sure you match the wires before attaching them together. Disposal of the old balast must be done through your local recycling center. The material in some of these is quite dangerous.
I would problably suggest contacting an electrician if you are at all uncomfortable with handling a re-wiring job. Good luck with your situation.
OpenSource13
Apr 11, 2009 | Lowel Light Lowel Flou-Tec 450 Fluorescent...
Hitachi tv projection
Need alittle more info . What is the model # . And does any of the lights on front come on or do you hear a click?
Feb 28, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Light Engine?
try removing the lamp and inspecting it if it's not shattered inside ,chances are it's ok and you might have another problem ,possible balast fault,that drives the lamp assy. look for fan operation also.
Sep 07, 2007 | LG 52SX4D 52" HDTV
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
80 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
