Question about Nostalgia Electrics Soft Pretzel Factory
Clip is broken on pretzel factory
Will this product still work if the clip is broken??
I have an old Simac Il Gelataio Super. I believe the clutch is broken. It will only churn until the product is very soft. Then the blade stps because the drag on the sides is too great. Is this...
It sounds like the main gear is cracked were the paddle shaft goes though it.the d shaped shaft is spinning when the ice cream gets firm. i repaired mine by making a sleeve out of copper pipe and slid it over the cracked part. works great.
Dec 11, 2010 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
I require a manual for my Deni 5000 ice cream maker
Click Here!! For your product manual!!
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
Apr 17, 2010 | Deni 5000 Scoop Factory 1.5 Quart Ice...
I have the DAK Gellatissimo machine with Broken Belt as well
The following Gates belt will work. Its called Poly power chain belt which is metric and just under 12 inches with 60 teeth. Just Google the number and you will find several suppliers online. Costs around $24 which is cheap to fix such a great machine.
Product # 5MGT-300-09
Oct 03, 2009 | Musso Stainless Steel Pola Ice Cream Maker
I need the instructions for the Deni ice cream maker
If you go to www.deni.com and click on Ice Cream/Yogurt Makers, then scroll down the page, below the features it will say "Click here for the product manual" If this helps please rate me and let me know..good luck
Jul 19, 2009 | Deni 5400 Scoop Factory 1.5 Quart Ice...
Cannot find manual
If you go to www.deni.com and click on Ice Cream/Yogurt Makers, then scoll down the page, below the features it will say "Click here for the product manual" If this helped please rate me and let me know..good luck
Jul 18, 2009 | Deni 5100 Scoop Factory 1.5 Quart Ice...
Simac Sorbetiere Gelataio 1600. with broken plastic part.
Hi Kendy,
my Simac 1600 just broke yesterday. So if you like I can send you this plastic piece. But my mashine has a plastic blade and so I don´t know exactly what you need. Can you send me a picture. olaf.drauschke@gmx.de
Jul 07, 2009 | Ice Cream Makers
No instuctions for my arctic twister which was given to me as is
This product wastes a lot of ice cream in its mechanisms. I would not reccomend its use to anyone who believes in "waste not..."
Here are the instructions for any wasteroos who would still use this product:
Série IC200 Series
Arctic Twister™
Ice Cream Mixer
? U.S.A./Canada 1-800-231-9786
Mexico 01-800-847-2309
www.blackanddecker.com
To Assemble the Ice Cream Mixer:
1. Insert the Twister firmly into the opening on the
Base (A).
2. Slide the Chute/Dispenser over the Twister along the runner
on the Base (B); it will click into place.
Note: Unit will not operate if Chute/Dispenser does not click
into place.
3. Hold the Lid with Ratchet Clip in one hand with the Handle
facing front. With one finger, push the Ratchet Clip on the Lid
forward. In other hand, hold the Plunger with smooth side
facing front, and from underside of Lid, insert Plunger into
Clip opening (C), pushing Plunger up until the Ratchet Clip
rests on top of the Plunger base.
4. Set aside the Lid with Plunger in place. Now you're ready to
start mixing up some fun and delicious ice cream treats!
To Use the Ice Cream Mixer:
Assemble all ingredients before you begin to make your first
batch of twisty treats: Set out an ice cream scoop, the mix-ins
you plan to use, ice cream cones, cups or dessert dishes,
then bring out the ice cream.
For best results, use hardened ice cream, frozen yogurt,
sorbet or sherbet directly from the freezer.
You may want to rinse off the Lid, Plunger, Chute/Dispenser
and Twister before beginning new ice cream flavors or
mix-ins.
Always wash Lid, Plunger, Chute/Dispenser and Twister
between batches, if you have been using ice cream or mix-ins
containing peanuts, to prevent accidental peanut
consumption by those who may be allergic to them.
1. Plug the Cord into a standard 120V wall outlet.
2. Position a flat-bottom cone, dessert dish or cup under the
spout of the Chute/Dispenser.
3. Place 1 scoop of store-bought ice cream into the
Chute/Dispenser. Sprinkle in 1-2 tablespoons of the mix-ins
(see "About Mix-Ins"); add another scoop of ice cream, and
continue layering as above, ending with ice cream, until
Chute is filled.
4. Fit the Lid with Ratchet Clip and Plunger in place (see
assembly instructions #3 above), onto Chute opening,
pressing down slightly and turning the Lid to the right to fit
into position, then to the left to lock it into place on the Chute.
5. Gently pump the Handle up and down a few times to "prime"
the Chute.
6. Press the On/Off Switch to "on" position, then slowly pump
the handle to move ingredients down the Chute. As you
pump the handle, the ingredients will automatically be moved
into the Twister, then out the spout of the Dispenser.
7. When the Chute is empty, turn On/Off Switch to "off" position.
Push the Ratchet Clip forward and pull up the Plunger, then
use the Handle to move the Lid to the right. Lift the lid with
the Plunger in place out of the Chute.
8. Repeat steps 2-6 to make as many batches as desired.
Jul 06, 2009 | Black & Decker IC200 Arctic Twister 2.11...
Ice cream maker "agitator" broke
I searched in vain to find a standalone part for the Rival 8401-M, but here are some leads:
You can call Rival and see if they still have the part in stock, although it is doubtful since they don't even have support for the machine on their website anymore.
I found several never-opened and used Rival 8401-M's in working condition on eBay and other places on the web, ranging in price from $16.00 - $35.00. For electronic products that are more than 4 years old, I reccomend buying used, because a unit that is NIB (New-In-Box) may be dead as a doornail (The analogy I use is this: if you have a Ferrari, no matter how well-built, and you let it sit unused for 7 years - when you go to start up that Ferrari after 7 years, it's not going to work because the parts have degraded, etc over that time period). Here is alink to an auction for a working, used Rival 8401-M
If your blade is broken, I did not find replacement blades anywhere on the web. If it is, in fact, the agitator that is broken, I have two leads:
Here is a web site that will show you what an agitator looks like (it is the tiny part that they are pointing to in red):
http://www.twinsupply.com/proddetail.asp?prod=176-1055&partner=herb
Ace Hardware, at one point, stocked the Rival 8401-M - if you take it in to them, you can see if they have an agitator that would work (if it is, in fact, the agitator, and not the blade that is broken).
My final reccomendation is tongue-in-cheek: Buy a new Cuisinart ice-cream maker instead - a simple one like the ICE-20 can be had for $20-$40 brand new.
-Tha Mp3 Doctor
Mar 17, 2009 | Rival 8401-M 4 Quart Ice Cream Maker
Polar ice maker model PIM15W
Try Greenwayhp.com look under replacement parts page 3.....The gim15 tray is the same........
Feb 02, 2009 | Polar PIM15W Ice Cream Maker
Dak gelatisimo machine broken gears
I just helped a problem similar. It is possible to get a repair man and fix it. Get a hold of a repairman at www.repairman.org. I do not know the number but i'm shore it is on that website.
Nov 25, 2007 | Musso Stainless Steel Pola Ice Cream Maker
Nostalgia Electrics Soft Pretzel Factory Logo
Top Nostalgia Electrics Ice Cream Makers Experts
Ruth summersides
Andrew Taylor
Andrew Taylor
Are you a Nostalgia Electrics Ice Cream Maker Expert? Answer questions, earn points and help others
