Check the site linked below. It has setup code list to many popular brand remote controls. Refer them, and check which brand remote control have setup codes to Crosley. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to
many popular brand remote controls are given.
Three digit, four digit, five digits and two-digit code list are
there. Check the site with
patience. Surely you'll get a solution
to your problem. Search the site by
'Timeslide' option. It will make search
easy. Or, type in the brand name to
your device into its search box, and press "Enter"
When it is off and plugged into the wall outlet the standby light will be on. The stadby light will go off when power button is pressed. If not there is poblem that needs service.
I recently was given my Father's CR78CD and, assuming your unit is in working order, you turn on the turntable motor by lifting the tonearm off the post and moving it away from the turntable about one and a half to two inches. You should hear a soft click as the switch for the motor activates.
For belts, I recommend PRB belts - they are one of the only manufacturers left. However, they have been in the belt making business for a long time and their products are exactly what you need.
Here is a PRB distributor that can help you. http://www.vintage-electronics.cc/vprbbelts.html
I hope that helps.
I would hope the unit could be operated locally, but if it must be controlled by a remote, you'll have to find the lost one or replace it. Two replacement remotes are available for $61 or $48 below:
http://remotes.com/store/crosley/cr248.html
Given the price of the remotes, it may very well require the remote to operate.
