Question about Kenmore 55693 Side by Side Refrigerator
Will not dispense ice,new filter installed
Appears to have a partial filled tray of frozen ice.changed filter tuesday,still no ice
  • 399 Answers
SOURCE: ice maker stop making ice for kenmore 106.56352500
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Dec 06, 2008
buddymcl777
  • 67 Answers
SOURCE: ice maker doesn't turn out the ice/
Top 2 possiblities
1/ The motor that ejects the ice is shot.
or
2/ the heater element that melts the ice into pieces.
Here is where you can probably pinpoint problem.
Making Ice When everything is hooked up, the icemaker begins its cycle. The cycle is usually controlled by a simple electrical circuit and a series of switches. In the diagram below, you can see how the icemaker moves through its cycle.
  • At the beginning of the cycle, a timed switch in the circuit briefly sends current to a solenoid water valve. In most designs, the water valve is actually positioned behind the refrigerator, but it is connected to the central circuit via electrical wires. When the circuit sends current down these wires, the charge moves a solenoid (a type of electromagnet), which opens the valve.
  • The valve is only open for about seven seconds; it lets in just enough water to fill the ice mold. The ice mold is a plastic well, with several connected cavities. Typically, these cavities have a curved, half-circle shape. Each of the cavity walls has a small notch in it so each ice cube will be attached to the cube next to it.
  • Once the mold is filled, the machine waits for the water in the mold to freeze. The cooling unit in the refrigerator does the actual work of freezing the water, not the icemaker itself (see How Refrigerators Work for details). The icemaker has a built-in thermostat, which monitors the temperature level of the water in the molds. When the temperature dips to a particular level -- say, 9 degrees Fahrenheit (-13 degrees Celsius) -- the thermostat closes a switch in the electrical circuit (see How Home Thermostats Work for details on this operation).
  • Closing this switch lets electrical current flow through a heating coil underneath the icemaker. As the coil heats up, it warms the bottom of the ice mold, loosening the ice cubes from the mold surface.
-->The icemaker has a heating coil underneath the ice mold.
  • The electrical circuit then activates the icemaker's motor. The motor spins a gear, which rotates another gear attached to a long plastic shaft. The shaft has a series of ejector blades extending out from it. As the blades revolve, they scoop the ice cubes up and out of the mold, pushing them to the front of the icemaker. Since the cubes are connected to one another, they move as a single unit.
  • At the front of the icemaker, there are plastic notches in the housing that match up with the ejector blades. The blades pass through these notches, and the cubes are pushed out to a collection bin underneath the icemaker.
  • The revolving shaft has a notched plastic cam at its base. Just before the cubes are pushed out of the icemaker, the cam catches hold of the shut-off arm, lifting it up. After the cubes are ejected, the arm falls down again. When the arm reaches its lowest resting position, it throws a switch in the circuit, which activates the water valve to begin another cycle. If the arm can't reach its lowest position, because there are stacked-up ice cubes in the way, the cycle is interrupted. This keeps the icemaker from filling your entire freezer with ice; it will only make more cubes when there is room in the collection bin.
This system is effective for making ice at home, but it doesn't produce enough ice for commercial purposes, such as restaurants and self-service hotel ice machines. In the next section, we'll look at a larger, more powerful icemaker design.
Posted on Jun 07, 2009
  • 103 Answers
SOURCE: Water not dispensing to fill up ice maker
Hi: Make sure your freezer is at zero degrees F. It will take 24-72hrs for an ice maker to produce when the freezer is at 0 degrees. Only then will the water fill the trays. I hope this helps, Jeff
Posted on Jul 08, 2009
MNfisherman
  • 11896 Answers
SOURCE: The ice maker works, but does not dispense
The bar, hinges or sensor may be broke or shot..
  • 135 Answers
SOURCE: 2005 Kenmore Elite - No ICE
If there is ice in the tray but the harvest arm is not pushing them out; either the heater is not warming the cubes fore removal or the temp sensor is not telling the harvest arm to function. Usually this requires the ice maker to be replaced. Also the freezer must be at least 15 degrees or less.
Posted on Aug 27, 2009
My Maytag ice maker stopped working; ice on doors & draw; What do you think might be causing this?
As odd as this sounds, my Maytag MFX2570AEM stopped making ice. I could feel ice in the tray but it suddenly stopped ejecting or making more even when the bar was in the correct position.
I read many articles telling me the motor was dead, the gears for removing the ice from the tray needed to be replaced, etc. THEN, I read one person who responded that his issue was resolved with a HAIR DRYER. It turns out something about the unit had frozen due to water getting on it, etc.
Sure enough, after blowing a hair dryer into the ice maker for 5-7 minutes I replaced the ice maker drawer and in about a minute it ejected the ice and filled the trays with water again. It has been making ice ever since.
Jan 31, 2015 | Maytag Refrigerators
Ice maker Tray is twisted
Uninstall and re install the unit. See what happens. Is there ice frozen in it?
Oct 25, 2013 | LG LSC27925 26.5 Cu. Ft. Side-By-Side...
Ice maker maker not calling for water. changed mixer valve (new) still nothing water dispenser works. the icemaker runs it rotation ok still no water coming into tray
the fill line is frozen in the freezer .remove ice maker fill line is located behind maker use a hair drier to thaw.. could be ice maker too it controls the water valve.
Aug 24, 2010 | Kenmore 53642 / 53644 Side by Side...
GE GSL25IGRE BS slow water dispenser
Sounds like your water valve may need changing, and has filled up with sediment, slowing the water flow.
Mar 29, 2010 | GE Profile Arctica Stainless Steel Top...
Get water, not making ice
To check if water is making it ro the ice maker. At the lower back of fridge, look for where your water supply connects to the water valve. Unplug the wires from water valve that has the larger tube coming from it. You will need a cord that you can run jumpers wires from it to the two prongs on the valve. Connect one wire to each side of the valve. Plug the cord in for around 4 seconds. Now reach inside the freezer and feel inside the ice tray. If your getting water there will be water in the ice tray. Before doing this, did you fill the filter up with water before you installed it? If not you will need to take it back off, fill it with water and re-install it. This primes the filter. After you re-install it, hold the water leaver in that's in the door for 10 seconds. If no water comes out. Wait for a few min. and try it again. you should get water within two or three tries.
Please rate this solution if helpful
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Automatic ice maker won't make ice
Turn off water.
Disconnect the line after the filter.
Turn water back on. If there is no water flowing, replace the filter.
If there is water flowing, the feed valve is probably defective.
Aug 02, 2009 | Kenmore Refrigerators
Ice maker tray not filling with water.
Changed the filter, now it works fine. I'd still like to find a way to bypass the filter. My fridge is only 2 yrs. old, but I'm sure it will have plenty of life left after these filters become unavailable.
Jul 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker
did you find out how to fix it ? please let me know
Jul 06, 2008 | LG LRSC-26922 Side by Side Refrigerator
FROZEN FILL TUBE
the problem is most likely the water fill solenoid valve. you have two in the unit, one for the dispenser and one for the ice tray. then again, you may not getting power to it. I would take apart the valve first and see if the plunger in the top is rusted up and clean it up. first apply 115 volts to it to see if it will open. the valve coil could be bad too. could be a few things but it would be a easy job for your local appliance technician
Jan 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice maker not getting water
check your water valve you have 2 located at lower back of refrig.
Dec 11, 2007 | Whirlpool GD5SHAX Side by Side...
Kenmore 55693 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
