Question about Cooktops
The Defy Ceramic Hob DHD390 is level level with the granite top when fitted?
Want to know when the Hob is fitted will it be level with the granite or will it stand out a bit Worried about the edging of the ceramic if it chips
SOURCE: how to fix a crack in ceramic top
Mine cracked and I ordered a replacement shipped overnight. I can't get a repair person out before Christmas. Is it easy to do it myself?
Posted on Dec 20, 2007
SOURCE: Bosch ceramic hob
hold down powerboot for 4 seconds to switch off child lock
Posted on Sep 15, 2008
SOURCE: have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Posted on Sep 29, 2009
SOURCE: error code 56 on stoves ceramic hob
The capacitor C17 on the pcb modual needs changing, dont go to stoves as this will cost you in the region of £250 to £300 yep i could not believe it either, Go to Maplins and get a capacitor (1000uf 16v VH50) Turn of the power Lift out the hob undo the screws around the top edge two each side the at the back take off the Glass now remove the heat shield from around the modual, lift out the modual and turn over, looking at the pcb at the top slightly to the right is C17 a small object that looks like a silver battery, carfully break this so it falls apart and remove any small bits, note - on left + on right Now solder new Capacitor in place, you will have to cut the legs shorter so dont get any parts to hot when soldering new part in, put everything back as it came apart and the hob will now work as good as new and only costing you approx 56p it should take a novice about 20mins to do this, good luck.
Posted on Oct 03, 2009
SOURCE: Have a baumatic ceramic hob displayin letter 'L'
the solution is already on fixya i just tried it and it works.press the right key and the minus key at the same time release the right key hold the minus key for 10seconds and the L will disappear
Posted on Jan 27, 2010
Residual indicators & right hot plates don't work!
LOL like the way you put that about FAULTY ELECTRICIAN . and that would be my guess also .
Feb 11, 2016 | Cooktops
My clients ceramic hob has small scratches appear on one of the pan areas it's only a week old how can this happen the pans seemed clean underside .
ceramic tops are not made for sliding pans or skillets on . as on GAS ranges. give them a bottle of cook top cleaning creme
Dec 22, 2015 | Bosch 233331 - GLASS CERAMIC HOB TOP
Hob problems
Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
Hope this helps.
May 19, 2010 | Smeg 28 in. P752 Electric Cooktop
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Cooktops Logo
27 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
