Question about Maytag 24 in. DWD1500A Built-in Dishwasher
Cloudy glasses and dirty dishes
Maytag buildt in. I don't know how to check filters???
  • Anonymous May 21, 2009
    I have switched to Casacde at Maytag's recomendation and also I run the hot water at the kitchen sink for a few minutes before starting the dishwasher. Also I found out that my water pressure is low and that could be another concern. I am sure we have hard water, it is well water. Thanks for ythe help.
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Changing a normal filter in the dishwasher would not solve your problem. they are onyl used to catch food particles. your cloudy dish problem comes from hard water. after hard water gets heated up in your dishwasher it dries with a chalky white residue. there is a product out that filters the water before it enters your dishwasher reducing the hard minerals and leaving your dishes spot free guaranteed. you can get it www.dishwasherfilter.com. you will be glad you did. thanks
Posted on May 21, 2009
  • 10,865 Answers
There are no filters in the dishwasher. However, you may have filters under your sink or near your hot water tank for whole house filtering.
Posted on Mar 11, 2009
Glasses int he top rack of my kitchenaid dishwasher don;t get clean. they finish the run spotted and covered in what looks like baked on dirty dishwater. dishes in the lower rack look ok, but the...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 11, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishes no longer get clean dishes always got clean now glasses are cloudy and resr seem dirty always seemed ok before is there a filter or screen yhat needs to be cleaned
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
May 24, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Apr 04, 2010 | Maytag MDB9600A Jetclean II Built-in...
Food left on dishes, and glasses are very cloudy. We use rince aid, and have tried several detergents. Water temperature has been turned up twice.
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 01, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Cloudy dishes
Sep 22, 2009 | Maytag MDB9100A Dishwasher
Maytag performa dishwasher PDBL390AWB - dirty dishes
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Sep 13, 2009 | Bosch SHU9915UC Dishwasher
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Dwc7400aaw maytag -glass are cloudy,groundup food particles drying to dishes & glasses,when filling makes loud high pitched sound-generally not cleaning well.
Apr 06, 2009 | Maytag MDB9600A Jetclean II Built-in...
Cloudy glassware, stained flatware
Jan 19, 2009 | Maytag 24 in. DWB1000 Built-in Dishwasher
Dirty glasses
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 29, 2007 | Tricity Bendix 24 in. BDW53 Free-standing...
Maytag 24 in. DWD1500A Built-in Dishwasher Logo
398 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
