Question about Crosley CR78 CD Shelf System
The CD door or drawer won't close properly with out giving it a nudge just before it suppose to close, other wise its ajar just slightly!
BASICALLY WHAT I already wrote it it hessitates write at the closing,its like its sticking or something it just won't completely close on its own !
    Top Expert:
  • Crosley Master
  • 36,514 Answers
I have had a couple of drives with that symptom. Tried cleaning the guide rails and applying a drop of silicone lube to the rails. No change. Concluded the little motor was becoming too weak to close the tray, so back to the nudge and hope routine
Posted on Apr 20, 2013
2 Suggested Answers
  • 1833 Answers
SOURCE: CD drawer will not stay
This type of problem occurrs due to spring which is installed in
the system. Bring a spring from the market for that product. After
that open the system and remove the old spring and install new one.
After that check the power cable which is connected with the outer
switch. If it has no power then changes the power cable also.
Be careful, If you have no proper tools to open the system then buy tools from the market. Otherwise your system may be damaged.
Posted on Aug 15, 2011
Dishdrawer door comes ajar
It is also likely the drawer has come off the gliding rail at the right.
You will have to pull the drawer out from the housing and check. Not sure if you have a standalone unit or integrated with the kitchen cupboard. The instructions to pull drawer out are available in the installation manual. Select the correct model from this site .
http://www.fisherpaykel.com/au/support/user-manuals/
Dec 08, 2013 | Fisher and Paykel 24 in. DS-603 Built-in...
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
Tailgate won't close
are the jaws in the lach already closed? If so stick a screw driver in ther and pull the handle while you pry them open.
Apr 15, 2013 | 2002 Dodge Ram 3500 Truck
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
Door ajar light stays on door won't close all the way
-Just disconnect the wire that hook up to the switch.
(Only on the effect door)
-Or remove the switch and if you can put a spacer to bring the swtich
to the outside little more. That will solve the problem.
mai
Mar 21, 2013 | Dodge Caravan Cars & Trucks
The cd drawer won't stay closed
the cd drawer will probably use infra-red to sense when the drawer is open or closed or maybe just a gear mechanism, either way these must be clean, I'd take it apart and lean it all with cotton buds and isopropyl alcohol
Feb 07, 2013 | Audio Players & Recorders
Drawer door won't stay close
Hi Paul Lehto - I understand that the drawer will not close, however may you please provide me the model number so I can assist you better in pinpointing you the information.
Dec 19, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Hatch won't close
you dont say which latch it is but check the part that latches on the stud sticking out. if its closed just pull open handle and manually flip the latch open an should work fine.
Oct 29, 2012 | 2011 Audi Q7
Hood latch won't latch when closing
Raise hood,have some one go pull hood latch and you look at latch and see if it releases,if it doesn't then cable may need replacing,I would'nt completely shut hood cause you may not get back open,also check hood latches bolts and latch for something bent or broken.
Sep 21, 2012 | Chevrolet Silverado 1500 Cars & Trucks
Crosley CR78 CD Shelf System Logo
111 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
