Question about Coleman SportCat Portable Catalytic Heater
I'd like suggestions about how to disassemble the catalytic housing from the attached base plate. It appears that the connection is a press fit.
  • spresutti Mar 11, 2009
    My intent is to disassemble the unit for engineering reasons NOT to use the unit, repair the unit, etc.
  • Coleman Expert
  • 252 Answers
THESE DEVICES ARE NOT USER SERVICEABLE. They are dangerous enough without user intervention, that's why no reputable HVAC company will touch one. Contact Coleman or throw it away.
Posted on Mar 11, 2009
  • HANK MCNEIL Mar 11, 2009
    Sorry! have to be aware others will read my answer too!
How does the metal plate on crank attach to the crankshaft sensor?
They are called a reluctor wheel and some are heated and pressed on, others are bolted on or held in place with dowel pins and then some fit on keyways. They attach to the crankshaft and rotate were as the sensor is attached to the housing and is stationary.
Jun 25, 2015 | Cars & Trucks
Electrical motor will not work
(Probably too late to be useful, but seeing as I just had the same issue myself...)
There aren't any screws holding the housing on. There are a few indentations around the base where you can insert something to pry. Just work your way around gently, and the housing should come off.
Apr 15, 2014 | Jura Capresso 560 Electric Burr Grinder
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
Replacing base plate
The base plate for your saw is held in place by a screw that goes through a plate that fits into the raised part of the baseplate with the elongated holes. The nut that holds the screw in place is sandwiched in the base of the two housing halves. The raised part of the base plate and elongated holes are what allow you to tilt the base plate.
Jun 16, 2012 | Saws
I'm having a problem assembling my Samsung 2033 sw monitor. The directions are horrible and I don't want to snap the base.
I bought a Samsung 2033sw Monitor and I couldn't get the base attached to the monitor. When I returned it to Best Buy their "geek"
technicians discovered after opening another new monitor that
the spindle was attached to the monitor at the factory. But on
the monitor that I had problem with, the spindle was simply
put in the box along with the base plate. Best Buy solved the problem by disassembling the monitor itself and then installed the complete base assembly. You should return your monitor and asked the sales associate or manager to let you see another new monitor. The only thing you need to attached to the monitor is the round base plate.
Jun 17, 2009 | Computers & Internet
Switch a rheem thermostat to a hunter thermostat for heat pump
You can take the front cover off of your programmable thermostat. Unscrew approximately 2 screws that attach the base plate of the thermostat to the wall. Look in the back of the base plate after removing it from the wall to see how the 2 or 3 different colored wires (ex: red, green, black) are hooked up. Make note of this. Remove the wires from the back of the base plate and attach the wires to the same posts that they were connected to on the original base plate you removed. I believe the posts on the back of the base plates are color coded. (Ex: attach green wire to where it says GRN on back of base plate).
Make sure the thermostat that you are replacing and the new thermostat are similiar in shape, otherwise you will have make repairs to cover up a space that may appear around the new thermostat.
May 14, 2009 | Hunter Fan Company 5/1/1 Programmable...
1998 Chevy Blazer ignition parts in steering column
It is the passlock seneor. Is the wiring a 2 wire connector with an orange coating? If so then the connection is at the base of the column.You can tape the new wiring to a coat hanger put grease on it and fish it down through the column. You will have to perform a theft learn when you get it back together. Good Luck.
May 06, 2009 | 1998 Chevrolet S-10 Pickup
I cannot remove the plate to pute the other plate on
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/589307-02,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Mar 23, 2009 | Black & Decker MS550GB Mouse 5 Amp Detail...
Coleman SportCat Portable Catalytic Heater Logo
264 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
