Question about Kenmore Washing Machines
Kenmore 970-C29042-00 washer parts diagram
970-C29042-00
3 Suggested Answers
housejess
  • 317 Answers
SOURCE: Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Posted on Nov 04, 2009
heatman101
  • 43501 Answers
SOURCE: can i shorten
The blowing of the breaker has nothing to do with the hose.....
The problem you have is that you only have a 15 amp. circut to the washer... this is okay for many washers, but some will pull too much surge current especially when the motor starts.... this can trip a 15 amp. breaker...
You also could have a weak or slightly bad breaker there....
the first thing i would do is to change the breaker with a new one...do not change it to a higher amperage breaker if you do not have 12 ga wire....14 ga wire can only handle a 15 amp. breaker and 12 ga wire can handle a 20 amp. breaker....
If you only have 14 ga. wire to the washer and a new breaker does not fix the problem, then you may have to run a new 12 ga. wire to the washer...
heatman101
Posted on Dec 16, 2010
My kenmore 970-38712 washer makes a terriible banging noise on the final spin.
http://www.searspartsdirect.com/model-number/9703871220/0582/0153200.html?searchType=modelSearch&q=970-38712&searchTerm=970-38712
This link shows you your tub parts. There are 2 springs and 2 shock absorbers. Those may be bad broken or loose and one other thing to check is make sure the inside drum has not broken off of the spider assembly in the back. An easy way to check that is open the door and grab the front lip of the metal tub and try to move it up and down, you will notice a huge amount of movement if it is broken loose. The videos I posted apply to all front load washers, The first 2 are great on diagnosing and the last one shows whats left of a broken spider gear. Kenmore Washing Machine Model 970 3871220 9703871220 970 3871220 Parts
If it is the spider support assembly then you will have to replace the entire inner tub and that is about $400 just in parts.
Jan 14, 2017 | Kenmore Washing Machines
Kenmore washing machine model 970 c44102 00
Refer the control panel diagram at this site.
SEARS CANADA Washer Control panel Parts Model 970 C40042 00
Explode the diagram part and use the magnify cursor to see the parts of the dispenser. You need to pull the drawer out by lifting up slightly and then releasing its front edge from under the latch bar. Put it back in same way by inserting at a slight angle and then pushing in and straight. If you want you can take the top cover out (with proper screw driver) and pull the whole dispenser out. But I think you should be able to simply pull the drawer out and lean it.
Aug 31, 2014 | Kenmore Washing Machines
Error code f28 on Kenmore HE2t model #11047561601
my washer modle 970-C41062-00 my iner bearing it boken i take a part but i try to find bearing kit parts number .I need parts number.kit
If Do you kno it. thank you.
Sep 16, 2013 | Kenmore HE2 Plus Front Load Washer
Do you have a parts manual for a Kenmore front loading washing macnine model number 970-C42062-00?
The model # you gave is not valid.
Look for the silver metal tag usually found on Kenmore washer on the frame when you open the door.
There will be the model # xxx.xxxxxxx
Once located you can go here and using the correct model# get parts and pricing info
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
Jan 05, 2011 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Can you stack a kenmore washer / dryer model # 970-c84102-00 and 970-c44102-00?
  • yes you can stack 970 c84 10200 mine is. I just wish i could repair it, first youe have to take the cover off and thats as far as i got
Oct 19, 2010 | Kenmore Dryers
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore model 970-c44072-00
Probably broken shocks. 50 dollar part but pita to replace
Nov 09, 2008 | Kenmore 43142 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
69 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
