Question about Hotpoint Washing Machines
My hotpoint aquarius wmf940 is flashing f11 and not rinsing or spinning or draining out water
Hotpoint aquarius wmf940 washing machine flashing f11 can i solve this problem myself??
  • 209 Answers
SOURCE: HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Posted on Sep 27, 2007
  • 619 Answers
SOURCE: Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Posted on Jan 05, 2008
beltronic205
  • 1461 Answers
SOURCE: Hotpoint Aquarius WF560, goes through cycle wash
Could need new motor brush kit>
Posted on Oct 06, 2009
barkencoa
  • 3463 Answers
SOURCE: the water wont drain from my machine from the wash
What you need to do is check the pump is getting a feed to it
Select a spin cycle, and with a test meter, test for voltage across the pump terminals, if you are getting a feed, and the pump is working ok, then you obviously have a blockage beyond the pump.
If no voltage then could be a broken wire, or a faulty programmer/board.
ONLY CHECK FOR VOLTAGE IF YOU ARE COMPETENT TO DO SO, as it takes no prisoners.
Hope this helps.
Posted on Dec 07, 2009
SOURCE: I have a Hotpoint Aquarius WML540 washing machine
I have a Hotpoint Aquarius WML540 washing machine and after the wash and the rinses, all the lights start flashing and the programme will not go any further.
I would like to know what is causing this and how to solve it.
Posted on Feb 18, 2010
Hotpoint Electronic 800 WM 12 Aquarius won't rinse
If it won't rinse because it won't fill, it's most probably because the cold water inlet valve is faulty. Many machines will only rinse with cold water....No cold water.....No rinse!! Not a big job.....Nomess
Apr 13, 2010 | Washing Machines
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Kenmore quietpak2 no longer rinse, drain, spin
Sounds like the pump, eighter blocked or needs new pump.Place outlet hose in to bucket to drain, if no water comes out its blocked, if water flows freely possible needs new pump.
Slim jim1
Nov 19, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Sep 24, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
