Question about OMNI Alfa 500mW AWUS036H USB Wireless Adapter 80211 bg Network Radio Card Includes 2dBi Omni Antenna 80211gb
Awus036h won't install on windows 98 - OMNI Alfa 500mW AWUS036H USB Wireless Adapter 80211 bg Network Radio Card Includes 2dBi Omni Antenna 80211gb
  • OMNI Master
  • 7,733 Answers
Windows 98 NOT SUPPORTED
Posted on Apr 21, 2013
Testimonial: "Oh bummer. Thanks for the input."
I want driver alfaawus036h
http://support.data-alliance.net/alfa-awus036h-driver-installation-instructions/
Jan 11, 2013 | OMNI Alfa 500mW AWUS036H USB Wireless...
I'm trying to install a program but it is telling me it can't run, it requires run as. how do I fix this
This occurs when you are trying to install an older program on modern machines. Old DOS-based software can sometimes be run in a window, but may require much manual setup. Older Windows-based software may be restricted because the programmers, knowing the software would not run on Windows 95, let's say, had the software look for the Windows 98 identification. Unfortunately, while those programs may well run under Windows XP, since the program is only looking for Windows 98, it see this as in incompatible operating system. Therefore Microsoft gives you the ability to run these programs in a "run as" mode. You select which OS you wish the software to "see". So if your setup program won't run because of this issue, try this: Right click on the setup program icon, select the COMPATIBILITY Tab, and try using COMPATIBILITY Mode. Tinker with the setting and retry to load the program. Hopefully you have a good outcome. Of course the better solution is to get a version of the software that is updated and compatible with the current OS, but this is not always possible.
Jan 13, 2012 | E-Machines eMachines Desktop PC
CANNOT PLAY BICYCLE PINOCHLE SINCE UPDATING COMPUTER PLAYED BICYCLE PINOCHLE ON WINDOWS 98, CANNOT PLAY ON WINDOWS 7
Unfortunately, due to changes in the OS and how programs run, a program written for Windows 98 will not run under Windows 7 directly.
Even the compatibility mode will probably not work unless your version of Bicycle Pinochle for Windows was written for XP as well as Windows 98. (The WinXP version would possibly run under the Windows 7 32-bit version; it won't work under the 64-bit OS. To find your version of Windows 7, click Start > Control Panel > System and Security > System. If the version title ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit version.)
You need to either upgrade your game software or get an older version of Windows running somehow. This could be a virtual computer (runs inside your Windows 7 computer if your hardware permits it), a second machine or a dual boot computer. For Windows 98, you will need a licensed version of the OS for any method. Check a nearby Windows User's Group to see if anyone there has the OS.
If your version of Pinochle could run under Windows XP and you have Win7 Pro or Ultimate (or upgrade to them), you can run a virtual version of XP for free. In this case, download and install (in order) Virtual PC and XP mode from Microsoft. Then install the software in the XP computer as if it were the only computer running. (The compatibility mode didn't work inside XP mode for software written for Windows 2K so I doubt a Win98 program will work.)
An XP version of Bicycle Pinochle was offered by Microsoft: http://www.microsoft.com/games/bicycle/card/ . A Windows 7 version of Single Deck Pinochle is here: http://www.sac-irca.com/pino.html .
I wish that I had better news for you.
Oct 23, 2011 | Expert Software Bicycle Pinochle for...
I have a usb portable diskette drive that says compatabible upto windows 98 I have windows 7 can I download drivers for it?
If it won't plug and play then your basically out of luck. That is a very old device. If you still need to access floppy's i would purchase a newer device or have an internal floppy installed.
thank you,
Lee
Jul 26, 2011 | IBM USB Portable Diskette Drive (05K9276)...
I need the drivers that have to be installed in the process of installing windows 98 se
The drivers that are required are completely dependent on the hardware that you're installing the OS on. The OS itself comes with almost all the drivers it needs in order to have basic functionality. The easiest thing to try would be to go to the manufacturer's website and search their support section for driver downloads. Select the model computer you're reinstalling on and it should allow you to select which version OS you're installing. Pick Windows 98 if it's available. If it's not you'll have to resort to Google, but it would be possible that they didn't make Windows 98 compatible drivers for that particular hardware.
Jun 13, 2011 | Computers & Internet
I want to install alfa awus036h driver
Go to the site
http://www.alfa.com.tw/in/front/bin/ptlist.phtml?Category=105397
and go to usb adapter drivers, download driver for your OS.
Thanks for using FixYa.
May 24, 2011 | OMNI Alfa 500mW AWUS036H USB Wireless...
Hp d2400 won' install on computer with windows 98
Greetings,
Minimum System Requirement : Windows XP as stated on their website. Windows 98 is not supported.
Keep us posted and thank you for using our service.
FixYa - Technical Support, Instructions & Repair Service
Jul 30, 2008 | HP Computers & Internet
OMNI Alfa 500mW AWUS036H USB Wireless Adapter 80211 bg Network Radio Card Includes 2dBi Omni Antenna 80211gb Logo
101 people viewed this question
Top OMNI Computers & Internet Experts
David Payne
David Payne
Are you an OMNI Computer and Internet Expert? Answer questions, earn points and help others
