Question about Cell Phones
I have a TAE EVO 05 showing a water pressure of 6 bar - how can I adjust this down?
Chiller alarmed out twice with 1A error - I believe this is related to the high water pressure...
rablack66
  • 48 Answers
SOURCE: Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Posted on Nov 13, 2009
Testimonial: "Many thanks for your help. The drain was blocked with ice as you suggested. "
  • 2597 Answers
SOURCE: f22 error/ low pressure
F.22 Dry fire Too little water in the appliance, water pressure sensor defective,
cable to pump or water sensor defective, pump blocked or defective,
pump output too low
Posted on May 12, 2010
Testimonial: "thank you so much the information supplied allowed a local plumber to fix our problem in minutes 10/10"
  • 57 Answers
SOURCE: can you bypass high pressure transducer on a york
no you cannot
Posted on Jul 16, 2010
SOURCE: I get error code 13 when I put too much demand on
Use following link for Rheem tankless troubleshoot:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
I believe error code 13 is oxygen sensor malfunction.
Contact Rheem.
http://www.fixya.com/support/t3913798-error_code_13_air_flow_tankless_h20
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 23, 2011
george_karas
  • 211 Answers
SOURCE: alarm c1 oil pressure
check oil level srart for2 seconds disconect the -- earth of your battery let for 15 min conect then start after 10 min.
Posted on Aug 09, 2012
Hi, my Electrolux EWX12550w washing machine and dryer, working fine on was but when I'm drying it it starts at 13 minutes then keeps working but sticks on 10min also I get an err sign it's E10
Family error code E10 is visible to customers and (could be E11,E12 and E13 only visible in service mode) means problem
with filling water.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme).
Press and hold down START/PAUSE and the nearest option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the last alarm.
The alarm sequence continues as long as the two buttons are held down.
E11 - Problems with water fill for washing
E12 - Problems with water fill for drying
E13 - Water leakage
I believe there are difficulties in water fill for drying.
Water is necessary in the drying phase in order to cool down the steam entering in the drying condenser.
Possible causes: Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty
Dado
Sep 07, 2015 | Electrolux Washing Machines
My epson l800 write ,general error, open the printer cover and remove any paper inside the printer .turn the printer off and delete all print jobs ,turn the printer back on.am already try all but still...
Fix Epson Stylus Photo 6 Colors Printer General Error Problem
? 1:02
https://www.youtube.com/watch?v=Ci9MWG7zAkM
Dec 1, 2013 - Uploaded by TechRePair
Fix Epson Stylus Photo 6 Colors Printer General Error Problem. TechRePair ... ???????? Epson L800, T50, P50, R290, R295. User dismantling ...Missing: write
Epson General Error Problem + EPSON Adjustment ...
? 5:05
https://www.youtube.com/watch?v=gaKeB5JJqRc
Sep 28, 2014 - Uploaded by Gigi service
Epson General Error Problem + EPSON Adjustment Program / Waste Ink ... Reset Geral na Epson T30, T33, T50, T1110, L800, XP214, TX133 e ...Missing: write
epson l800 general error ' Error Help
Feb 10, 2015 | Epson L800 - printer - color - ink-jet
I cannot afford an aquarium chiller; however the temperature in my tank keeps rising and I can't seem to get it down. What should I do?
If your tank is in a room equipped with air conditioning, that would be your best bet; however if not, there are a few other options available to you.
I found a great do it yourself article on making a homemade aquarium chiller - take a look and see if it helps.
http://saltaquarium.about.com/od/diychillerplans/ss/sbsdiychiller.htm
If this does not help, then try the following ideas:
Fill a plastic bottle with water, freeze it, and then place in the tank
Adjust your lighting
Attach small clip-on fans to the hood of your aquarium and aim them towards the waters surface
Aug 29, 2012 | 1topstore Fish
This compressor is in my aquarium water chiller. When I plug in the chiller, The compressor starts then goes off. a few seconds later it starts again then goes off. It continues to do this. I have changed...
The Freon is probably a bit low. When the compressor draws from the low side the extreme low pressure trips the low pressure switch, shutting down the compressor. With compressor off the pressure equalizes the low pressure switch opens and the compressor switches on. murf427
Aug 02, 2012 | Panasonic QA125K29CAU6 Refrig...
How do I change the water pressure (bar) on my Rancilio Classe 6 E 2GR?
You will have to adjust the pump. there is an adjustment nut on the side of the pumphead, if you screw it in that gives you more pressure, and if you loosen less.
Sep 19, 2011 | Rancilio Classe 6 E 2 gr Espresso Machine
We have a Duet Washing machine. It keeps sounding the alarm and then the letter F will show up followed by the letter H..do you have any idea what these warnings mean...it just stops working and keeps...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hose, it may be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Feb 11, 2011 | Washing Machines
I get error code 13 when I put too much demand on the hot water. Too much demand before it shuts down is the bath tub at 1/2 the possible volume. I have adjusted my water pressure at the pressure...
Contact Rheem.
Feb 07, 2011 | Rheem Tankless Hot Water Heater...
F22 error/ low pressure
pump output too low
May 11, 2010 | Heating & Cooling
Error 6500 alarm flashing
Canon MP170 (Ink Tank Full Error):
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
Feb 04, 2010 | Canon PIXMA MP170 All-In-One InkJet...
My canon pixma mp170 says check printer on the screen with error code 5200 and the alarm button is flashing
1 - power off.
Dec 16, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
