Question about Kitchen Appliances - Others
MORPHY RICHARDS Accents 44038 4-Slice Toaster - Country Cream
  • 883 Answers
SOURCE: 4 slice toaster
open the unit. look for disconnected wires from sloppy factory
Posted on May 21, 2007
  • 32 Answers
SOURCE: Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 05, 2008
  • 37 Answers
SOURCE: wiring diagram needed for 3 slice dualit model auto 3
get it at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Posted on Nov 20, 2008
SOURCE: the toaster does not work but the egg portion does
Call the company. They will send you a new one. At least they did for my neighbor.
Posted on May 28, 2009
SOURCE: 4-slice egg & muffin toaster
On my fourth one now...love the idea, but the egg poacher keeps burning out.
The 800 number is 1-800-688-1989
Calling them now...this last one only lasted 3 weeks.
Posted on Jul 28, 2009
Where can i get manual for morphy richardscombi microwave.ac925efp
Free Morphy Richards Kitchen Appliance User Manuals ...
kitchen.manualsonline.com/manuals/.../morphy.../morphy_richards_pro...
Morphy Richards Electric Pressure Cooker User Manuals. Get Manuals; Support ...Morphy Richards Hot Beverage Maker User Manuals. Get Manuals; Support
Oct 30, 2015 | Morphy Richards AC925EFP...
I lost my brush for morphy richards vacuum
look on ebay or amazon or morphy Richards them self the deliver to almost every countrie check postage cost before commiting to buy if you are unsure if the post just ask them a question via email
Apr 08, 2014 | Vacuums
Voltage change to 120V
You can change the plug out but I very much doubt that your toaster will even heat. The way toasters work is by a resistance wire that heats up because of the current going through it that causes the wire to heat up. Since the wire that is in your toaster is designed to heat up under 220V drawing 9 amps. SInce you are now supplying only 120V then since I=V/R then in the first instance 9=220/R or 9*R=220 =24.444 Ohms Since in the second instance your V=120 then your Current =4.9 Amps and this will not be enough wattage to heat up the wires.
Jul 14, 2013 | Morphy Richards Accents 44744 4 Slice...
Toaster, 4 slice, throws safety switch when toaster heats up.
If it is throwing safety switch, other wise know as circuit . I assume your talking about wall plug in circuit. If this is true, then you can try moving to different out let. All kitchens, where a toaster normally would be plugged in is a series of at least out lets by code requirements. If you find another outlet, that is on a different breaker, then should not trip. If you are on same circuit right now that fridge is on or microwave, toaster might be to much in conjunction with the fridge running continuously ,and micro wave at regular use. Please let me know if this helpful info to solf problem. Thanks mike from fixya
Jun 14, 2011 | Morphy Richards Kitchen Appliances -...
Hi there Hiw can I turn off the whistle on the Morphy Richards Accent kettle please?
You can turn off the electronic whistle on the morphy richards kettle by moving the switch (marked with a musical note) which is located underneath the electric base unit (not on the kettle itself).
Mar 03, 2011 | Morphy Richards 43691 Cordless Electric...
Where do you buy the special screw driver to take the bottom ff the 44336 toaster as the toaster wont stay down on that side?
Well, I don't have that type of toaster. What do the screws look like? If they look kind of like allen but an allen wrench will not work, they would be TORX.
Feb 03, 2011 | Morphy Richards 44051 4-Slice Toaster
I just bought a dab from Morphy Richards and, it appears that you need aa remote to change channels. Could this be so? Display says press select yet there aint no select on the unit... model is Morphy...
ok i just found out what it is digital radio !!!!!!!! ok i dont think we have a radio department but i think we still have a car audio department . those guys should be up on all this new stuff .... good luck
Mar 30, 2009 | Morphy Richards 44051 4-Slice Toaster
Morphy Richards coolstyle Model 44880 4 slice toster
I have the 44280 2-slice version and had similar problems. To dismantle, unscrew the two star-shaped screw heads which hold the retaining slides in place. I don't have a star socket (female), only the usual male, so I used a pair of pliers. Pull out the two chrome slides. Pull off the two knobs also using pliers. Remove the outer casing with care as there are two fine wires attached. Now you can see the problem - probably a broken or lost nylon retaining catch on the electromagnet, and probably unobtainable by an individual. At this stage I decided to buy a new toaster!
Alec
Sep 29, 2008 | Morphy Richards 44778 4-Slice Toaster
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
