Question about Kodak EASYSHARE 5100 All-In-One Printer
When I connect my Kodak 5100 all-in-one printer to my computer, the printer works fine, but the remaining usb ports on my computer quit working. I cannot use a flash drive or any other device without first unplugging my printer. I have windows XP
    Scholar:
  • 60 Answers
Its not an issue with printer..........just chipset drivers on the computer needs to be up to date.........try and contact your system manufacturer if you dont know how to do it........
Posted on Jul 17, 2009
How do i get my printer to scan????
Do you have the full-featured software installed? (This software must be installed before connecting the USB cable to the computer) Download it here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9098/9099&product=EKN033539
If you use a USB hub or a print server, try connecting directly to the computer. The scanner needs bi-directional communication with the computer to work. Try a new USB cable and a different port. (Even if the printer works, the scanner can lose communication.)
I hope this helps.
(if the scanner light does not warm up or sound like it is moving, you may need to service the unit - contact Kodak.)
Apr 02, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
My kodak 5100 all in one printer will not print out my documents but only prints out what is on my scanner, how do i solve this?
did you recieved an error message printer not responding? If yes please double check the icons of printer on the printer and faxes, if you can see 2 icons delete both icons and unplug your USB cable, then restart computer.
Now if the computer is already restarted connect USB cable then try to print.
there are several reasons why it will not print using computer, there might a problem on USB cable and its connection or the drivers., Please verify the problem, or you may contact kodak toll free 1 800 421 6699. hey will help you on this issue., Gudluck!
Nov 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I bought a kodak easyshare all in one printer and the driver disk wont read what do i do?
Pls check the printer cable that connect from cpu to printer, or try to replace the cable with the another one.
Sep 06, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Hello, My Kodak 5300 acts as if it accepts a scan, it displays "scanning", but scanning never occurs. The copy function works fine.
connect ur computer and printer via usb cablen.scanning requires a place to scan and save the document. open home center on desktop and scan from there. u will be able to scan whatever u want. call kodak@ 1800 421 6699 for further directions.
Jul 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I have a kodak 5100. it worked fine with my dell/windows xp. when i installed it into my new e-machine, it was fine until i plugged in the usb cable, then it froze my computer. how can i fix this?
Try to put an other usb device like a memory stick in your e machine .check if this works fine.Also check the cable that connects your kodak to the E-machine.
May 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Installed with enclosed disc
Looking at the setup guide, it does indeed tell you to not connect the usb cable until prompted by the software. It is Step 7.
Here a link to the setup guide:
Kodak 5100 AIO Setup
Kodak Support has step-by-step instructions for uninstalling and reinstalling the software. Just make sure you remove the USB cable from the computer and reboot before you reinstall.
Here is the support page to begin on:
Kodak Support 5100 Reinstall
Comment back to let me know how it went.
Nov 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak AIO Easyshare 5300 scanning problem
Could be USB connection if you have another cable try it. Try connecting to different USB ports on your PC. If you have a Powerd USB hub lying around try connecting the printer to the PC through that.
Also try disconnecting all USB devices including the printer. Reboot your PC. Connect only the printer and try and scan.
Some times multiple USB devices dont work when they are both connected to the same PC.
Hope this helps!
SDtester
May 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Problem Installing 5100 printer
During the install, dont connect the printer when it tells you to. close the window that askes you to connect the usb cable to the printer and PC. The install should finish.
Leave the printer disconected.
Reboot the PC. If easyshare was installed you have to set it up.. If you did not select Web Install during the install then, after reboot and easyshare setup, open the Home Center software. There should be a message saying there are software updates availible. If not click the [?] on the top right to open the side pannel and click the bottom link that says check for updates. Run and install the updates. after its done then connect the printer.
If you did not need updates then try uninstalling and downloading the software directly from Kodak.com (link near bottom of this message)
If the printer still is not detected then try another USB port on your PC .. the PC ports on the back of the PC that are directly connected to the motherboard are the best. You can also try a new usb cable, or hook up a powerd USB hub between the printer and the PC. Also try unhooking all other USB devices (not printer and keyboard) then connect the printer.
If you could not get the updates through the home center you can get them at kodak.com (link bellow)
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?operatingSystem=windows_xp&downloadLanguage=en
I hope this helps. If you still have issues respond to this with any changes or what happened when you tried each step.
SDtester.
Feb 29, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
New Kodak EasyShare 5100 will not print!
You might have to reformat your hard drive as there is something in your OS that is hindering the printing.
Feb 01, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak easyshare 5300 issue.
Call Kodak tech support and they will ship you a new printhead without any charge.
Jan 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
78 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
