Question about Vizio VA19LHDTV10T 19 in. LCD TV
T.v. fell 3-4 feet onto carpet and now will not power on.
I have used my multimeter to test the circuits and I think it is the IC - Integrated Circuit EA1530A. I have not worked on t.v.s before or anything other electronics, besides installing car and home stereo. I do not know how to replace the IC or whether it is the only problem. Please help an electronics fixing noob. Here is the readings I got from the multimeter. Main Board# 715T3288-4 Part# CBCBPF82GKZ3 Power Supply Board# 715T2906-4 Part# PWTV8C21ASA1 R907: 167.7 DCV Q901: G-D: 1 Sec of Continuity, G-S: No Continuity, D-S: 1 Sec of Continuity R915: 2.4omhs R910: 166.2 DCV C920: 0.5 DCV IC901 TEA1530A Pins: 1: 0.5 DCV 2: 0 DCV 3: 1.3 DCV 4: 0 DCV 5: 0.1 DCV 6: 0.6 DCV 7: 0-183 all over the place DCV 8:166 DCV IC901 TEA1530A Pins #2 Pin as Ground: 1: 0.5 DCV 3: 1.3 DCV 4: 0 DCV 5: 0.1 DCV 6: 0.7 DCV 7: 0-180 all over the place DCV 8: 166.4 DCV Transformer(Top to Bottom): Left Side(Hot Side): 1: 167.1 DCV 2: 167.2 DCV 3: 167.5 DCV 4: 0 DCV 5: 0 DCV Right Side(Cold Side): 1: 0 DCV 2: 0 DCV 3: 0 DCV 4: 0 DCV 5: 0 DCV Connector: BL - ON/OFF Bright: 0 DCV 5v: 0 5v: 0 12v: 0 12v: 0 Standby: 0-183 DCV Jumped all over the place. Thank you for your time.
    Top Expert:
  • Vizio Master
  • 78,267 Answers
Well time for a new TV.
Posted on Mar 03, 2017
bestdarngood
  • 3037 Answers
SOURCE: VIZIO L37
If anything, try taking it to a tv repair shop and see if they can find something wrong with it by looking at it which I am physically unable to do online. See if they can look at it free and tell them what you have replaced but I don't know what else without looking at it myself. I hope you get it working.
I doubt you can get a free inspection of it but you can try. Possibly let them know how much money you have spent already and maybe they will give a little leeway. Good luck.
Posted on Apr 02, 2008
  • 41 Answers
SOURCE: Vizio 42 in L42HDTV10A no power no lights no nothing
Yeah if you don't have any power at all, no lights or anything its the power supply.
Posted on Oct 08, 2008
  • 718 Answers
SOURCE: Vizio L37hdtv10a fails to fully turn on
You will have to isolate the main board and Inverters.
Unplug the inverters and turn on the set.
If it "turns on" then try re-connecting each inverter seperately to see if only one is causing the problem.
Posted on Mar 07, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a Vizio VW46LFHDTV10A - the problem is the
It can be main board, T-CON, or LCD panel. I would try reseating the ribbon cables between the T-CON and the LCD panel first.Unless you have service manual and scope to look at the signals it will be difficult to be 100% for sure as to which board is bad, the repair guy will more likely to do board swapping, starting with the T-CON board.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you fin
Posted on Oct 29, 2010
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Posted on Feb 07, 2011
Hello? Greeting from Mongolia. I use nokia 200, But camera is not working now. it says operation failed. How can i fox it?
I think the problem was in camera integrated circuit . try to change your camera first. If your problem wasn't solved you can change your camera ic at specific service center
Sep 12, 2012 | Cell Phones
The fuse of Jamo Sub-200 gets blown off. is there anyone who might know the reason. thanks
try replace the blown fuse with ampere and check the sound if still ok.
some fuse got blown if the load current exceed. maybe high volume can cause the high current.
other cause by short circuit coming from the amplifier.
Aug 26, 2011 | Jamo SUB 200 Subwoofer
I have a Pioneer VSX-305 receiver. I blew channel A speaker outputs by allowing speaker wires to touch. Everything else works. Can anyone tell me what it takes to fix this. (I am an electrical engineer...
