Question about Garden
What grade of oil should I use in my 8HP MTD snowblower? Tks
    Master:
  • 482 Answers
A snow blower needs a low weight oil because it is operated when temps are low, 0-20w, or 5-20w should be good
Posted on Apr 20, 2013
5 Suggested Answers
  • 81 Answers
SOURCE: mtd pro snow blower runs then die
it sounds to me like either the oil pressure switch is being plugged after startup and causint the engine to quit then the plug settles until you start it again and it plugs again easiest way to test is to take the swith and remove the wire to it and see if the engine starts and keeps running, if so then replace the old pressure switch. If this does not solve the problem then the only other thing I can think of is the needle valve is partially pluged, at startup the fuel bowl is full and the engine startsbut after starting the fuel bowl runs low on fuel as it is not filling fast enough and the engine stalls. By the time you try starting it again the fuel bowl is filled again and the whole thing starts all over. Hope This Helps Don
Posted on Dec 09, 2009
rwvanlue
  • 486 Answers
SOURCE: mtd snow blower,8hp 2 stage, 1995, Problem: oil
The oil leak normaly would make the 'friction disc' inside the frame slip so as to not drive the axle.
Locate the oil leak
#1 engine crankshaft seal
#2 engine crankcase cover gasket
#3 engine overfull so that the excess oil is coming out of the crankcase breather tube and running down inside the frame
Posted on Dec 24, 2009
SOURCE: mtd snowblower yardmachine 3 hp/21"
if you are standing at the handles of the snow blower , kneel down there should be a sticker on the drive cover between the wheels , hope that helps
Posted on Jan 13, 2011
  • 13 Answers
SOURCE: i have a 8hp mastercraft snowblower started reving up and down now wont start
out of gaslow on oildirty, wet or clogged air cleaner
are you getting spark?
Posted on Mar 02, 2012
After it sits for a while the wheels will not turn and are stuck?
Hi William:
Snowblowers tend to get a lot of wet slushy use and if the are put away wet they can easily rust. Try to make sure all the mucky stuff is cleaned off (air hose works great) and spraying penetrating oil or WD-40 generously over all the moving bits except belts never hurts.
Apr 20, 2015 | Mtd Snowthrower Snowblower 5 24" Parts...
MTD Snow Blower will NOT start up!
fuel float stuck --- need carburator repair -- to check it has spark then pull spark plug --- if wet blow off spark plug and check spark on plug then squirt a small fuel out of oil can into plug hole and put plug back in -- if engine fires on first pull carburator needs fixing -- check by squirting fuel in carburator with oil can and see if you can keep it running
Feb 23, 2014 | Garden
My snowblower Yard Machines 26" 8HP started but
Clean the carburetor and check the intake manifold to the head for air leaks/bad gaskets.
Jan 13, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
No problem, just wanted to know if you can still get parts for the Tecumseh 8hp snowblowers. An older model.
yes,depending on the part you can still get parts.some parts they obselete but you can still find them.go to your nearest outdoor power equipment dealer they usally will have the part you need or they can tell you where to find it.
Dec 18, 2010 | Mtd Garden
I have a mtd 26" 8hp snowblower that need aufer
if the bolt broke off then you need to get old part of it out before putting in a new bolt.
Dec 12, 2010 | Mtd Products Yard Machines 158CC Tiller
MTD Snowblower starts good but runs very rough
Carb adjustment. There is usually a HIGH and LOW fuel mixture adjustment on the carb. Sounds like the LOW needs to be adjusted. Do a search on the Internet for a service manual for your particular model/make. Simple job IF you have the manual there for guidance.
Good Luck
Jan 26, 2010 | Mtd Products Yard Machines 158CC Tiller
Mtd snow blower,8hp 2 stage, 1995, Problem: oil leaking on axles, and on casing wear axle come out.wheel stop turning , no gear selection. could you direct me ???
Locate the oil leak
Dec 22, 2009 | Mtd Garden
Craftsman 8hp snowblower starts but will not stay running.craftsman 8hp electric start dual stage modle 536881800 snow thrower
Your snowblower carburator is gummed up. Go to an auto parts store and get a can of a carb. cleaner called seafoam. Follow the directions as far as how much to put into the snowblower gas tank. Run it for a few minutes and it will clear up. Regards, Joe
PS Please rate my answer. Thank you.
Dec 19, 2009 | Garden
Tecumseh 8hp HIGH REVING! snowblower
be careful, if the engine over revs it may just explode. These engines are very picky if over sped and easily blow up.
Your problem may be a broken throttle control rod, have look at that first. If the control rods are fine and in place it could be the fly wheel governor is worn out.
Jan 10, 2009 | Mtd Garden
Electric start not working 8hp.mtd. snowblower
Hi, check the starter if it's engaging too the flywheel. there is plastic molded gear on top of your starter some times gets broken.
If this doesn’t work for you please write back. Thanks,
Nov 21, 2008 | Garden
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
