Question about Dell Dimension 1100 PC Desktop
Not recognise memory for windows XP.
Hi ive got an emachine 4260 i have put more memory in it and its not recogniseing it what do i need to do it is the right memory i got i was upgrading it to a 1GB for a pc3200 plz could you help Thanks Joanne.
  • Shadow1989 May 11, 2010
    according to my memory configurator program, it accept pc2700 or less.  try using just that stick by itself and see what happens.
    Genius:
  • 1,605 Answers
The 4260 takes PC2700 DDR. not PC3200, also the 4260 take only memories with special chip buildin for that particular motherboard.
Posted on Mar 11, 2009
Hi, ive got the N900 whenever i try to take a picture, a message comes up saying 'memory not accessible. unable to save content. ? everything else works fine. please help. thankyou
this is either because your in-built 32gb memory is damaged or your memory card is corrupted or not recognised by your device.here are the steps to take
1.back-up whatever you have on the memory card like songs and videos.
2.use your phone to format the memory card so as to enable the phone put in its recognised folders.
3.finally restore your music and videos and try again, it should work. but if you dont want to do these, you can easily go under camera settings and change the default save location, say from mass memory to memoru card and vice-versa.hope this helped you?
Nov 07, 2010 | Nokia N900 Smartphone
Can i install windows XP over windows 7?i got a laptop emachines and with it came windows 7 i hate it! i want window xp. can i install xp and it deletes or overrides the window7? or do i have to have...
You can but its not straight forward, your laptop probably came with a SATA connection for your hard drive, XP doesn't recognise this. It doesn't have the correct drivers.
You'll have to build a special installation disc, using a free programme called NLITE, download from Filehippo.com.
You then have to get a copy of XP, with licence, also download all the drivers you need. If you can't get them from emachines you'll have to google for them.
Do the research, build the disk, then before you install. Make sure you've copied all the data from your laptop so you can reinstall win7 if the XP-eriment goes wrong.
Jul 21, 2010 | eMachines eMD620-5133 Notebook
Notebook compter not recognising my mp4 player
Maybe you need to install some driver, check if your product came with a CD driver or search for the web site of the product. You need to post more information about this mp4 player to help us to help you.
Feb 26, 2010 | Microsoft Windows XP Professional
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
Emachine cant find operating system
If it doesn't show a HD in bios, that means that either the HD isn't connected properly ie you have 2 devices set as slave or master on same ide cable and it cant detect the HD. Try temporarily disconnecting the CDroms or other devices that may be conflicting and see if that helps.
Hope that helps. Please remember to rate this information.
Thanks
May 03, 2009 | Computers & Internet
Emachine T1100 Emachine window then no system window
It sounds like the hard drive has been wiped or is dead or not connected. Check the power and control cables to the hard drive. Check drive with a maintenance diskette or CD. Replace drive if bad. If wiped or replaced, you need to re-install an operating system, such as MS Windows-XP, or Ubuntu (a free, downloadable, Debian GNU/Linux based operating system with a Windows-like user interface).
Jan 28, 2009 | E-Machines T1100 PC Desktop
My DVD burner is not recognising blank DVD
i had that problem and turned out ot be defective drive. if u cant boot a known good cd like memtest.org (extract them burn .iso image with imgburn.com)
Jun 16, 2008 | Pioneer DVR-110D DVD RW Dual Layer Burner
HELP!!!
What OS do you have?
May 19, 2008 | Apple iPod nano
USB problem
i think u must upgrade the USB driver on ur pc go to this link and download the driver and save it in desktop and double click on it and install it
http://usb-1394-firewire.free-driver-download.com/SIIG/31991/SIIG-USB-2.0-Controller-Driver-v0.216-Windows-98SE-ME-2000-XP.html
rate me solved if its help thx
Oct 30, 2007 | 2wire 1000-200004-000 Network Adapter
Dell Dimension 1100 PC Desktop Logo
81 people viewed this question
Alun Cox
