Question about Sony Playstation 3 (PS3) Console
How to fix my nat type to open
I have a comtrend AR-5381u router/modem in one how do i get my ps3 to open Nat it is nat type 2 right now
babygenius55
  • 96 Answers
SOURCE: ps3 network issue
First, wire your ps3 directly to the modem, cycle (reset) everything then try the normal connection procedures. You should only have the console, and the modem in the equation for testing purposes, this will let you narrow down the problem. You must turn everything off so that all of the information on both ends will auto refresh.
Posted on Dec 16, 2008
harshit_theg
  • 124 Answers
SOURCE: i have netgear wirless router
In this regard, I would recommend you to forward certain port no’s on
the Router.
Port numbers:TCP: 80, 443, 5223 and UDP: 3478, 3479.It is in this context, I would suggest you to please try with the
following troubleshooting steps:
A) Assign static IP and DNS address to the XBOX.
1. Assign IP address as: 192.168.1.50; Subnet mask as: 255.255.255.0
and Default Gateway as: 192.168.1.1
2. Assign Primary DNS Address as: 192.168.1.1 and Secondary DNS
Address as: 4.2.2.2
C) Open the ports on the Router using the following steps:
1. Click on Port Forwarding under Advanced.
2. Click on ‘Port Forwarding’ on the left hand column on the screen.
3. On the bottom of the screen, click on ‘Add Custom Service’.
4. Give a name to the service (for example, PS1).
5. Select Service Type as UDP and key in the starting port and ending
port as 88.
6. In the Server IP Address specify 192.168.1.50
7. Hit ‘Apply’.
10. Log Out of the Router Page.
Posted on Apr 07, 2010
Tom Marvolo
  • 708 Answers
SOURCE: nat problems
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
Posted on Aug 20, 2010
Tom Marvolo
  • 708 Answers
SOURCE: i got nat type 2 on my ps3 internet test,but wen i
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Posted on Sep 26, 2010
  • 387 Answers
SOURCE: ps3 is lagging, nat type is 2 and centurylink
Even though the modem could be working fine you still might have to do a factory reset on the modem. I know from personal experience that some isp providers **** for PS3 online gaming on of them is Verizon FIOS or that use to be there name. It may have gotten better by now since the company change.
Posted on Feb 10, 2011
No ip on comtrend ar-5381u, will not connect to internet
DO NOT INSERT A PAPER CLIP TO RESET THE MODEM! unless you know how to reprogram the router, this includes having complete knowledge of ALL the settings required by the ISP AND having your username and modem password (modem authentication passwords are not usually provided to the customer) Doing a "hard boot" will only return your modem to factory settings
Dec 21, 2012 | Comtrend CT-507 Router
How to open nat for ps3 modern warfare3
Hey alldayrobbie,
Check out this forum post that gives step directions and has video details on how to open a locked NAT for PS3.
Good Luck
Jul 29, 2012 | Comtrend 12 Used 5361t Modems
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Aug 18, 2011 | Computers & Internet
It says I have NAT type 3. How can I fix it to make it NAT type 2? Maybe even 1.
Go into you modem/router and set the PS3 as a DMZ host this will take care of the NAT Type problem.
Feb 20, 2011 | Video Game Consoles & Games
I cant play online becouse of this a NATtype3 what dose this mean
Nat 3 is the result of being hooked into a router without being properly setup for data transfer. essentially it is restrictive.
There are 3 ways to change your Nat type to type 2 or 1. (Nat type 2 meaning that it is properly setup without restrictions behind a router, and Nat 1 being a direct connection to the Internet).
1.) Hook the PS3mag-glass_10x10.gif directly into the modem will result in a Nat type 1, but of course that means disconnecting everything but the ps3 and that's an unnecessary hassle.
2.) Going into the router settings and Port Forwarding the PS3's necessary ports to the Ps3's ip address.
3.) Probably the simplest (on most routers) and most effective is to go into the router and set the PS3's ip address in the DMZ (DeMilitarized Zone), essentially the router doesnt have any say from what comes and goes to the Ps3, which is good so the connection isn't hampered.
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
How do i change my nat from type 3 to type 2 with the belkin n600 hd router for ps3
Step 15:Enable UPnP
Open Router setup
Regards
TOM
Jan 11, 2011 | Belkin Play N600 HD Wireless Dual Band...
I have a Motorola WR850G i am looking to open my nat type for my ps3 system i also have a DSL Verizon cable modem which i have open the nat type for that now I'm trying to figure out how to open my nat...
If your using a router, you have to ENABLE the UPnp within your router settings. Once enabled your NAT should be OPEN.
If you do not know how to get into your router, you will need to ask someone you trust to do this.
Jul 30, 2010 | Computers & Internet
How to get nat 1 netopia router 3347 ps3
  • you need to access the router access page of the router, look at the bottom for router access page or call router support
  • then go to WAN setup to enable/disable NAT
Aug 11, 2009 | Netopia (3347NWG-VGX) Wireless Router...
I want to change my NAT settings on my router
Step 1 : Check the IP Address of the PS3 And take a note of it
Step 2 : Open RSP By typing 192.168.2.1 on the Address bar of the internet explorer
Step 3 : On the left side Click Firewall
Step 4 : Leave the Password blank and click Submit
Step 5 : Disable it And Apply Changes
Step 6 : On the left side Under Firewall Click DMZ
Step 7 : Add the IP Address of thePS3 in DMZ
Step 8 : Click Apply Changes
Step 9 : Restart the Router
Step 10 : Test the Connection
Mar 06, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
PS3 NAT type problem using Zyxel P-660R-D1 series DSL Modem
thanks for help , the error was from user that have viruse on his pc , thanks again
Nov 11, 2008 | Zyxel P660HW-D1 Router
Sony Playstation 3 (PS3) Console Logo
254 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
