Question about Ryobi Garden
Ryobi rlt-1000ex electric line trimmer cannot remove bump knob
5 Suggested Answers
SOURCE: how do I wind trimmer line on double spoools for ryobi
Okay, so the good news is that YOU are probably not stupid. If you have a Ryobi trimmer like I do, it might have taken you a while to figure out the "secret" on how to rewind the line. If you only had to learn the lesson once, you are smarter than I am. (I'm leaving myself a note for next time).
If you wind the line the wrong way, you go through line really fast until it clogs up inside the bump head and you are forced to try again. The trimmer has an arrow on the spool for the direction to re-wind the line. Think of it this way, TURN THE SPOOL IN THE DIRECTION OF THE ARROW! Don't do what I did and rewind the line in the direction of the arrow, that would be wrong.
Whether this is a "mistake", a way to sell more trimmers/parts/line, or simply bad tranlation from Japanese to Engrish, it really doesn't matter. You don't need to buy anything with the exception of new line.
Good Ruck,
Mark
Posted on Aug 18, 2009
SOURCE: Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Posted on May 18, 2009
#1 Taper
  • 1040 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
SOURCE: have a ryobi rlt 30 cd and the spool wont spin fast enough
hgffggkgjgjgbTry taping the bottom on a hard surface;HARD!;;;;;;;bjjjjjjkjjjjm4454541joojojojlj That did the trick for me for some reason it doesn't grab and it gets lose were it won't spin fast bearly cutting a blade of grass.
Posted on Aug 15, 2009
How do i get trimmer line holder cap off my electric ryobi trimmer rlt 1038
Hi, I wished I had read this before I bought my rlt1038, I used it for
8 mins and 1) long grass caought around the drive head, 2) I tried to undo the screw holding the line head. Fortunately I have a wide pair of foot prints to go across the line head and a central heating pump adjustable spanner- after 5 mins I had undone it. Yet another bad design !
Good Luck
Mar 16, 2013 | Ryobi 15" Electric Factory Reconditioned...
Ryobi electric strimmer rbc 1000ex would not start
hi guys ,i have a ryobi electric rbc 1000ex and i've only used it about 5 times since new ,blue light comes on , but wount spin ? any ideas ?
May 12, 2012 | Garden
My bump knob on my Ryobi elect trimmer turns although very tight and turns the bolt but is not undoing. Any solutions please
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Oct 31, 2011 | Ryobi 15" Electric Factory Reconditioned...
I HAVE A RYOBI RLT 580. MY PROBLEM IS THAT THE COVER ON THE SPINDLE BROKE .THIS IS THE COVER THAT CLOSES THE LINE AND SPRING AT THE BOTTOM. NEED A NEW ONE. CAN ANYBODY HELP ME
This is all I could find for that model. Very little info is available on the RLT580, but I am sure you can get the part you need somewhere. Is this unit GAS or Electric?
http://www.ereplacementparts.com/search_result.php
Sep 05, 2011 | Ryobi 15" Electric Factory Reconditioned...
Where can I get a repair manual for a Ryobi rlt 900 trimmer ?
Go on line at RYOBI and you can down load it for free.
Jan 15, 2010 | Ryobi Garden
How do u remove the bump feed spool from the bump feed string head on my ryobi gas trimmer
Grasp the outer portion of the cutting head in your left hand and turn the inner knob with your right. Depending on model, some bump knobs are threaded and some are post and notch. Use a little spray like wd40 to loosen the mechanism. It may take a firm hand, but the two will separate so that you can reload the line. Consider reloading with the .095 five sided line. It cuts much easier than the round line.
Aug 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Have a ryobi rlt 30 cd and the spool wont spin fast enough
Apr 21, 2009 | Ryobi 15" Electric Factory Reconditioned...
Jammed line spool on Ryobi gas trimmer
I have a microwave that arch for no reason after it has been running more than 1 minute. if I'm warming a cup of coffee it arch. if I'm popping corn it archs. Could the bulb inside of it be bado or going bad? How do I replace the bulb? if you can't help me, could you forward this to someone who can. I bought the microwave from Seaars 2-years ago.
Jul 17, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Trimmer
Sep 09, 2007 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
306 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
