Question about Mitsubishi WD-73733 73" HDTV
How to replace optical light engine
How do i replace it myself
Large red spots growing in the middle of my 50v500 hitachi projection LCD screen
Hi, you have an Optical Engine fault. Complete assembly needs to be replaced. This page shows the most common Hitachi Optical Engine Faults.
Hitachi LCD TV Light Engine Optical Block Info
Nov 27, 2015 | Hitachi Televison & Video
My tv has a yellow, green or blue tint to it. We think it needs a new picture tube. Do you think that is the problem and if so is it easy to do myself
You have Light Engine Failure. Only fix is replace the Engine. Here is a Page that shows Hitachi LCD Projection TV Optical Engine Faults.
Check for these faults before spending money on a failed bulb. Here is page with all Hitachi TV Lamps and Bulbs.
Feb 11, 2011 | Hitachi UltraVision CineForm 55VG825 55"...
Have green cast to picture, what's up?
Hi:
Unfortunely the optics engine is faulty, one of the small LCD inside the light engine is coming apart. The only fix for this problem is to replace the optics engine, most call it Light Engine. You can get one fairely cheap from this site. COM">WWW.TRISTATEMODULE>COM . They sell optics engines new or rebuilded ones.. They will even repair yours..
Nov 10, 2010 | Hitachi 50V720 Television
Have a Sony TV modelKDS-R50XBR1 and after changing
Required optic block part number is A1148155A for KDS-R50XBR1, commonly calls light engine. Available HERE and HERE.
Click above links for price info.
Thanks.
Jul 30, 2010 | Sony KDS-R50XBR1 50" HDTV
Sony kdf-e42a10 screen discolor yellow streak on white background. lamp 6 month old.
Unfortunely your optics engine needs replacing, (Light Engine).. The only solution to repairing this problem is to replace the optics engine, One of the LCD Screens has gone bad.
Oct 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Optical engine for akai pt50dl14
Here's a link to order the original Akai light/optical engine for this model (PT50DL14) from a major parts distributor:
Akai Samsung PT50DL14 Replacement Part Light Engine / Optical Engine Block
Feb 17, 2009 | Televison & Video
Cleaning Optical Block
Sorry to be teh bearer of bad news, but the optical block (light engine) can not be dis-asembled outside of a cleanroom. You can remove the rear cover of the set and clean the mirrors and glass. That may help, but usually these typesd of symptoms are an indication that the light engine is starting to fail. The light engine can be replaced by you if you feel comfortable. The part is still available.
Keep us posted.
Dan
Aug 12, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Toshiba 52hmx95 dlp
Take off the back, and take out screws holding in the light engine. Look at new light engine, and the old one you will have to take off a couple of things that your new engine wont come with. It is very easy to change. Any questions please ask.
Feb 14, 2008 | Televison & Video
Light blue cloud
I have the same problem. The repair guy said it's the optical engine and you may as well replace the set as pay for the repair. First time I'm glad I bought the extended warranty. That's another story. Zonieal
Jan 17, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Mitsubishi WD-73733 73" HDTV Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
