Question about Motorola Mobility RAZR V3
How do i find my ip address on my phone - Motorola Mobility RAZR V3
How to get my ip address in my to use my wifi?
Hi once you connect wifi in your phone immediately an ip address will assigned for you by your ISP provider ....If you want to know your network ip address then visit sites like Ip-Details.com in your phone .Here they will display informations like ip location ,ISP address ,country and so on .
Jan 12, 2014 | Sony Ericsson Walkman E16i W8 Orange...
3com 3102 not working
try 192.168.2.1 / 192.168.2.0 / 192.168.0.1
hope it works.
enjoy
Feb 15, 2008 | 3Com NBX 3102 IP Phone
IP ADDRESS
If you need to find the ip address of your phone then connect internet to your phone.And then open IP-Details.com here it display the ip address of your phone.
Aug 01, 2013 | Samsung GT S3850 Corby II
Setting static ip address
Do you want to connect your Nokia phone with static ip address you have?You can check the details in user manual or you can search instructions in online.It differ from phone to phone.But you need to wifi modem to connect your ip address to Nokia phone.For home connection ISP provides static ip address.You can use only that.But mobile phone network providers won't give static ip for phone connection.To check ip address you can visit the site Ip-details.com
Jul 24, 2013 | Nokia Cell Phones
I've powered my 9620 off/on, moved the phone to a different desk. I keep getting DHCP Conflict and the phone keeps rebooting. I am not able to CRAFT... does not work on this phone at this point.
Someone configured a static IP on your network. The DHCP server thinks that IP is free and keeps handing it out to you. You can either trace the equipment (workstation or phone) that has that IP or you can go into the CRAFT menu and assign a static to the equipment (please check with your network or system administrator to see what IP you can assign to your phone. Also talk to your network admin if you are using VLANs)
To get into the craft menu and change the ip address settings
1. during the startup of the phone press the * key when you see "* to Program" during initialization
2. enter 27238#
3. navigate to the ADDR menu
4. change the ip address, call server ip, subnet, router to the correct ip addresses
5. if needed change the http, https, or file server address
6. restart phone
Mar 08, 2011 | Avaya 9620 IP Phone
How do i manually configure and ip address for the mitel 5224 ip phone?
Press and hold the up arrow.
Configure Phone - Yes
network parameters - yes
press no until you see "change" and press yes.
You will need to set the following appropriately.
IP address, Subnet address, default gateway, ICP controller address, TFTP address, VLAN ID, VLAN priority, DiffServe Value, DNS address.
Normally it is not necessary to set the phone static except for testing. If your network and DHCP server is set up properly, you are not gaining any benefit for setting it static.
Also, you should find out what the other IP addressess are that are static on the Voice subnet. Along with that, you will need to know the DHCP range. These are needed so you don't assign a duplicate IP address to your network. Assign the phone to the wrong device could do great harm to your network. Assign it to use the same IP address as the phone system and none of your phones will operate.
Use with caution,
Mark
Feb 10, 2011 | Mitel 5224 IP Phone
IP address
your voip enabled phone uses dynamic ip addressing so doesn't have a fixed ip. however if you want to configure the phone Connect the WAN port of the SPA922 to your network (router, switch or hub). Make sure that you have a DHCP server so that the SPA922 will get the IP address.
To login to web based administration follow the steps
Access the web based setup page of the SPA922. Verify the IP address through the LCD. Click Menu then press 9. It should show you the DHCP IP address. Open a browser and type that in the Address bar.
Click Admin Login .
Note: The SPA922 does not have a username and password by default. If you are asked for a username and password and you have not configured a password, it means that the SPA921 is locked by your VoIP provider. You need to obtain the password from your VoIP provider.
if this helps resolve your issue please vote for me. thank for using fixya.
Aug 10, 2009 | Linksys SPA922 IP Phone
Avaya assighning New static IP address after IP address conflict
The phone is looking for the calsrv ip address, which it cant see. So it is trying to "Dsicover" it.
Go to another phone and press "mute"ADDR#
You can then see the ip address information and input it into the phone that is incorrect.
Mar 04, 2009 | Avaya 5610 IP Phone
How to configure Avaya's IP Phone 5610?
What IP did you give the phone? When it says discover, its looking for the call server, which it is not finding.
Which system is this on? If IP office, you may need to build an IP route in the system for that subnet.
Feb 13, 2009 | Avaya 5610 IP Phone
Cisco 7960G IP Phone Problem
Try to manually reset the phone - **#"Settings" (this will unlock the configuration) + Network + menu under number "33" - erase the configuration. Then the phone configuration will be erased. Also you can manually set IP address and TFTP server
Sep 11, 2007 | Cisco 7940G IP Phone
Motorola Mobility RAZR V3 Logo
27 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
