Question about Kohler Plumbing
Need To Change Valve on Waterhaven shower system Model K499-SS
How to remove top panel to get to valve
dragonsthatk
  • 547 Answers
SOURCE: Shower handle will not shut off the valve...constant drip
little cover cap on center handle screw inside
Posted on Feb 21, 2009
dragonsthatk
  • 547 Answers
SOURCE: single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Posted on Feb 23, 2009
  • 297 Answers
SOURCE: Speakman shower faucet washer replacement
there may be two nuts,one for the stem and one for the stem barrel.if not then the stem does just screw out,may just have a build up of something on it,try and working it back and forth to try and break it loose,careful not to damage anything.
Posted on Jul 29, 2009
odiebugs
  • 949 Answers
SOURCE: how to adjust anti scald valve on american standard shower faucet
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
Posted on Feb 10, 2010
Testimonial: "Thanks for the info! It turns out that our faucet was so old it had black plastic piece that had to be popped out and re-positioned!"
  • 127 Answers
SOURCE: I am installing the valve housing for a moen
No...the (cotter pin) is a retaining piece for the cartridge. If you remove it the cartridge can blow out under pressure.
Posted on Apr 11, 2010
Testimonial: "thanks for the help..."
The grey cartridge (diverter valve) of my shower is discontinued. The whole copper piece costs over $100. The piece I need only costs about $20. Any suggestions if I can find this anywhere else?
Replace Shower valve - how much $? - RedFlagDeals.com Forums
forums.redflagdeals.com > Home & Garden
Nov 27, 2011 - Hi all Just bought a new shower column from Rona. ... the valving is in the pressure balance valve, thermostatic valve, diverter valve or volume ...
How To Troubleshoot A Thermostatic Shower Valve ...
? 9:45
https://www.youtube.com/watch?v=2pVuvG6q84A
Aug 10, 2011 - Uploaded by bathstore
This video shows you how to troubleshoot and rectify thermostatic control problems and the on/off control for a ...
Shower Systems & Valves - Home Depot
Jan 01, 2016 | Home
I have a Richmond RCN 0595A12328, MODEL 5V40-7 40 gallon water heater. Can you tell me if there is some kind of an assy. I can use on it so when a toilet if flushed someone in the shower does not get...
The water heater has nothing to do with it. You need a shower control valve that won't let the water pressure change when the toilet is flushed. Moen makes just such a valve called a pressure balancing valve. Moen L82683 Positemp Tub/Shower Valve. http://www.moen.com
Jan 07, 2015 | Water Water Heaters
TR 019 STEAM SHOWER leaking water from every jet, body jet , foot massage, shower head, top shower head when in off position
Tr019 is a type of control panel that operates the electrical features in a steam shower cabin, usually found in Chinese products. The issue you have is with the valve, in particular the on/off valve. These can be replaced individually or as a complete new valve . This company in uk sell them http:// www.steamshowerparts.co.uk
Aug 12, 2012 | Home
No hot water in shower but have hot water in sink
Is your shower valve a single handle. If so I would reccomend you change cartridge. To do this shut off water to valve or house. Remove center cover on valve handle,most of these are just friction fit so gently pry off with knife point or small screwdriver. Remove handle by pulling straight out,then remove chrome cover that fits around outside of valve. Ther is a small copper retaing clip that holds valve in place. It should have a small hole in tab that is on top of valve. Grasp this with pliers and pull up to remove. Then remove cartridge by pulling on cartridge stem. If it's doesn't come out you can get a moen cartridge puller at hardware store. Remove old cartridge,install new one and reinstall retaing clip. Reinstall chrome cover and handle.Turn water back on and try shower valve to see that cold is on the right side. If it's not remove handle and turn center stem 180 degrees.This will change cold side to right. Put handle back on with cover and you sould be done. Hope this helps. Thanks
Nov 19, 2010 | Moen Home
Model 680 ss dripping on the leading edge behind
model 680 and up. the warer valve is located in the upper part of the unit. follow the water. is very posible the water is coming from the top of the unit. TIP. remove the upper grill. and a white cover. behin the white cover is the water valve.
Mar 27, 2010 | Sub-Zero 680 / F
When installing a shower temperature control valve should the cartridge be removed before soldering to copper pipes
Yes you need to remove the valve befor you solder the copper pipes on it. If you do not remove the valve you will melt it to the valve body and then it will not be useable.
Mar 02, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I have an old home with a one hand Temptrol shower diverter which no longer regulates H2O temp properly. I purchased a Delta Carlisle 174939-SS-I and need to know how best to install this unit. I am a 60...
Start by turning the water off to the whole house. Open the tiled wall or if there is access behind the old valve open that wall instead. With a tubing cutter cut the hot and cold water lines as well as the shower riser. Remove any clips that are securing the valve to the wooden studs. Mount the new valve in the same area as the old. Make sure that the valve is not upside down arrows on the brass body will indicate flow direction for the tub spout. Connect the water supply lines to the new valve by means of soldering or mechanical joint. Connect the existing shower riser by means of soldering or mecnaical joint. Turn the water on and test for leaks.
Feb 09, 2010 | Delta & Single Handle Shower Faucet
Water came out both shower head and tub spout (even w/o spout)
The shower valve is clearly mark "UP" when you look at it from the front.
Nov 17, 2009 | Plumbing
We have two 16 year old shower faucets (house was built in 1993 by Del Webb). Can't tell what model they are. We are guessing they are Moen Legend 3175 (one handle). Problem seems to be pressure balancing...
This is a common problem with this type of shower mixer valve. They are not very good at regulating with pressure change. Your options are somewhat limited to not flushing the toilet or using any other taps when in use, repalce the mixer valve for a modern ceramic unit or installing a 2 vane hot & cold shower pump.
Nov 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Not able to pull up the shower valve
The valve is in upside down. Sounds like the shower head runs all the time and thats what fills the tub? The valve needs to be flipped OR the diverter in the valve needs to be switched to the other side of the valve. If this is a one handled valve it is installed upside down. UP is indicated on the valve.
The valve can be reused just turned over.
Dec 13, 2008 | Moen 2919 Chateau Two Handle Tub and...
Plumbing Logo
48 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
