Question about Grohe Freehander Adjustable Shower Head System Chrome
Grohefreehander showerto stiff to operate
Hard to operate to use if you are infirm or a child is not posible
Why are my gear controlls on my handle bars stiff and hard to move
COULD BE RUST IN THE CABKLE, OR A FRAYED WIRE
Mar 20, 2015 | Cycling
My brake paddle sometimes get real stiff or hard when I press it
posible problem whit brake booster or vacunn supply hose
Sep 06, 2014 | 2006 Kia Sorento
Turn off child lock
Setting child lock
The child lock can be set to prevent a programme being accidentally started or a programme in operation being accidentally changed. The child lock function locks all buttons and the programme knob. The child lock can be activated or deactivated by holding down the OPTION and OK buttons simultaneously for 5 seconds.
  • Before programme is started: Appliance cannot be used
  • After programme is started: Programme in operation cannot be changed
The icon appears in the display to indicate that the child safety device is activated. The child safety device is not deactivated once the programme comes to an end. If you want to set a new programme, you must first deactivate the child safety device.
Dado
Below is Child Lock Icon
Mar 11, 2014 | AEG Dryers
The former Operating system is vista, i tried to down grade my operating system to XPsp2. the problem is the installation cannot continue the apperance is blue screen that informing me the hard drive...
you need to find the floppy driver for your chipset and install it to detect the hard drive. newer chipsets use a hard drive mode called AHCI, or like you mentioned RAID.
alternatively you need to go to the BIOS and disable these or change the setting to IDE/Legacy to detect the hard drive. the only advantage to the AHCI or RAID is hot-swapping the hard drive and Native Command Queuing (supported by newer hard drives) but the performance gain in XP would be negligible.
May 05, 2011 | Computers & Internet
The child locks are stuck it only opens from the outside
there is a slider switch on the door(between door and frame) that you can lock or unlock the child locks to prevent them from opening the door from inside but still can open door from outside----just slide the lock switch to enable or disable the child lock.
if they are stuck/stiff---you may have to remove the door panel for repair.
Usually they work free with a liitle lubricant(WD-40) to slide easier.
Jan 23, 2010 | 2000 Ford Expedition
To hard to turn and get about
You need to put pressure down on the handle bars as you turn ~ not like a wheelbarrow.
Jun 24, 2009 | Zooper Cool Zone Buddy Stroller
Display window stays on screen, buttons won't work
Sounds like one of the buttons on the monitor is stuck in. See if you can unstick them by pressing them infirmly, but not too hard, several times. Try each one in succession. Hope this helps!
Jan 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Half of drive
What Operating system are you using?? Posibly only will allow up to 500G
Dec 28, 2007 | LaCie Bigger Disk (300874) 1 GB Hard Drive
Grohe Freehander Adjustable Shower Head System Chrome Logo
53 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
