Question about Xerox Phaser 7750DN Laser Printer
"Print Error-Contact Service; Report Fault 7-401"??
We have a Phaser 7750 in our Graphics Dept that displays this message:
Print Error-Contact Service; Report Fault 7-401 Press i
I've already changed the mnotherboard with the HD. Anyone ever seen this message before?
  • Jafu82 Mar 17, 2009
    I can't seem to get to the Service Diagnostics. Back arrow and "i" have to be pressed simultaneously?
    All i managed to see when i hit Back arrow was the word "Null".
    Guru:
  • 110 Answers
Reset the Tray 2 feed counter within Service Diagnostics as follows:
1. Enter Service Diagnostics (back arrow botton with the "i" button soon as you turn it on) and scroll to NVRAM Access and press OK
2. Scroll to Reset CRU Life Counters and press OK. The display will show the status of all CRUs. Press OK until the Reset Counters menu is displayed.
3. in the Reset Counters menu select Yes and press OK.
4. Scroll to Tray 2 and press OK.
5. Exit diagnostics.
That's what worked for me I called a company called Iteminc they gave me the instructions and they told me to :Replace the tray 2 pick, feed and separate rollers before it starts jamming soon. www.iteminc.com is their website good luck give them a call if it does not work.
Posted on Mar 16, 2009
  • iteminconline Mar 17, 2009
    Yes the back arrow and the "i" arrow have to be pushed at the same time hold them until you get into service diagnostics.
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
MAINTENANCE:
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
Xerox Phaser 7750 error code 14 & 15.
try to hold down the on/reset button a few seconds when you power it up ...on most printers this resets them ..about 10 sec it is enough ...
Nov 26, 2009 | Office Equipment & Supplies
Hi i got xerox phaser 7750 and i have error code
Cheap fix : reset the Developer Life Count in the Service
Tools menu. Hold down the back ARROW key with the "i" them with your other hand turn on the machine.
Expensive fix : What has happen is that the developers have come to the end of the life and once it gets to a certain page count it will print out no more until you have replace the developers. One thing xerox forgot to do is reset the engine control board too for this machine. So you might need a new engine cotrol board too.
Procedure
1. Replace the Developer
2. After the Developer has been replaced, reset the Developer Life Count in the Service
Tools menu.
NOTE: It is recommended that all the Developers and Beads be replaced at one time rather
than on sccessive visits.
Good luck.
Oct 29, 2009 | Xerox Phaser 7750DN Laser Printer
I have a xerox 7750, error code 9-913
This problem occurs when you buy the wrong image unit.
The contact chip that is located at the bottom of the orange plastic is not for the machine. Replace it with 7750 image unit and that should fix your problem. Black is fault 9-910 cyan fault : 9-911 magenta fault: 9-912 yellor 9-913.
Sep 24, 2009 | Xerox Phaser 7750DN Laser Printer
I get an error message that says "Printer Error - Contact Service: Report Fault: 15.004.45.1758" Whats does it mean and how can I fix it? Thanks
That means the 2 halogen lamps that serve as the drum heater have gone out. Either one or both have blown.
They simply are 2, ,, 150 watt halogen lamps that you can replace, Takes about an hour to do, I can send you instructions if you want.
E-mail me ,,, rak458@aol.com
Jul 14, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 7750 Fault 9-913
Use the following procedure to troubleshoot Error Codes 009-910 through 009-913
1. Check the installation of the Print Cartridge. 2. Clear the Tech Rep Fault for errors 009-910 through 009-913 (see instructions below). 3. Try changing the indicated Print Cartridge. 4. Check for an open wire or poor contact between the Print Cartridge and the Engine Control Board. a. Yellow, J-151 to J-405 b. Magenta, J-152 to J-405 c. Cyan, J-153 to J-405 d. Black, J-154 to J-405 5. Replace the engine control board
NOTE:  Before troubleshooting for an open circuit (Step 4) or replacing the Engine Control Board (Step 5), clear the Tech Rep Fault for any of these codes first using the following steps: 1. Enter Service Diagnostics. 2. Highlight NVRAM Access and press OK. 3. Highlight Clear Tech Rep Faults and press OK. 4. Highlight link codes 009-910 through 009-913 and press OK.
Hope my info solves your problem..... Thanx for using fixya......
Oct 24, 2008 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750
There is a motor in the laser called the polyogon motor, It turns the mirrors in the laser.
It most likely is not starting fast enough.The laser isnt that hard to remove. But if it has failed, it is pretty expensive.
Let me know if you want to attempt to pull it.
Sep 10, 2008 | Xerox Phaser 7750DN Laser Printer
PRINTING ERROR
> Home > Support & Drivers > Knowledge Base
Solution --> ERROR 0082" name="Note" /> Phaser 790 / DocuColor 2006 Printer's: Cancel print job and cycle the printer's power
  • On the printer's Control Panel, press the Cancel Key (12 KB).
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the CANCEL key.
  • If the error message persists, turn the printer off for at least 30 seconds and remove the computer interface to the printer (17 KB) before turning the printer back on.
  • Use the menu keys to perform a front panel reset (under RESETS menu).
  • If the printer redisplays the error message upon reboot, a file is likely STUCK at the front of the print queue. Use the front panel RESETS menu to CLEAR LOGS AND QUEUES, which will delete all print jobs in the printer's disk spool.
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the MENU key to gain access to the front panel menu.
  • If the front panel menus can not be accessed turn the printer off for 30 seconds and then turn the printer back on.
  • If it is known which print job was last sent to the printer, try to reprint the last job spooled, which may be the cause of the error. Step 4 on clearing logs and queues may need to be repeated to eliminate the crashing job.
Note: Most XX82 or XX1E front panel error messages are NOT hardware related, but caused by a specific print job or application.
Mar 04, 2008 | Tektronix Phaser 860DP Thermal Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 7750DN Laser Printer Logo
834 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
