Question about Water Heaters
Tekmar 150 the tekmar 150 was already in the house we purchased. No mauals were left and I don't know how it works. It is cold in the basement and I am wondering what temperatures I should have it set at and some general instructions of how the system works
  • 2,692 Answers
Posted on Mar 11, 2009
I have a 1991 40 gl and it fell through the floor which is like 2 ft off the ground. turned the water off and replaced the pipes it has its own lever type power supply with the screw in fuses 30 amp (2) of...
You have 2 problems with several possible causes:
You have 10-year-old electric water heater that was reinstalled after falling down, and doesn't heat the water.
And you have no hot or cold water pressure, and no pipes are leaking.
1) First problem is lack of water pressure throughout house.
Turn on outdoor spigot nearest to water meter.
This spigot will tell you if problem is inside the house or between the house and meter.
If spigot runs full force, then you probably have clogged pipe where water heater connects to main cold line, or the main shut off valve got clogged with sediment that broke off inside the pipe when you were working on water heater.
Open and close shut off valve to see if that helps. Then disassemble pipes and track back the problem. Put pressure gauge on water heater drain valve to watch pressure drop when turning on indoor faucet.
Read following information:
Water heater doesn't work:
Test across wires at top of heater to see if you are getting correct voltage:
If tank is receiving correct voltage, then no hot water puts suspicion on upper element or upper thermostat, or both.
Open following link for electric water heater troubleshoot steps:
First had no hot water, no water coming out at faucetts at all
If you had to shut the entire house off to install, your main valve may have broken off. Common problem with cheap Home Depot gate valves. Check valve and see if it turns endlessly. If so, that's the problem. To get water back on you'll need to shut off at the meter. The stem assembly screws into the valve body. Carefully take a wrench and unscrew stem assembly from body. Once removed you will need a pair of needle nose pliers to remove gate assembly which broke off. Pull out gate, make take a little effort if water is hard in your area, may have to tap a few times with small hammer on bottom of valve to free it up. After removing gate, reassemble whats left of the stem assembly. Be careful with gasket, grease on threads helps. Tighten vice and snug. Note: Whenever you are working on piping, plumbing systems, always be aware of how you tighten and loosen things up. Back up what your removing with another wrench or channel locks. You don't want to snap something off and create more problems!
Now go back inside and open hot and cold water in tub. Make sure valve is on over water heater. DON'T PLUG IN OR TURN ON ELECTRIC WATER HEATER UNTIL YOU KNOW IT'S FULL.
Turn water back on at meter. Go inside and see if water is coming out.
Apr 24, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a 3 year old ge smartwater gas water heater. in our ontario winters, the gravity vented unit spills exhaust into the basement because the pipe and chimney get too cold after the heater is off for...
Id try raising the chimney until you can get the smoke from a piece of paper to get sucked up under the draft hood. I believe theres a different problem then a cold pipe.raising the chim.might not be the answer.
Jan 17, 2011 | General Electric GE SmartWater Household...
I have a Rheem 80 gallon electric water heater in our new house. It's been in use about 6 months. When we first moved in this past summer, at least two lengthy showers could be taken back to back and still...
To check to see if it is a bad element - turn the power off again and use a multimeter to check continuity (Ohms) in each element. It is not uncommon to have one element fail. Replacing an element is "elementary" :), if you have some mechanical aptitude. Just be sure and drain the tank to below the level of the failed element. Easier if it is the upper element of course. Again - be sure the power is OFF - check it with your meter before you begin and you may even want to lock out the breaker if there is any possibility of someone mistakenly turning it back on.
Dec 18, 2010 | Rheem Water Heaters
Bosch water heater keeps getting error EA. We read online that if we ran the hot water in the sink while taking a shower it would stop erroring. We did that and it worked perfect for about 6 months. A...
lower the output temp on the unit. the tap water could be too cold coming in. The bosche units don't like a large temperature difference between tap water and the water at your shower head. Condensation becomes a real problem. I run my water thru my basement slab to heat it up and that made all the difference, but you probably didn't buy your house with a dirt basement did you?
Dec 08, 2010 | Bosch & Tankless Water Heater
I purchased a new GE GE50M06AAG water heater at Home Depot. Installation was fairly simple and straightforward. Once the tank was full the T&P valve started to let water come out of the valve, causing...
Hello Put a bucket under the relief valve and lift the lever up and snap it closed.Maybe it is not seated correctly.If not change it out.Also if the new one acts up you need a cold(domestic)water expansion tank(EXTROL) in the cold water pipe.
Sep 17, 2010 | General Electric Water Heaters
50 gallon electric heater not working after about 5 minutes in the shower the water gets cold and the rest of the house i do have 240 going to water heater thermostats goood element good
Some elements will read with a meter good until they heat up.
Hot water then going to ice cold top element is working and bottom bad. Luke warm water and then goes cold bottom element good and top element bad.
Elements and thermostats are not to exspensive to replace.
If you have power only two thing's left are the thermostat's and the elements.
May 21, 2010 | Water Heaters
My water heater isn't working correctly. The temperature is set to 140 and the water is still freezing cold. I called the number on my water heater, but i had trouble understanding the man due to his...
if its electric its your element thermostat,if its gas the thermostat is down by the gas valve they are why water isn't hot,they are shutting off supply of either gas or electric they are both easy to install
Oct 17, 2009 | Water Heaters
I have a Rinnai tankless. The temperature fluctuates wildly
I think the dip tube in your water heater has failed, this is a plastic tube that goes in the cold side of your tank and forces incoming cold water to the bottom of the tank allowing hot water out at the top. When this tube deteiorates the incoming cold water mixes at the top of the tank causing the problem you have. the dip tube runs about 5 bucks but takes someone with pluming skills to install.
Jan 05, 2009 | Rinnai Webstone The isolator EXP tankless...
Water Heaters Logo
114 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
