Question about HP Photosmart 3210 Printer
Removing printhead on HP 3210 - HP Photosmart 3210 Printer
  • HP Master
  • 685 Answers
What do you need help with? if you give more info it is easier to help you.
Posted on Apr 20, 2013
HPPhotosmart 3210 AIO hangs us with error code of 0xc05d1281
Hi Minnie,
This could be because of residue on the Printhead electrical contacts
Try the steps below and it should help.
Turn off the Printer.
1. Open the Carriage access door.
2. Remove the Cartridges
4. Move the carriage from left to right 6 times and it should move freely
5. Clean the contacts on the Cartridge with lint free cloth. ( Golden dots )
6. Turn on the printer and it should say " Cartridge missing or need to be reinstalled "
7. Install the Cartridges and close the Carriage door
8. the printer should go through alignment process
If this step does not fix, You may try calling HP customer support to check for better options/solutions
HP Customer Care : 1-800-474-6836
Regards,
Sean
Feb 16, 2013 | HP Photosmart 3210 All-In-One InkJet...
My HP Photosmart 3210 Printer does not Print Red.
WELL IT'S 5 DEC 2012, THIS HP 3210 QUIT MAGENTA'S.
WENT TO TOOLS TO CHECK LEVELS, NO YELLOW, GOT NEW CARTRIDGE, TEST SHOWED NO MAGENTA'S. REMOVED RIGHT SIDE COVER (GENTLY) AND REMOVED ALL TEN CABLES AND REINSERTED CAREFULLY. TESTED AGAIN, AND HAD LINES ONLY ON BOTH LIGHT AND DARK MAGENTA'S,
RAN CLEAN HEADS, SIX TIMES AND ALIGN PRINTER ONCE.
PICTURE GOT BETTER AND BETTER FINAL TEST DIAGNOSTIC PAGE PERFECT ALL SOLIDS. GOOD LUCK KEEP GOING
Jun 08, 2012 | HP Photosmart 3210 Printer
My HP photosmart 3210 skips lines on the black ink only. The other colors print fine.
(The obvious) Replace the black cartridge. Even if ot says you have ink you could have a faulty cartridge, even if it has worked fine in the past. (The not so obvious) Clean your printheads/nozzles. Repeat the process a few times.
Apr 27, 2011 | HP Photosmart 3210 Printer
I get Error 0xc18a0106 what is it please help me!
Generally, this is Hardware Failure Error on HP Printers. You may try few steps before considering it is Hardware Failure.
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If you still get this error,
Remove the Cartridges and Printhead
( Printheads are that hold the cartridge and it has a latch on right side to loose to remove the Printhead, if you dont find a latch, your printer does not has Printhead. Generally, Printers with only 2 cartridges do not have Printheads and any printer beyond this with 4,5 or 6 cartridges have printheads. Sometimes the cartridges are on left side or printer and Printheads inside the printer after you open front access door or you will find cartridges and printhead both inside the printer if you open the front access door )
Clean the contacts ( Electrical or Golden contacts ) using lint free cloth. ( Cloth damped with few drops of water, squeezed properly )
Put the Printhead and Cartridges back and Turn off the printer and turn on.
If you have completed all the steps listed above and are still experiencing a problem, Service the product as it needs repair.
If your printer is In-Warranty, Contact HP Tech support - 1800-474-6838 and they should be able to replace it without charges.
Regards,
Ron,
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 19, 2011 | HP Photosmart 3210 Printer
I get an error message "Ink system has failed",,what is this..I have replaced all cartridges, and still no good it then says carriege jam..nothing seems to be in the way, etc
I can only guess the printhead may be clogged, and you may have two things to try:
1.- Run several (>10) cleaning cycles, hoping it will unclog the prinhthead
2.- Try with brand new cartridges
I don't know if it will work, but ink ages, and it might have dried in the cartridge and clog the printhead. Fortunately, HP builds the printhead into the cartridge, so replacing it is cheaper than with other manufacturers.
OR
  1. ress the On button to turn the all-in-one off.
  2. Unplug the power cord from the back of the all-in-one.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the all-in-one.
  6. Press the On button to turn ON.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
Nov 25, 2009 | HP Photosmart 3210 Printer
Fault 19a0002 ?????????????????,, must be a fault that happens many times with the HP 3210 all in. can somebody help me ?
Are you reporting the correct error. I cannot find it on the HP web site.
I did find an Fault error "0xc19XXXXX". This points to a ink cartridge error.
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
If this does not apply to you, please let me know because there are some other things that might apply
Don
Nov 18, 2009 | HP Photosmart 3210 Printer
ok u neeed to to remove all old drivers all printer driver form add remove then run www.ccleaner.com tool get left junk out then go to hp.com download latest driver for your printer vista or xp need try that 1st thx nick
Oct 07, 2008 | HP Photosmart 3210 All-In-One InkJet...
Ink
did you do a clean and recalibrate?
Jun 21, 2008 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