Without a Sams Photofact or a service manual I would go directly to the Power IC which is the largest Integrated Circuit mounted to a large heat sink. If you see any fuses they are probably for the power supply since any fused circuit on the speaker output would be ineffective because the IC would be damaged before the fuse would blow, but you need to check them anyway. Since the short was at the speaker output your problem should be at the final stage of amplification, which is the Power Amp IC. Prior to the early 70's you would have transistors mounted to a heat sink which could be individually checked and replaced. Then manufactures started to use the Power Amp IC which are more costly but eliminate having to find matched pair transistors. All you can check on the Power Amp IC is if you have an input using an oscilloscope or signal tracer and the power to the IC. If you have an input signal and power to the device with no output, I would replace the IC. Unless you have a test circuit for the IC you cannot test it completely unless you have a device like a Huntron Tracker or build a test circuit using a signal generator and a power supply to measure the gain of the IC with an oscilloscope. Short of ordering a service manual this is a good place to start.
Aug 15, 2011 | Audio Players & Recorders
Oster microwave trips breaker on start
Hi if breaker trips off it means there was short circuit happened within the circuit.Even if you try to replace the fuse with a new one,It wont help because short circuit that happened in the circuit and must be fixed first.It would be better if you let a technician see the oven.IC's or Integrated Circuit has been short circuited and some IC's might have been damage that needs to be replaced.Hope this helps.
Jun 22, 2011 | Microwave Ovens
Sharp LC-60LE810UN. the sound all of a sudden cut out on the tv. everything on the tv seems to be working just fine. but there is no volume at all.
hi,
You have to check three things.
1. Check is the mute function is ON or not. For that press the mute button on the remote.
2. Check the speakers of you tv. For that you have to open the tv. For testing the speaker you need a multimeter. Check the coil continuity of the speaks. it should be 4 ohms or 8 ohms. If there is no continuity then change the speaker with a new one. If the continuity is ok then
3. You have to check the audio output amplifier IC ( integrated circuit). For finding out the audio amplifier ic which one it is, just follow the wire from the speakers. Its other end will ends in the socket near the audio output IC. It will be fitted on a aluminum heat sink (radiator)
To replace the IC you need soldering ion,desoldering pump, solder etc.
the part number will be written on it. you have to purchase the same part with the same part number.
ok
Apr 27, 2011 | Sharp LC60LE810UN 60 in. LCD TV
Dynex 40" lcd tv screen
There's an IC (integrated circuit) that handles pictures on the t.v. and can cause lines and/or discoloration on the screen. At most, having an electronics service provider changing this IC (integrated circuit) will bring back the original quality of the picture.
Mar 18, 2011 | Televison & Video
I would lke to know the reference code on the audio out put ic, used in the VHF MARINE IC-M302.
Quick description as per ICOM Manuals:
Quote
The AF amplifier circuit amplifies the detected signals to drive a speaker. The AF circuit includes an AF mute circuit for the squelch. AF signals from IC1 (pin 9) are applied to the de-emphasis circuit (R61, C89). The de-emphasis circuit is an integrated circuit with frequency characteristic of –6 dB/octave. The integrated signals pass through the high-pass filter (Q5, R62–R67, C90, C91) to suppress unwanted lower noise signals. The filtered signals are applied to the AF mute circuit (IC7B), and then passes through the [VOLUME] control (VR board; R1) via the “VOL1” signal. The signals are applied to the AF power amplifier (IC6, pin 1). The output signal from IC6 (pin4) drives the internal (external) speaker.
Unquote
I thus assume the IC you are looking for is the IC described as IC 6.
Data sheet availible online: http://www.datasheetcatalog.org/datasheet/sanyo/ds_pdf_e/LA4425A.pdf
The IC is a Sanyo LA4425A. A 5W Power amplifier.
Apr 02, 2010 | Icom IC-M302 VHF Marine Radio
The pitch on my Roland Juno-G keeps shifting and the sounds become detuned for no reason.
The main problem with your Roland Juno-G shifting sounds and detune is in the amplifier section. The power I.C(integrated circuit) there have a problem or its defected try to reheat the solder of that I.C(integrated circuit) If nothing happens change that I.C
Jun 13, 2008 | Audio Players & Recorders
TELEVISION
This may indicate a problem with the signal processor IC (Integrated Circuit)or the color burst signal might have insufficient amplitude which would also lead back to the signal processor IC. You will need a schematic to find the IC and you will need a multimeter and an oscilloscope to view the video waveform. If you do not have a background in electronics do not attempt this repair on your own please take the set to a qualified repair shop. The loss of color points to the loss of the color burst signal or the failure of the video circuitry to respond to the color burst signal.
Sep 20, 2007 | Televison & Video
No sound through speakers, but ok through headset
u have a problem either on the speaker or on the sound amplifying circuit. signal coming from the earphone jack is not amplified. check the speaker first. if its ok then check the audio output ic(integrated circuit). good luck!
Jan 31, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Vizio VA19LHDTV10T 19 in. LCD TV Logo
60 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
