Samsung SP56K3HXX/XSA keeps switching off and os
TV turns on, picture comes on, about 40 seconds later it just switches itself off, then back on. I have secured the blue thermal switch to the closed position, but television still turns itself off and on.
techman
  • 3130 Answers
SOURCE: toshiba 42wt29b. screen keeps turning blue
MMMM Hard call here. The fact that it does try to come on blue maybe an indication that the power supply regulator circuit is good. It could also be a shorted blue tube and when it comes on its overloading the screen drive and the set goes into overload protection shutdown. The real way to see Would be to pull off the blue crt socket as well as the Hi Voltage lead on the crt and see if the set comes on without blue. If it does Your gonna need a pict tube. If it dosent then troubleshooting along the switched power supplys would be neccassary.. BUT I advise you THAT IF YOU HAVE NO EXPERIENCE TROUBLESHOOTING TV SETS PLEASE SEEK A PRO TO ASSIST YOU AS THERES VERY HIGH VOLTAGE INSIDE THESE SETS EVEN IF THEY ARE UNPLUGGED. GOOD LUCK
Posted on Jun 29, 2006
SOURCE: TV keeps turning itself on and off, onto standby
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Posted on Apr 22, 2008
SOURCE: LG Rear Projection Television Model RT-56NZ23RB - Fault
For my LG TV - LG RT-56NZ23RB, I replaced two STK 392-120 chips and it has fixed convergence problem now.
Posted on Jun 09, 2008
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Posted on Dec 05, 2008
SOURCE: Samsung DLP 62 inch turns off by itself after being switched on
I had the same issue but instead of shorting out the sensor, I removed the bulb assembly, cleaned the interior of the assembly and TV the best that I could with a vaccum and small paint brush. Once cleaned, I reinstalled the bulb assembly and the TV has worked for the last eight months with no problem.
Posted on Jun 27, 2009
Freezes turns white then turns off then back on
IF YOUR IMAGE IS ALL WHITE YOUR LOGIC BOARD IS DEFECT BUT IM SAD TO SAY DO NOT REPLACE THE LOGIC IT WILL ONLY TEMPORARLY SOLVE THE PROBLEM THE PANEL IS OVERLOADING THE LOGIC BOARD PANEL IS BAD
Apr 24, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
CONTROL BUTTON ON TV KEEPS CLICKING AND TV WONT COME ON.
the 1979 consumers act...you have 6 years..
get independant report then phone where you bought it from up..they should then repair or replace..if not £12.99 0n e-bay...do it yourself
Feb 23, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
No picture but still has sound. switch off and picture comes back
i haven`t got a solution, however mine has just started to do the same. can you let me know if u got the problem solved. thanks
Jan 31, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Samsung DLP turns on and off - cycle repeats
make sure put the lamp door back before trying to turn it on because they have switches on them that allow the tv to turn on. If that is ok you probably have a bad ballast.
Call a local tv repair shop to further diagnose the problem.
Dec 10, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Jun 16, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
May 10, 2008 | Samsung TXJ2754 27" TV
Tv switches itself off then back on again
It seems that the back light is malfunctioning or needs to be replaced the fact that it turns off after a few seconds indicates that is getting over heated. All LCDs, Plasmas and Projection TVs come with a shut off switch witch will turn of the monitor when a spike on the temperature is detected this is to protect the system from overheating. Now before you think about send it for repair; is it well ventilated? Does air circulates around it? Good luck!
Aug 27, 2007 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
