Question about General Electric Washing Machines
Where is the inlet water filter on a washing machine
Is there a water filter i
    New Friend:
The inlet valve is usually connected inside the machine and connected directly from the water source.
Posted on Apr 20, 2013
yalmer
  • 552 Answers
SOURCE: My siemens XL 1600 washing
If it is out of balance this can occur.
Try leveling and then make sure the load is not lop sided.
Posted on May 27, 2008
  • 5 Answers
SOURCE: cloged inlet filter
You can also buy new filters to replace the old inlet filters from Home Depot. They are not LG brand they are "generic" filters but they do work. LG does not supply these filters the only way to get them from LG is to purchase the entire inlet valve (keep in mind you have 2 hot and cold) to obtain these filters. You can call the parts dept 888-393-6484 and get the part numbers for these valves and a distributors phone number so you can purchase the valves from them. Hope this helps.
Posted on Jun 06, 2008
Mark Harmer
  • 8 Answers
SOURCE: Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Posted on Sep 21, 2009
  • 380 Answers
SOURCE: Samsung washing machine gives Low Water pressure
You get these messages turned off by fixing the problem.
Low water pressure is basically one of the valves is not letting water pass through.
1. Do as you already did and clean the inlet filters. Any kinked hoses?
2. Adjust the water pressure in the house. Is it too high or too low?
3. Replace the valves in the unit.
4. Main board.
Posted on Dec 30, 2009
odiebugs
  • 949 Answers
SOURCE: the check inlet light flashes. I have cleaned the
If your sure the water way is clear, unplug the unit, plug it back in,
and see if the error is gone, if not, place the water lines into the tub and turn on the water to make sure water is coming into unit, if so the problem lies somewhere else.
Re-post if this didn't help, and say you did this but still have the error.
Good luck, hope it helps.
Posted on Feb 05, 2010
I have a LG Fuzzy Logic WF-T5001PP washing mashine. It is taking longer for the water to enter. Does it have a water inlet filter that I can clean?
HI... If u see your backside of your machine there is a inlet valve (water inlet valve) open that water tube and see one small netted filter is there you just remove that filter outside and clear that filter with a tooth brush and insert it again....
Jan 15, 2017 | LG Washing Machines
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
My ultima1000, wm 71 says error 10 sometimes and error 11 mid way thru a cycle. The pipes are fine and water is on what could be the problem?
E10 No cold fill detected - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
E11 Not hot fill detected - washing machine does not fill
  • Wiring fault
Apr 11, 2016 | Washing Machines
How do i get my filter out of my bush a127ldw washing machine got E03 error am working my way through your list but cant get filter out
Water inlet filters
On the tap part of your machine's water inlet
hose and at the ends of water inlet valves, there
are filters to prevent entrance of the dirt and
foreign materials in the water to the machine. If
the machine is unable to receive sufficient water
although your water tap is fully opened, these
filters should be cleaned.
x Remove the water inlet hose.
x Remove the filters found on the water inlet
valves by using a pincer and wash thoroughly
with a brush. (1)
x Clean the filters of the water inlet hoses
located on the tap side by removing manually
together with the seal. (2)
x After you clean the filters, you can fit them
the same way as you have removed them.
Pump filter
The pump filter system elongates the life of your
pump, which is used to drain the dirty water. It
prevents lint to enter the pump. Cleaning of your
pump filter in every 2-3 months is
recommended. To clean your pump filter:
x Open the kickplate's cover, by pulling the
handle. (2-A & 3-A)
x Before opening the filter cover,place a cup in
front of the filter cover to prevent flow of the
remaining water in the machine.
x Loosen the filter cover by rotating it counter
clockwise and drain the water. (4-A)
x Remove the foreign materials from the filter.
x Check for the rotation of the pump manually.
x After you have cleaned the pump, fit the filter
cover by rotating clockwise.
x Put the kickplate cover into place.
x Do not forget that if you do not fit in the filter
cover properly, it will leak water.
Jan 21, 2013 | Washing Machines
Washing machine not filling
really sounds like the inlet servos arent working there and might need of replacement
May 06, 2017 | Washing Machines
THE SCREEN SHOWS IE
Hello there and thank you for choosing fixya
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
And finely if all of this does not work then the inlet valve on the machine needs to be replaced ok?
Hope this all helps
Aug 05, 2011 | LG WM1814CW Front Load Washer
I have a LG direct drive wahing machine and its flashing IE cant find manual what does it mean please help!
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. Check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. If clogged, water will not flow through these filters into the washer. Disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg If this doesn't work then you will need to change the water inlet valve by removing the top panel.
Mar 15, 2011 | LG Washing Machines
The machine is indicating an IE fault
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly wm_inlet_filter_removal(1).jpg
Mar 02, 2011 | LG WD-1280FHD Front Load Washer
Kenmore elite calipso wash motion
your inlet filter is most likely plugged.
take of your hoses from the machine and clear the filters in the machine inlet ports.
If this does not help your inlet valves are broken.
But most likely the filters is the good bet
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
111 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
