I have Dell 5210n printer and get 920.26 Service Fuser Error, please advise me how to clear it.
2 Suggested Answers
  • 13 Answers
SOURCE: Our Dell 5210N printer gives the error: 929.00 ser...
A 929 Service Toner Sensor error indicates a problem with the toner sensor, the front harness cable, or the developer drive. It could also mean that the toner cartridge is defective.
  • The most likely cause of this error is the toner cartridge itself. This is especially true if it is a new cartridge and the error started after you installed it.
    1. Take the cartridge out of the printer and locate the encoder wheel on the right-hand side of the cartridge. The encoder wheel can be found on the right side of the cartridge (usually over a bar code sticker). It is a thin, black, plastic wheel with small rectangular notches cut into it. This wheel will sometimes get stuck, but you can free it by turning it by hand.
    2. Try moving the wheel forwards and backwards a little. If it does not turn correctly, you will receive a 929 Toner Sensor error on the printer when you try to use the cartridge it is attached to. Note: The encoder wheel moves only a little bit each way. It should not make a complete revolution. If it does, the wheel is probably broken.
    3. Try to move it a little bit each way a couple of times to see if you can free it up. Caution! DO NOT force the wheel as you could break it.
    4. If the wheel on the toner cartridge is stuck, try another new toner cartridge. ( If you do not have another new toner cartridge available, an old toner cartridge or another cartridge from a working printer of the same model will also suffice for this test.) Power the printer off and install the second toner cartridge. Then power the printer back on. If another toner cartridge clears up the 929 error, the printer is fine and the problem is with the toner cartridge. If the error does not clear, there may be a problem with the printer.
    5. If you narrow down the problem to the toner cartridge, call the point of purchase and explain the situation to them. They may have a replacement policy. If they cannot help you, call our Technical Support Center and we will see what we can do to replace the cartridge that is causing the error. We will not be able to reimburse the price of the cartridge, but we can offer you an exchange. To do this, we may ask you to send in your cartridge first. Please note that we cannot offer an exchange on a refilled or refurbished cartridge. For this, you must go through the point of purchase.
      Click here to order toner cartridges and other supplies for your printer.
  • If you receive this error with a second toner cartridge, you may want to check if the Front Harness Cable is plugged into the Toner Sensor. Do the following:
    1. Turn off the printer and remove the toner cartridge.
    2. Look inside the printer at the place where the cartridge goes (on the right). You should see the Toner Sensor. On the back of the sensor assembly, you should be able to see a white cable connector.
    3. Push this white cable connector into the toner sensor assembly by pushing the connector towards the front of the printer.
  • If you continue to receive the 929 error, your printer will probably need service.
Source: Lexmark KnowledgeBase
Posted on Jun 22, 2010
Close door or replace cartridge message won't go away
Replace the imaging drum and reset the life counter on Dell ...
www.dell.com/support/article/us/en/19/SLN142828/EN
DellOct 31, 2014 - Obtain replacement part; Fit replacement part; Reset life counter ...counter on Dell 1700, 1710, 1720, 2230, 2330, 2350, 3330 and 3335 laser printers. ...toner low and error lights, 23xx and 33xx will display the message Replace PC Kit. ...Fit the assembled toner and drum to the printer, close the front door.Missing: 5210n ‎persistent
34 Short Paper Error on Dell 5210n, 5310n Printers ' Dell US
www.dell.com/support/article/us/en/19/SLN133464
DellMay 10, 2013 - If the pegs do not change position, the gray paper size guide may have become separated ... On the left side of the inside of the printer, under where thecartridge goes, there are two white ... Close the upper and lower doors.Missing: laser ‎message ‎persistent
Dell Printer -- Feeder Problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/29793
Aug 28, 2008 - I am having trouble with my Dell 1700 laser printer. ..... the printer jams in the middle, I get the message, but opening and closing the front door will allow the..... I replaced the cartridge just in case,(the tape had been removed!) ...
Jan 08, 2016 | Dell 5210n Laser Printer
How to fix a Dell 5210N 900 RIP Error?
Replace printhead. If Dell can't be found or is cost prohibitive, use a refurb/reconditioned Lexmark T640 series printhead.
Aug 26, 2014 | Dell 5210n Laser Printer
My Dell 5210n printer has a very loud squeak in the back. How do open the printer to lubricate the bearings?
Usually you don't lubricate. It is probably the fuser assembly wearing. How is the print quality? Have you ran a test page, ran a supply status page? Checked the error log?
Jan 17, 2013 | Dell 5210n Laser Printer
What does the 922.02 service fuser error mean? Will not print,
It means the fuser (roller than heats the toner to the page) has a problem, most like needs to be removed and cleaned or replace.
Jan 17, 2011 | Dell 5210n Laser Printer
5210n fuser error code
The fuser unit needs to be replaced. This is most likely due to the fuser heating element no longer heating the fuser adequately.
Jan 03, 2011 | Dell 5210n Laser Printer
Donde encuentro manuales de esta impresora DELL 5319n
Workgroup Laser Printers Contents: Dell Laser Printer 5210n/5310n Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Dell Support ...Dell 3115cn Color Laser Multifunction Printer - Dell 3130cn Color Laser Printer - Dell 5210n Mono Laser Printer - Dell 5310n Mono Laser Printer - Dell 5330dn Mono Laser Printer - Dell 7330dn Mono Laser Printer...
Documentation ...Printer 5110cn Dell Laser Printer 5210n / 5310n Dell 5350dn Laser Printer Dell 7130cdn...
Documentation Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Support Information Matrix for Dell Management Console Version 1.1 ...Color Laser Printer 5110cn Laser Printer 5210n/5310n Laser Printer S2500 (n) Workgroup Color... 5330dn Dell 7330dn Dell 2145cn ...
Systems Management Supported Information: Dell Management Console Version 1.0 User's Guide ... Dell PowerVault ...Dell PowerConnect ...Dell'EMC ...Laser Printer 1815n ...Laser Printer 5210n/5310n Yes ...
Dec 13, 2010 | Dell 5310n Laser Printer
Our Dell 5210N printer gives the error: 929.00 service toner sensor. What should we do
May 20, 2010 | Dell 5210n Laser Printer
Canon printer IR2016J show error code E007. Please advised me on how to resolve it or rese it. Thanks
i have a canon copier IR2016J shows me error code E007 please advise me on how to resolve it or rese it. thanks
Jul 01, 2008 | Office Equipment & Supplies
jasbo
jasbo
