Question about Olympus Camedia E-10 Digital Camera
Olympus E10 pins bent on compact flash slot
Thanks
Babsone
So what you are saying is that even if I have a few broken pins in the compact flash slot I can switch to Smart Media and the camera would work fine since the two operate independantly. Is that correct?
    President:
  • 919 Answers
That is correct. The camera should default and detect that a smartmedia card is now inserted to the camera and write the images to that card. As I stated earlier, the cards are independent of each other.
Posted on Mar 11, 2009
THE CAMERA BRINGING A NOTICE ON A SCREEN ERROR CF.WHAT IS POSSIBLE THE PROBLEM.
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
I've got an Canon EOS digital rebel. says "no CF card" when there is a card in the slot. card works (tried it on another camera). thoughts?
The camera isn't seeing the card inserted.
Have you tried another compact flash card in the slot to see if your camera is definitely at fault?
If so get a maglite and examine the slot the card plugs into and check none of the pins are bent. If there is a bent pin you may be able to straighten it with a pair of tweezers, though you may need to dissasemble the camera to do this. If the pins are all ok then you may have a board fault and while this is fixable it requires patience, a steady hand, knowhow, and test equipment. It would be easier to search for a scrap camera of the same model on ebay with a working board (search for one with a broken screen or lens) and simply swap it out.
Of course before you do any of these things check if your manufacturers warranty is still valid.
Dec 24, 2007 | Canon Digital Rebel / EOS-300D Digital...
My ds slot does not show up on my choose games even though i put the games in it says 'no ds card inserted" please help me i have my ds but only the gba slot works
There is probably one or more bent pins inside the top slot (SLOT 1). Remove the battery by removing the battery cover on the bottom (held ny a screw). Shine a small torch into SLOT 1 and look inside to see if any of the pins are bent differently to the rest of the pins. If any pins are bent they can be bent back to their correct positions by using a suitable small tool such as a precision screwdriver. If a pin is actually broken then the complete slot will need to be replaced.
If it is not a bent or broken pin, there may be some other type of blockage inside SLOT 1.
If there is nothing wrong with the pins and there is no blockage inside the slot, then there may be a dry joint where the slot is soldered to the PCB inside the DS. This kind of fault will require the DS to be opened with a special tri-wing screwdriver and the use of a multimeter to check all the connections. If you have soldering experience (and tools) then you can try re-soldering the connections.
Be advised that opening the DS is much easier than putting it back together again!
Feb 14, 2011 | Nintendo DS Lite Console
Bent pin in card slot , i have bent one of the pins that fit the compact flash card is there any one out there with spares to repair, ta steve
This is not a consumer repairable problem. Take it to a professional. If it's just a bent pin (not broken), the repair shouldn't be too expensive.
Oct 09, 2009 | Cameras
I have a couple broken pins in the compact flash connector internal to the camera. Can I order a replacement socket and attempt repair myself?
It can be done, but it's not easy and requires patience and a good invetory of parts and screws. Replacement card reader can be salvaged from a broken ebay camera (A75 and A85 readers are interchangeable). Here's a disassembly of a very similar A70:
http://blog.thustra.com/2007/03/canon-a70-ir-modification.html
Now are the pins actually broken or just bent. If just bent, you can actually and easily unbend them, but it requires patience:
http://camerarepair.blogspot.com/2009/06/fixing-compact-flash-memory-card-error.html
Jun 24, 2009 | Canon PowerShot A75 Digital Camera
Olympus e520 will not turn on
try to rest your camera and see if that works
Apr 20, 2009 | Olympus E-520 Digital Camera with 14-42mm...
The compact flash slot in my Olympus E10 has two bent pins
You can also use the smart media card slot. The two cards function independently of each other.
Based on what you report the camera would need to be serviced. Regretfully all parts, accessories and repair service have been discontinued due to the age of the camera.
You may refer to the yellow pages for local camera repair centers who maybe able to offer parts and service on the camera.
As a loyal Olympus customer, our Customer Service Department is also available to discuss other options available to you.
They can be reached Monday through Friday, 8:30 AM until 7:00PM East Coast time, at: 1(800)622-6372 option 2 and then option 3.
Mar 11, 2009 | Olympus Camedia E-10 Digital Camera
Olympus E500 card error
check the pins in the cf slot.. should be two even rows and straight... probably needs repair
Dec 13, 2008 | Olympus EVOLT E-500 Digital Camera
D70 digital camera
could be bent pin in the memory card slot
Jan 03, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Olympus Camedia E-10 Digital Camera Logo
187 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
