Question about Toshiba Satellite M65-S9092 PC Notebook
Some of the keys on my keyboard don't work properly. If I type an e-mail or somthing, there will be a lot of letters missing. I can hit a key a few times before the letter appears on the screen. It's not all letters; it seems to be just a few, but I need to figure out which ones are the usual culprits. I tried to get this resolved with Toshiba's tech support before the warranty expired, but did not. The keyboard has always done this, since it was new. I thought it was me at first, but it's definitely the keyboard. Has anyone else experienced this? Thank you!
Some keys on keyboard not working on my acer aspire 5253-B2692
Im going to assume you didn't spill anything on the keyboard here...The best solution for you is to take the keyboard out and reseat the ribbon cable that holds it in place. Sometimes those cables get just a little bit loose, but a little can cause a lot of trouble as you can see. Let's see how much trouble...open "notepad" or some other writing program you have....type every single letter and number and see which ones you are missing. Let me know if there are any others that don't work....then we'll go through the process of taking the keyboard out and reseating it.
Jun 11, 2012 | Computers & Internet
I have a problem regarding my lg x110 notebook. some keys are not working properly like the letter g on the keyboard, when i hit the letter g it appears letter c on the monitor same as letter t and z and...
Examine your keyboard for any build-up of dust, dirt, liquids or other particles that could be causing the keys to type the wrong characters. Allow any loose dirt to fall out by inverting and shaking the keyboard lightly.
Confirm that your keyboard is set to the English language. Go to your control panel and click on the "Regional and Language Options" icon. If the setting appears to be in a foreign language, change it to English/U.S.
Check if your number lock key is on. If so, depress the key to disengage it.
Run a character key test by using the Microsoft Keyboard Diagnostics (MSKEY) program. While in the MSKEY program, hit several keys to make certain that they are the same keys that are identified in the MSKEY window. To start MSKEY in Windows Vista, select "All Programs>>Accessories>>Run" from the Start menu. Type "mskey" in the box and depress the "OK" button. Start MSKEY In Windows XP by clicking on "Run" from the Start menu. Type "mskey" in the Open box, then hit "OK." Depress either "PS/2" or "USB" to apply it to your type of keyboard hookup. MSKEY software is only available with Microsoft IntelliType version 1.1 or later.
Remember to clean your keyboard regularly to keep it free of dust and debris.
Don't disassemble the keyboard because it may affect the validity of your manufacturer warranty!
May 08, 2011 | LG Computers & Internet
I type j and it comes out 1. can't fix.
Try this.
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times. does it help?
I think your numlock might be stuck on and your keyboard "num lock" key isnt working
Jan 04, 2011 | Computers & Internet
On my Toshiba Satellite Pro M15-S405, i would push a certain letter on the keyboard and instead of typing that letter, it would make a window pop up. Is there some kind of setting that i can change to...
Your windows key (the one with the flag) appears to be blocked. Try pressing them both (or 1, if you only have 1) once, see if the keys work again. If not, try taking the keys off the keyboard (just put somthing under them and pull) and put them bac on. If that doesn't help either, you will have to have your keyboard replaced.
Dec 10, 2009 | Toshiba Satellite Pro M15-S405 Notebook
The keyboard on my Asus M51V series notebook does not register every keystrike. It frequently misses letters when the keys are hit. I have given up using it as an input device and now use an external...
I have the same laptop and it does exactly the same thing misses key hits and when i use mine and press a key it doesn't go fully in if you hit the key (very annoying when doing an essay) i find it good just to go over what you typed just to check it. Or get it fixed at a local computer shop, im not really that much help sorry.
Sep 28, 2009 | ASUS Computers & Internet
Can't type some letters
sounds like either there is something stuck under keys ie (kids toys, food scraps, stuff) or keyboard is bad
Jul 20, 2009 | Logitech 9675020403 Keyboard
A key (which one?) changes the letters all keys type
You're hitting SHIFT and CTRL -- which changes the keyboard input method, i.e., for French keyboard, or for DVORAK keyboard, or for Scandinavian keyboard.
Access CONTROL PANEL, and use REGIONAL settings to "uninstall" all keyboard-layouts that you _never_ use.
Jul 01, 2009 | Microsoft Natural Ergonomic 4000
Letter and number keys not working.
go to my computer>computer hardware>keyboard
click driver, then check if your device is working properly, if it is, click update driver.
Apr 20, 2009 | Microsoft Wireless Desktop 3000 Keyboard
Toshiba Satellite M65-S9092 PC Notebook Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
