Question about Cryo Interactive Saga : Rage of the Vikings for Windows
How can i play Saga : Rage of the vikings online ? I tried even tcp/ip connection ( via hamachi, a lan connection simulatior) and it didn't worked! Thnx
Can't find a way to play this game online!
EEE PC, Win XP, TCP/IP and DCHP does not work, cannot renew IP address.
flush and renew your ip address via this commands:
*click the start menu*select "run"*type "cmd"*press enter*you will have a black screen*type ipconfig/release*then it will release your current ip address*type ipconfig/renew to renew the ip address then you're good to go.
Dec 27, 2011 | Computers & Internet
Desktop will not conntect to internet, but it says connected. My laptop works with the wireless network connection just fine, however, we cannot get the desktop to work. any suggestions? i have been on...
You didn't mention if your desktop is connected hardwired or wireless. Let's assume your desktop is connected hardwired via ethernet cable and your PC is saying that your are connected, then you need to check 2 things. First, TCP/IP settings, go to the network connections page of your PC and look for Local Area Connection. You need to right click on Local Area Connection and click on Properties. Then on the next page, look for Internet Protocol (TCP/IP) or Internet Protocol version 4 (IPv4) for Win Vista and Win 7 OS. You need to click on it to highlight it then click on Properties. On the next page, make sure that "Obtain an IP address automatically" and Obtain DNS Server address automatically" are both selected. Sorry if cannot give you a detailed walkthrough because you didn't mention the Operating System of your PC. Second, check Proxy Settings, open up Internet Explorer and click on Tools on the upper portion then click on Internet Options. On Internet Options page, click on the Connections Tab then click on the button for LAN settings. On the next page, make sure that the "Use Proxy Server for your LAN" is unchecked.
Sep 14, 2011 | Computers & Internet
How to connect my Linksys router with my wi tribe modem?? my laptop pick up the wireless signal and can connect,,it says "connected" but when you open a page it says either "invalid server...
The Linksys Wireless router is fine, but your latop is not configured for DHCP (Dynamic Host Configuration Protocol). The computer is connected to the router at layer 2, whereas HTTP (Hypertext Transfer Protocol), sits
atop the TCP/IP (Transmission Control Protocol/Internet Protocol) layer, and seems to be trying to
query the ISP's (Internet Service Provider) network for a nameserver (via DNS (Dynamic Name Service) protocol) that doesn't exist on the ISP's network. Configuring the laptop for DHCP and specifying no nameserver will fix this (the ISP's network will dynamically assign a DNS).
Its also possible (though a remote possibility) that your Linksys wifi router may be configured to disallow TCP/IP virtual circuits to/from your computer's IP address - but this is a really advanced
capability of your Linksys wifi router - few know this capability even exists.
Connecting multiple wifi devices to the Linksys router should be no problem, just configure them all to interact with the router using DHCP.
Jul 04, 2011 | Linksys WRH54G Wireless Router
Can i play the cricket 07 on the LAN
Steps:
1. Both you and your friend must download Hamachi. www.hamachi.cc
2. Once done downloading, run the set-up and get in a connection with each other.
3. One person open up Cricket and make an LAN game with yourself.
4. Other person open up the server window and attempt to add a new IP. The IP you enter is the one of your friend which you can find off of Hamachi. It should look like 5.xx.xx.xx.
5. When added, a new game should be in your favorites/whatever tab where IPs are added and then click to join the game.
I've done this... But not with Cricket '07. Counter-Strike 1.6 =D. It's uber fun especially with AMXX mod and a bunch of fun plugins. Hope this works for you.
Jan 09, 2010 | EA Sports Cricket 07 for Windows
"cannot connect to gamesession"
I don't think the game allows online play with 2 same cd keys...
I'm not allowed to advise you to get another cd key from the net, because that is illegal.
I guess you will need another copy of the game to play multiplayer.
Apr 13, 2009 | Black Isle Studios Icewind Dale: Heart of...
Can't connect to my router
Try this;
Just set it again via wired connection or LAN. Access it via Network Connections, and under Network connection look for for your LAN. Right click Local area connection,click properties, then highlight Internet Protocol(TCP/IP), click properties. Under General choose "Use the following IP Address ".
Input on IP address you should have router tutorial. Commonly its default is 192.168.1.1
Subnest Mask 255.255.255.0
Default gateway 192.168.1.2
Under it choose " Use the following DNS server address"
Input DNS address DNS of your ISP
Click ok
goto Inernet browser tab input 192.168.1.1 this will direct you to router configuration setting input its user and pass. If unchanged see tutorial of your router or at the bottom of the router. Then you can change setting of your router.
Hope it helps.
Apr 08, 2009 | Zyxel Prestige 660R Router (P660R)
Wi Fi fine, ISP fine, no internet via LAN connection though.
Make sure your firewall is not blocking your ability to go to websites. I saw this the other day, somehow the users firewall was set to block all internet traffic out of the computer.
Jan 21, 2008 | NetGear DG834G Router
Cryo Interactive Saga : Rage of the Vikings for Windows Logo
114 people viewed this question
Top Cryo Interactive Video Game Consoles & Games Experts
James Wishart
Are you a Cryo Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
