Question about Kenmore 21.7 cu. ft. Side-by-Side Refrigerator with Thru-the-Door Ice & Water with Water Filtration 4659267
Will front dial rotate if water not entering tray on Whirlpool ED22DQ/RQ icemaker?
  • Kenmore Master
  • 4,654 Answers
Please don't rotate that dial it can damage the ice maker. This sounds like the dual water control valve on the back of refrigerator most times. Part 2002182 Water Inlet Valve
Will front dial rotate if water not entering tray  - b297db30-bf49-4543-8f75-0ad266e36c1e.jpg
Parts manual => ED22DQ I will be here should you have questions, Thanks Sea Breeze
Posted on Apr 20, 2013
5 Suggested Answers
  • 718 Answers
SOURCE: Ice maker for Kenmore model 532343 not working
Does your water have minerals?
Faulty Water Valve
Your ice maker is designed to fill with water for 6 to 8 seconds. Check to see that the ice maker is not sending power to the water inlet valve for a period longer than what you unit is designed for. Does your water have minerals?
Also check to see if the water inlet valve is closing too slowly. The power to the valve is being shut off in the correct amount of time, but due to wear and tear in the valve, it is closing too slow.
Check the timing on the value. Put a volt meter across the leads of the water inlet valve. Set the voltage range to cover the 120v voltage. Cycle the ice maker and watch the meter. When the ice maker begins to fill with water the meter will read voltage coming from the ice maker. Time the difference between when the voltage is cut from the valve and when the water quits filling the ice maker.
If the water shuts off immediately when the voltage is removed, the valve is probably good. Since it was off 10 days the particle build-up on the valve may be the problem since it could solidify. You could try working the valve back and forth or replace it.
If the valve closed quickly then the problem is the valve was opened too long.
If that is the case then you have an ice maker control problem. In that case see if the timing can be adjusted.
Posted on Mar 24, 2009
  • 531 Answers
SOURCE: icemaker will not drop ice.
icemaker problem
Posted on Apr 07, 2009
FixinFax
  • 3085 Answers
SOURCE: water doesn't enter ice maker tray
You probaby just have an air lock somewhere. Trace the tube to where it taps into the water pipe. Remove the hose and blow thru it.
Posted on Feb 11, 2010
jharper501
  • 139 Answers
SOURCE: ice maker maker not calling for water. changed
the fill line is frozen in the freezer .remove ice maker fill line is located behind maker use a hair drier to thaw.. could be ice maker too it controls the water valve.
Posted on Aug 24, 2010
Is the water volume adjustable in my icemaker?
It maybe pressure related and not a volume of water problem. You could try to go and turn down the tap at the point the water line is attached to the feed pipe for the line to the ice maker they only need to be open a little say one turn to feed the unit.
May 30, 2015 | Kenmore Refrigerators
I have a whirpool frdg. and the water line connection to the pump has corroded. Its model says ED22DQ-RQ but everywhere i look on line there is no such model. I need to find the part that is the male and...
Here ya go,this is a link to look up parts http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-ED22DQXEB04/1198/0165000?searchedModel=ED22DQ&blt=11
This is one of 50 models that start with ED22DQ look on the ceiling or the left side wall of the fresh food compartment to find your exact model and enter it in the box on this site
Good luck, i hope this helps
Gene
Aug 01, 2011 | Whirlpool Refrigerators
I have a Whirlpool refrigerator with an ice maker and when the icemaker is filling with water it leaks from the front of the tray into the ice storage bin.
1. icemaker is not level. (check and re-level)
2. icemaker has a crack in the mold.(replace i/m)
3. Water level set too high.(remove front cover and adjust water level screw counterclockwise)
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Model ed22dqxaw10 - water enters the ice maker
If the water enters as if it were on a timed basis it would be clear that your ice maker either needs rebuilt or replaced. All signals are sent to the water control valve from the ice maker. The ice maker if working properly will begin its cycle when the thermostat tells the icemaker to begin by heating the elements below the ice maker to warm slightly to loosen the ice from their ice slots. After that any confusion would be in the front of the ice maker to tell the water to come on before the ice maker emptys its ice and begins a 7 second refill of water. If you would like to rebuild your ice maker click HERE and enter your model number ED22DQXAW10 then click on photo 11 ice maker on left of screen. If you would prefer a Replacement Icemaker Click Here=> P/N: 4317943 Try disconnecting the ice maker side of your dual water dispenser to insure that it is not the problem. Dual water control valve part number Click Here=> P/N: 2188542 Like to know if the problem has been located and resolved or if you would like to continue with my assistance contact => Sea Breeze just above the Fixya Tech Support Box on right. Or try http://seabreeze.fixya.com that is having problems because of server overload. appliancepartsse@yahoo.com Thanks, Sea Breeze
Oct 26, 2009 | Whirlpool Refrigerators
Ice maker arm will not rotate all the way around to dump ice dial has arc marks just past the copper plate can lightly touch the rotating arm and it will dump ice and refill water and freeze but then it...
Sorry to say but you will be better off buying a new icemaker kit than trying to repair this one. He is a tip. I have bought icemaker kits for $40-50 in Lowes. Search online too.
Aug 24, 2009 | Whirlpool Refrigerators
Icemaker does not fill with water
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to check the wiring to icemaker solenoid.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 11, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Icemaker not producing ice
you need to troubleshoot the problem, if the wire arm that tells the ice maker to stop making ice when full is in the upright position the ice maker will not make ice. the problem has to be either the switch on this arm malfunction. but probably in MOST cases it is your electronic water valve which has gone out. this is located on the water supply line on the back of the fridge at the bottom probably behind some cardboard or plastic. it is the same kind of water valve as a dishwasher uses, if it malfunctions it will not deliver water to your tray, manually fill the tray and put the arm down, if the maker dispenses the ice out of the tray, chances are your electronic valve is broken.
Apr 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Ice Maker Won't release ice
Jetguy77,
I have a 1993 year (16 years old now) Whirlpool side-by-side with icemaker, Model ED22PW. I have had similar problems with the icemaker - water goes in, freezes, but ice does not eject from tray. It has happened to this unit 2 times since 1993. It turns out the problem is not the thermostat. It is the icemaker motor module. The icemaker has a small synchronous (clock) motor that rotates the ice ejector. When it goes bad, the ejector does not rotate, either because the module timer had failed or the motor itself has failed. The solution is to go to your nearest applinace parts dealer and by a new "icemaker motor module" for Whirlpool Model (your model here). Mine cost $58.85 the last time I replaced it in 2006. To install the new module, you will need to remove the icemaker from the refrigerator. Mine has 3 screws that attach it to the side. Also unplug the power & control cable. The water tube slides out when you pull the unit forward. When you get it out, it is then easy to remove the motor module and insert the new one. You may have to reset the timer on the module to get the tray to fill completely.
Jan 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Refrigerator Model ED25PW Ice maker tray not filling with water
Just had this issue - after checking all line connections, I pulled the ice maker feed water line from the back of the unit and found the tube was blocked with ice. Melted the ice with some hot water, and all is good once more. I would check for this before getting into the solinoid.
Aug 27, 2008 | Refrigerators
Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Nov 07, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
81 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
