How to fix iPod connector on logitech purefi - Audio Players & Recorders
  • 3 Answers
Hi friend:
ifyou buy Ipod, we will have a user manual in the package,
the user manual can teach you how to do
dm800 hd
Posted on Apr 20, 2013
TEAC speakers play iPod quiet
Can i modify my multi pin connector on the back of my sub on my logitech 2.1 system.
Jun 11, 2013 | Audio Players & Recorders
I've lost my manual for Logitech PureFi Express S-0329A. Where can I find instructions?
http://logitech-en-amr.custhelp.com/ci/fattach/get/502116//session/L2F2LzEvc2lkL2dSVDRaaHRr
Apr 27, 2011 | Logitech Purefi Express S-0329a Speaker
I don't know to connect Logitech speaker to my computer.
Plug the green stereo cable to your PC (Green port on PC too)
Connect the black connector (Round shape) to the back of the sub-woofer (big box)
Play music on your PC, should work like a charm...
Hopefully you have already tested the PC to work fine and produce sound. Else you will need to t/s the PC to fix it...
if the PC is probably broken / port is broken - you can connect your iPOD or other music player's green port too - will work just fine!
logitech_r-20_001.jpg?1286435471
Apr 01, 2011 | Logitech R-20 Computer Speakers
Charging
Some Pure-Fi's has a problem charging 2nd Gen Touch iPod, even when proper supplied adapter is used. You can try pressing the iPod further into the connector and see if it stays charging. If not, you can tilt the Touch slightly forward to make proper charging contact with Pure-Fi's iPod connector.
If you only charge your 2nd Gen Touch in your Pure-Fi, or other devices less thick than the Touch, like iPod Nanos, then you can stick a spacer on the Pure-Fi behind the Touch to always properly tilt it slightly forward. Only space it slightly forward just enough to cause it to charge so as not to stress the connector.
Stick-on chair/furniture protectors work good for this. If they are too thin, stick one on top the other till you get the thickness you need. Do not use any thicker a spacer than needed so as not to stress the connector any more than needed to make charging contact Use thinner stick-ons, like double sided foam tape, to get the final spacing you need.
The added advantage to a proper spacing between an iPod and Pure-Fi, is it relieves connector stress when plugging in and using an iPod while plugged in, since the taller Touch iPod cannot tilt backward. If you place your spacer at the very top of the Pure-if back panel, then iPods thicker, but shorter, than the height of your space can also be used.
Hope this helps everyone with this irritating Pure-Fi design problem.
To view the charging/not charging status on the 2nd Gen's screen, turn off the 2nd Gen and the Charging Icon will show when contact is being made.
May 24, 2010 | Logitech Pure-Fi Express Plus...
Malfunctioning connection on ipod ''logitech pure-fi anywhere2''
phoned logitech today who have offered to replace the docking station free of charge as it was under warrenty.Will probably stick with them as a company
thanks for your offer of assistance will bear you in mind for a more complicated problem
Feb 08, 2010 | Logitech 984-000006 Pure-Fi Anywhere...
I have the logitech x-540 5.1 speaker system, do i need an adapter to plug in to my macbook and iPod? so I am able to have hear all 5 speakers together?
Yes, you do, the adapter has 1 green end, which gets plugged into your computer and then the other end has 3 connectors, green, yellow, and black, which then goes into one thick cable. I have the set up right now.
Dec 03, 2009 | Logitech X-540 Multimedia Surround Sound...
Sound does not come out of docking station
It is most likely the 30 pin connector on the Logitech that is the problem. They can break if the incorrect iPod inserts have been used. Try playing someone else's iPod on it, if no go it's busted. Repairs are difficult if not impossible. Sorry
Nov 25, 2009 | Audio Players & Recorders
Does the logitech pure fi express take the new ipod nanos
Hi Jod,
The Logitech pure fi express only support Ipod/Iphone up to 3Generation, please note that Iphone 3GS is not currently supported.
Thanks and have a nice day
J -
Oct 26, 2009 | Logitech Pure-Fi Express Portable Speaker...
Logitech Pure-Fi Anywhere Portable Speakers for Apple iPod . It keeps shutting off after a few minutes. It's plugged into a wall outlet.
Many have reported the same issue, reset the pure-fi with the reset switch (on bottom) while it is turned on, then put your iphone/ipod at 75+ % of volume before/while playing.
Feb 21, 2009 | Logitech Pure-Fi Anywhere Portable...
Battery down but ok with power on MM50.
The battery for the MM50 speaker is VERY hard to find. Logitech does not make a replacement battery for this unit but here is a link to a site that carries it: Replacement NTA2335 Battery for Logitech MM50 iPod Speaker
The battery has a plastic connector which connects to the board so soldering will not be necessary. You just open up the back and switch it out. Easy Peasy!
Jan 08, 2008 | Logitech Inc MM50 Portable Speakers iPod...
29 people viewed this question
 Grubhead
Grubhead
