I have a IBM Lenovo t60 changed my Harddisk etc... I forgot my SV password how can I reset or find out what I set it too.
Bios password lenovo T60
there are 2 ways to attempt it. 1/ you need the diagram of your mother board as it involves changing a jumper setting on the board to clear the pass. 2/there is a small round battery inside ( could be under a cover under the laptop ) unplug that battery for a while to clear the cmos. hope this helps
May 01, 2015 | IBM Lenovo ThinkPad T60
My laptop IBM Lenovo Thinkpad T60 of type:2008-AD7, S/N L3-C0670 06/07, seems to be locked at the very start when the power is turned on, it shows a lock and enquires a password from the early start. it...
There is no default password on the T60.
If you are seeing a lock symbol then somebody has set the supervisor password. If you can't guess it (try "password", "admin", "pass", etc) then you need to find the person that set the supervisor password.
Once the supervisor password is set the T60 is very well protected and it can't be reset by removing the laptop battery or CMOS battery.
There is a way to read the password from the protection chip but this is very complicated and requires taking the laptop apart and building your own chip reader.
The instructions for doing this are are:
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Hope this helps,
Chris
Mar 05, 2011 | IBM Lenovo ThinkPad T60
Forgot cmos password after cearing cmos not able to boot from harddisk. Pls assist me how to remove cmos password of ibm T60 laptop
I just helped a friend out with this exact issue on the same notebook. Here is the instructions (step by step...well 4 steps) that worked perfectly. What you are doing is using a backdoor password set up by IBM/Lenovo.
Turn on your Thinkpad T60 computer.
  • Watch for the status message "To interrupt normal startup, press the blue ThinkVantage button" to appear on the screen. The only time you have the ability to access your BIOS is while this message is on your monitor. If this message disappears, you will have to restart your T60 and try again.
  • Press the "ThinkVantage" button on your T60. From the list of options that appears, select "Start setup utility." You will be prompted to enter your BIOS password. Type "merlin" and hit "Enter" to bypass the password prompt using your backdoor password and enter your main BIOS utility.
  • Select "Security." In this window, select "Set Password." Type the new password you want to use for your BIOS. Press "Enter" to finish resetting your T60 BIOS password.
  • Hope this helps...
    Jan 03, 2011 | IBM ThinkPad T60 Notebook
    I have i problem with my lenovo thinkpad t60, how do i remove the bios password in it?
    To reset the BIOS password read the information from this link.
    In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
    Nov 09, 2010 | IBM Lenovo ThinkPad T60
    I forget my Laptop Startup password of IBM T60.
    For IBM/Lenovo Password
    there is solution for all IBM/Lenovo laptop
    check this site... http://ja.axxs.net. u need to buy this device Key maker pro...
    OR
    there is one more way to break password for many laptop ..u need to make com port or printer port and there is software for it ...
    check this site http://www.lancos.com/prog.html
    Thanks
    Jan 17, 2010 | IBM Lenovo ThinkPad T60
    My ibm is lenovo t60 and i need bios password
    I would tell you to clear the CMOS. But, on those laptops, they soldered a chip on dedicated to saving password information, etc.. You'll have to replace the motherboard. If the pc's functioning fine, you can use the "ThinkVantage" button to restore the factory settings.
    Jan 10, 2010 | IBM Lenovo ThinkPad T60 ThinkPad T60P...
    I forgot my power-on password for my ibm thinkpad t60 and i can no longer use it. is there a way to remove the password so i could use the laptop?
    take it apart and remove the bios battery on the motherboard,remove main battery,set something heavy on power button to hold it down and wait,maybe a day ,or a couple hours ,it varies ,sometimes doesnt even work,but this one should reset,reassemble and power up ,good luck ,hope this helps.aloha from maui todd0708
    Oct 22, 2009 | IBM ThinkPad T60 Notebook
    HOW TO UNLOCK PASSWORD ON IBM THINKPAD LENOVO T60
    IBM PC laptops locked? Are you locked out of it? How to unlock Windows password?
    If the password is one of admin passwords, change to use another administrator to login IBM PC. Or if password reset disk is available, password reset wizard prompts you how to reset Windows password with it after you click link "Reset Password" on Windows login screen.
    When all the available ways are not useful for you, use effective Windows password recovery tool - Windows Password Genius, to remove Windows password or add new account.
    Oct 05, 2009 | IBM Computers & Internet
    Computers & Internet Logo
    54 people viewed this question
    David Payne
    David Payne
