Question about Hunter Dryers
Hunter fan 27185 has lost speed
Model 27185-060 has a three speed control which worked fine last summer. Today I replaced the battery on the remote because the controls weren't working as they should. The fan and light will go on but I cannot regain the different speeds I once had. At best it spins at low to medium speed.
    Master:
  • 993 Answers
Capacitor or its wiring defective
Posted on Jan 20, 2015
    Top Expert:
  • Hunter Master
  • 33,282 Answers
Remote controlled ceiling fans can suffer a lapse of memory when there is a power outage. You eliminated the possibility of a dead battery in the remote by installing a new battery, but just to be sure remove the new battery and press all the buttons on the remote to eliminate the possibility of a stuck button then reinstall the battery. Next disconnect power to the fan at the breaker box, not a wall switch or by tugging on a chain. Turn the fan power on again. Using only the remote, check operation.
Posted on Apr 20, 2013
hardrocko
  • 1476 Answers
SOURCE: 3 speed Hunter Fan only has 2 speeds
Assuming that the unit was wired properly from the factory and without being able to look at the switch I would have to agree that the switch is bad. The different speeds are obtained by having a different winding for each speed. If the unit was wired properly at the factory and never had three different speeds then the switch is not rotating between all the contacts. The switch should only be a couple of dollars and would certainly be a cheap solution to try. You can check the existing switch by removing it from the circuit completely and checking the continuity with a DMM from the input to each output as you switch it. Continuity should move from one to two to three. If not the switch is bad. If the switch checks out OK then you have a bad winding in the fan and probably need a new unit. Good luck.
Posted on Jul 12, 2006
SOURCE: Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Posted on Apr 22, 2009
SOURCE: hunter speed control problem
I have the exact same problem. Called Hunter's tech support and they confirmed the capacitor must be bad. This is the black box that has 4 wires going to the switch. They are sending me a new one for under $12. I haven't received it yet, but the wires from it going to the switch can be removed from the switch by shoving a paper clip along side the wire, this'll release the spring clip holding the wire in. Not sure, but I may have to cut and wire nut any wires that go elsewhere.
I recommend you call them too and as long as you have the 5 digit model number (usually on top of fan) they should be able to get you what you need.
P.S. it is highly unlikely that it is in the switch. I tried replacing it with one from Home Depot and I actually got Low-Off-High, which is worse. The Hunter tech support guy said you can't use after market switches with their fans.
Posted on Jun 19, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
SOURCE: Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Posted on Mar 11, 2010
What is the code for a hunter fan remote model
That's the model # for the remote. www.hunterfan.com
Sep 29, 2014 | Dryers
I have a Hunter Ceiling Fan Model No. 27185. I can control the fan with the remote but can not control the lights with the remote. is there some instructions on how to operate the system?
27185 is the model # of the remote. Check to make sure your light wires are connected at the light fixture & receiver. Also, make sure your dip settings are set on the same frequency. Lastly, push the light button & pull the chain on the light.
Oct 06, 2013 | Hunter Dryers
Hunter model 27185-060 remote problems
1) clean the contacts batteries 2) change the new batteries 3)resolder the wires contacts batteries 4) open the remote, and clean the keypads with special spray very well, 5) resoldert any colder joints for better contacts 6) reset the code again and proof 7) otherwise you must go to the repair shop TV, or replace by new ones.
God bless you
Jun 19, 2012 | Hunter 27185 Remote Control
We got 4 HUNTER ceilin fans in one room. Model 27185-060 with remote FCC ID:IN2TX11 Two of them are runing clocwise another two in opsite side Wat can we do to run all in one direction?
Your Hunter ceiling fan is equipped with a small switch that changes the spin of the blades from clockwise to counter-clockwise. Regardless of the make or model of your ceiling fan, this switch is typically located on the center motor housing where the fan blades are attached. good-day!
Aug 19, 2011 | Hunter 52" Ceiling Fan With Light And...
The remote on my Hunter ceiling fan (Model: 27185 - 060) does not activate the ceiling fan. I can turn the light on manually, but not the ceiling fan. I cannot see the antenna on the ceiling fan.
The first thing you need to do, is change the battery(s) in the hand held remote, as well as the battery(s) in the receiver inside the fan's cowling. Weak batteries will limit a remotes operation.
And, FYI - there is no antenna on the ceiling fan.
I hope this helps you. Thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
Re: Hunter Fan Model 27185 - 060 The above fan was purchased circia 5/1/2000 and does not now function properly (actually it has not been fully working for 4-5 years. It is installed in a 19' ceiing...
You either have a wiring problem possibly a ground rocked loose or the motor is going out.but if you press 1 while its running and it dies sounds like motor and nothing wrong with remote
Apr 26, 2017 | Hunter Heating & Cooling
LIGHT AND FAN ARE NOT WORKING. HAMPTON BAY LIGHT IS NOT WORKING
Could be a loose wire up inside the fan. I would be very careful in its use. Might I suggest getting an electrician in to resolve this issue. You do not want to battle a fire over a fan light issue.
Aug 28, 2009 | Hunter Ceiling Fan Light Remote Control
good luck.
Aug 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
584 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
