Question about Panasonic PV-V4021 S-VHS VCR
Action button will not let me set the time on vcr
  • Panasonic Master
  • 1,511 Answers
No action that is why
Posted on Jan 22, 2015
I have rca niteglo with tv and vcr program spots and no code search or indicator light, how do i program my tv to it?
You can try to set-it up with the set-up codes said to RCA. Both TV and VCR should be synchronized separately. Both of it will have separate codes too.
No remote control will have a button on its marked as 'Code Search' . There is a way to do it.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 01, 2014 | RCA Televison & Video
ADV-3800, how do I set the clock
Press VCR button to change into VCR Mode and follow the procedures below.
1 Press the SETUP button on the remote control.
2 Press the ENTER button, while highlighting CLOCK SET.
3 Set the current date and time with button or NUMBER button.
For DATE SET, follow the order of Month/Day/ Year ; for TIME SET, follow the order of Hour/Minute in CLOCK SET screen.
4 Press SETUP button after completed.
You can find your complete manual HERE.
Click DOWNLOAD THE DOCUMENT, and then in area 2 enter the verification code, and click download now.
Mar 01, 2011 | Apex Digital ADV3800 DVD Player/VCR
Change clock
how do I change the time on my sansui vrdvd4000 dvd player / vcr combo
Nov 06, 2008 | Sansui VRDVD4000 DVD Player/VCR
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Timer programming
The remote control is key to timer recording. Notice the selections are color-coded: grey-black for VCR, gold for DVD. Then look at the second and third rows of buttons. Each button has multiple functions depending on if the VCR or DVD button has been pressed. To record from TV signal to VHS, press the VCR very top button. (The controller will also control your TV if set up properly, so be sure the small switch at the top-left of the controller is set to the VCR/DVD side. I use a separate controller for my TV so I never change this.) Now press the "PROG." button located beside the "3" button. (Your television must be on and set to "see" the VCR not the normal TV signal.) Now look at the second row of buttons, the ones with the "+" signs. The grey words below them indicate what they'll do when pressed (the same buttons do what the gold words say when the DVD is selected.) So to set the start time, press the first "+" button with the word "START" below it. That sets the start time of the show you want to record. It'll go in 30-minute intervals if you hold it down, otherwise it's a minute-at-a-press. If you go too far, you can back up with the third row's "-" button. When you have the start time set, move on to the next button labeled "STOP" and similarly set the end-time of the program. Continue with the third "+" button to set the date you want to record. Lastly, set the channel by pressing the fourth "+" button labeled "CH." It's a bit tedious if you have a high channel number to get to. When you have all these set properly, it's important to then press the "TIMER" button (located next to the keypad number 6). That turns the VCR off but "watching" for the settings you've just made, and it'll wake up and do the recording at the proper moment. You can confirm you've got it waiting by looking at the display on the VCR; to the left of the channel number a red "clock" image should be lit. That says it's waiting. You can program several shows to record by repeating these steps, or you can do them all sequentially by setting the first one, then pressing the "PROG" button again (rather than the "TIMER" button) and setting up the next recording. When you're done, THEN press the "TIMER" button and the VCR will go to sleep until it's assigned wake-up time.
Sep 16, 2008 | JVC HR-XVC30U DVD Player/VCR
SAFE
Pro-Tect Plus™ Locking Feature
To disable VCR usage or to protect set timer recordings, the unit can be locked so that the
buttons on the VCR or remote control don’t work.
• To Lock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
appears in the display to indicate Pro-Tect Plus is active. SAFE also appears if the VCR is
turned on while the feature is activated.
To Unlock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
disappears from the front panel display. Unlocking is the only way to use the VCR.
May 10, 2008 | Televison & Video
Setting the clock/time
There should be a menu button on the remote which will get you into the various advanced programming functions. Many/most of the late VCRs cannot be programmed, time set with the buttons on the VCR itself.
Mar 12, 2008 | Televison & Video
How to set time and date
Turn on. Goto channel 3 or 4. Press DVD/VCR button until display says VCR. Press TV/VCR button until the display says VCR. Press SETUP button. Select SYSTEM SETUP. Select CLOCK SET. Edit time and date. Press SETUP button.
Jan 07, 2008 | Toshiba SD-V394 DVD Player/VCR
Turning on VCR for 2nd time recording
Have you fixed your problem?
If not, just try pressing the dvd/vcr button, so the vcr becomes the primary device. Now you can press setup and go back into the vcr menu.
Nov 11, 2007 | Toshiba SD-V394 DVD Player/VCR
Set vcr to record a program later
The VCR has to be off for the timed record to work.
Oct 30, 2007 | Mitsubishi HS-U510 VHS VCR
Panasonic PV-V4021 S-VHS VCR Logo
107 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
