Question about Electrical Supplies
How to replace light fixture in home - Electrical Supplies
  • 23 Answers
Do you want to replace the light fitting with the same type or something different ? If different what type are we looking at?
Posted on Apr 20, 2013
How to change bulb thats a t8 fluresent fixture in a home
A Lot of the T8 style have very little room to move the tubes around, check a few things:
See if you need to remove the tubes in a specific order,
See if the ends of the fixture are removable,
Instead of dropping both ends of the tube drop one side first,
Sometimes after the tube has been twisted and dropped slightly you may have to maneuver the pins to avoid the fixture.
Dec 11, 2012 | Philips 6996C FKD 230V 1000W Lighting
Home Improvement Fixtures?
It seems that you are looking forward to hire Home Improvement fixture. Well, I would like to help you in this and I suggest you that hire this Home Improvement company for getting best services & good ideas for your home. Home Improvement
Jun 11, 2012 | Kichler Lighting Dryers
Replace GE 50W Halogen bulb in ceiling fixture
if fixture is as shown, remove the nut in the middle of the fixture, remove the lamp, and replace it, note donot touch the lamp with your fingers, this causes lamp to fail, use a cloth to install then replace in reverse as you took it apart
Sep 27, 2011 | Universal Lighting and Decor White 11"...
Own a #182155 secure home SH-5105-WH-B light stays on all the time.testing it in a dark room with door closed,light can be seen under door,never goes out.any help you can offer would be great!
Switch the Dual Timer selector to OFF.
Wait 1.5 minutes for fixture to recalibrate.
Then check fixture again.
http://heath-zenith.hcents.com/data/manuals/598-1152-05.pdf
Aug 04, 2011 | Heath Zenith Secure Home Motion Activated...
Fluorescent lights will not come on. There is power to the ballest.
Power to the ballast is good. The power you checked is known as the primary power. The secondary power from the ballast (transformer), should be around 600 volts. This 600 volts is what vaporizes the gas in the fluorescent lamp. Go to home depot and buy a magnetic field tester (we call it a thumper) It has a shirt pocket clip on it. Do not insert the thumper in the fixture lamp sockets, just put it in front of one of the light fixture sockets. It should beep and the light on the magnetic field tester (thumper) should come on if you have a magnetic field in the light fixture socket. This means that the light fixture ballast secondary is working. No beep and no light from the magnetic field tester (thumper) means your ballast is bad. Ballast are dangerous to replace. Have an electrician replace it. Your life is not worth losing over saving a few dollars.
Jan 06, 2011 | Lithonia Lighting White Finish 48" Wide...
We have fluorescent cove lights in the living room. We think the "starter" is bad, but we can't locate the "starter". Can you help? We have tried switching the working light bulbs...
Very few flourescent lights have "starters" these days. If it does have a starter, it will be a visible cylindrical object usually located at either end of the fixture. More likely it's the ballast that is bad. Turn off the power and remove the cover to the fixture. The ballast will have a lot of wires coming out ot it. Take note as to where all the wires are attached, remove it, and take it to a hardware store or Lowes or Home Depot to get a replacement. Make sure it is an _exact_ replacement. Sometimes it's easier and cheaper just to replace the entire fixture as some of the older ballasts are expensive due to there being replaced by newer technology.
Dec 10, 2010 | Sli Lighting 48" Fluorescent Bulbs 34...
How do you take the light fixture apart to fix the balace?
You may find that a new fixture is the easier and cheaper way to go as some ballast can be expensive and hard to find the matching style. A similar style fixture at Home Depot or Lowes cost, in a 2 pack about $18.00. Add a CF bulb to it for another $4.00 and you have a decorative similar fixture. Some ballast cost anywhere from $9.00-$50.00. If you wish to replace the ballast: (turn off the power) remove the globe, remove the existing florescent bulb, take the fixture off the ceiling (usually two screws) remove the wire nuts, make a small diagram of the existing wires and the color codes, take the ballast to the Home Depot or Lowes first, match the ballast. Now reverse the process to replace the fixture. Hope this helps. Good Luck!
Douglas
Oct 31, 2010 | Universal Lighting and Decor White...
No clips to hold globe on ceiling fan
You best resolution now may be to replace the light kit with one available at Home Depot ..
Jun 07, 2009 | Hampton Bay 52 In. White Redington...
Rotary dimmer control for 5 light chandelier stops dimming
Whoa...You definitely may have a fire and/or shock hazard hanging from your ceiling. I've seen a lot of fixtures with old, brittle wire and bad insulation in them. Lamp wiring is subjected to a lot of heat, especially with higher-wattage fixtures. Long term exposure to heat near or above the insulation's rating is especially damaging to electrical insulation. I've also seen cases where metal parts of the bulb socket partially melted and/or broke loose.
If you're comfortable and confident of your abilities to make a safe electrical connection, you can replace the wire and bulb sockets in your fixture. If it's valuable or an attractive antique, it's worth fixing or having fixed, even if you sell it. Just make sure you use wire with insulation rated for use in an electrical fixture. It must be rated for a temperature no less than 105 degrees Celsius.
It it's a lower cost fixture, replace it or have it replaced. Regardless of what you do, you're probably going to be replacing that dimmer again...sorry.
If you live in an older home, it may be worth (in terms of safety) having a few qualified electricians evaluate your electrical system as a whole to make sure everything is still in safe condition.
May 04, 2009 | Rotary Lot 10 Leviton Ivory Light Dimmer...
Ceilng Fan light fixture-metal clasps have broken off
For Hampton Bay ceiling fan replacement parts!!!
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Electrical Supplies Logo
101 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
