Question about Blue Microphones Snowball Professional Microphone
My blue snowball USB mic stop working after few seconds
I got it today, and I try it, work nicely. Then suddenly it stop working, the red light still lights up. I thought it was my computer fault, so i restart. It still doesn't work. I wonder if it is broken.
5 Suggested Answers
  • 1121 Answers
SOURCE: brand new blue snowball mic input level is very
try use a dedicated pre-amplif on your mic, and connect to your normal set.
Posted on Dec 22, 2009
SOURCE: I've got a new Blue
I had the same problem with my PC and went to http://www.asio4all.com/ where I downloaded and installed the driver and it worked!! I found the site by reading this FAQ (see below) at Blue under Snowball.
(But I still have the same problem with my MAC).
"If you should experience any problems getting the program to recognize the mic, Adobe recommends the following: If the device does not allow you to record, then your microphone is not being detected as a valid input device in Premiere Elements. You can use an open source program called ASIO4ALL, which is a device driver that essentially wraps existing WDM devices, like USB microphones, as ASIO-compatible sound devices. Use the following steps to utilize this tool:
  1. Quit Premiere Elements.
  2. Visit the following web page and download the latest available version of ASIO4ALL: http://www.asio4all.com/
  3. Install the software, and restart the system if asked to do so by the installer.
  4. Make certain that your microphone is plugged in.
  5. Launch Premiere Elements. Go to the 'Edit->Preferences..>Audio Hardware' menu option. For the Default Device, choose the ASIO4ALL option. Click the ASIO Settings button, then select your microphone from the list of devices, click Exit, and then click OK on the Preferences dialog. Close and then restart Premiere Elements."
Posted on Dec 29, 2010
SOURCE: when i plug in my
There could be a few possibilities, they are:
* Your driver is corrupt, not recognizable or compatible
* Your hardware or device malfunction
Assuming that your device is in good condition and your driver is compatible with Windows. What's next? try the following solutions:
Method 1 - Unplug your USB device, restart your computer wait for 5 minutes, plug in your USB device again. This enables your motherboard to clear all of its cache.
Method 2 - Uninstall and Reinstall your driver
Method 3 - Use the Device Manager to scan for new and recently installed hardware.
Go to 'Start' -> 'Run' -> Type 'devmgmt.msc' (step 2) and then click 'Ok'.
Select 'Action' Menu, click 'scan for hardware changes'. Windows will perform a quick registry scan for any new hardware changes. IF it still doesn't work, try this:
* Test the hardware on another computer, if it works, then it could be your Windows. If it doesn't, try it on another different computer. If the USB device does not work again, it could be hardware malfunction. See your dealer if it is a new purchase.
* Obtain the latest service pack for Windows XP, it could be a bug.
* Shut down your computer and unplug your computer from the power supply, allow the motherboard to clear its cache and memory, restart and plug in your USB.
Posted on Feb 12, 2011
criss_michae
  • 63 Answers
SOURCE: Blue Mic Snowball "not recognized
The serial number should be on the box. If you don't have the box, it will be located somewhere on the circuit board inside the mic.
Hope that helps!
I want to use more than one microphone for a teleconference
Buy a USB mixer that would plug into the Mac, then plug the Snowball into the mixer. Make sure before you buy the mixer that it will have USB inputs for the Snowball, as most use professional XLR's. The output of a USB based mic like a Snowball is very minute to start with, as USB just does not put out the voltage.
Nov 15, 2017 | Blue Microphones Snowball Professional...
My Blue snowball mic does not wokk. I am on os x 10.6.7
Go into your MACs system prefs, 2nd line -> sound and set your prefs for external mic input...
Mar 26, 2011 | Blue Microphones Snowball Professional...
Hope that helps!
Feb 11, 2011 | Blue Microphones Snowball Professional...
I got a blue snowball microphone and had 2 problems. On XP, I can get it recognized and record stuff (I use Acid Pro) but while I am recording (with headphones) I dont hear anything in the head phones....
Thanks for purchasing the Snowball! The problem doesn't look directly related to the mic (as it's purely USB) and monitoring is dependent on the capabilities of the recording software being used. For direct monitoring, we recommend GarageBand and Audacity.
Hillary, Blue Microphones
Mar 24, 2010 | Blue Microphones Snowball Professional...
Mitsubishi tv model wd-62531 less than 2 years old
It sounds to me like your bulb has burned out. Look behind your TV for where the bulb housing is and pull the bulb out to check if it's burned out or not. You'll know when you look at it if it's toast.
Dec 10, 2008 | Mitsubishi WD-62531 Projection Television
Plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Nov 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Blue Microphones Snowball  Professional Microphone Logo
175 people viewed this question
Top Blue Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Are you a Blue Audio Player and Recorder Expert? Answer questions, earn points and help others
