Question about Frigidaire FGHD2433K 24 in Builtin Dishwasher
ER clean S code- fridgidare dishwasher
Fridgidaire dishwashe model PLD4375RFC3 shows ER clean S code Lights flash, won't work
  • 4 Answers
SOURCE: fridgidaire dishwasher
POWER FAILURE
Posted on Jul 10, 2008
  • 93 Answers
SOURCE: I have this code error
That will be a main control board. Also if you have a touch pad replace that also. If its more than three years do not repair but replace.
Posted on Jul 24, 2008
SOURCE: our 6 month old frigidaire
My unit has the same problem and it is due to a failure of the control board. The tech that came to look at it tells me that this unit vents from the top of the tub rather than from the front, and he claims that the installation instructions require a 1" gap between the top of the tub and the countertop.
Now I have found no such information in the installation manual that I downloaded, and I am skeptical that a 1" gap could be done, and if it could it wouldn't look to good.
I am going to pull my unit out and see exactly where the vent fan is and what the clearance is. The service tech says they can't replace the control panel until the installation is proper. I am thinking this is at least to some extent a design flaw with this machine. There seem to be a lot of reports of this failure.
Posted on Apr 08, 2009
SOURCE: Hi, my frigidaire pld4375rfc3 stopped working. I
Next time DON'T buy a Frigidaire product. It is absolute GARBAGE!!! How does a durable good (an item that is supposed to last for at least 5 years) break down w/in the first 1 or 2 years??? Only poor quality items do that.
Posted on Feb 22, 2011
heatman101
  • 43501 Answers
SOURCE: My frigidaire dishwasher is blinking lights and a
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Posted on Mar 07, 2011
How do I find out the error codes?
Good Afternoon Delia Collins, thank you for your post!
Based off the information you have provided your Frigidaire dishwasher is flashing an "ER" error code on the panel. Typically, the "ER" stands for an error code sometimes to help clear out a false error code you can perform a reset on your dishwasher. In order to do that you would need to disconnect power from your dishwasher for approximately ten minutes.
If you continue to experience an issue with the error code I would recommend contacting a technician for proper repairs. The technician will be able to properly diagnosis your dishwasher and this will help you to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Nov 05, 2014 | Frigidaire Dishwashers
On my fridgidaire dishwasher. The code ER comes on and it won't finish a load of dishes. Is there anyway I can reset it
You need to research the code along with the model at Frigidaire website.....if you cant find the answer you should contact the Frigidaire tech support people.
Oct 25, 2014 | Dishwashers
ALL LIGHTS FLASHING ER S
push cancel if that doesn't work cut the power to it for about an hour
Apr 28, 2014 | Whirlpool 24 in. DU1148XTP Built-in...
Why won't my Kenmore dishwasher display work properly?
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Dishlex dishwasher won't complete a cycle. Number 60 shows up and a small flashing line. ??????
Drain pump is blocked. .If you are good with tools you can clean it yourself. Let me know
Mar 28, 2013 | Dishwashers
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
ER code, flashing touch pad selections.
It is most likely a fault with the keypad mebrane on the dishwasher control panel. Need model number of dishwasher to make a more detailed conclusion.
Jan 04, 2013 | Frigidaire Dishwashers
The touchpad has gone bad. common problem with most of the electronic dish washers out on the market today. Replace the touchpad console and you should be good to go.
May 31, 2010 | Frigidaire Dishwashers
THe Dishwasher just keeps Washing And Rinesing
Turned Fridgidaire washer on last night before going to bed; this morning, it's running (at least making sounds) but did not wash; 4000 Series Frigidaire; display says Washing Drying Er Clean S; and two lights are flashing - Ultimate Scrub and Rinse only.
I tried turning off the breaker and restarting the machine but that doesn't work.
Sep 05, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire FGHD2433K 24 in Builtin Dishwasher Logo
35 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
