Question about Garden
Homelite ut60526 will not rev up - Garden
4 Suggested Answers
SOURCE: manual for Homelite model#ut60526
Not sure exactly what you need out of the manual, but if you are looking for schematics/parts list here is a .pdf document online that has the tiller broken down. Hope it helps.
http://www.ereplacementparts.com/images/homelite/UT-60526.pdf
Posted on May 15, 2010
SOURCE: homelite ut60526 pull cord seems detached inside
my homelike ut60526 cultivator rope pulls and recoils but does not engage the engine, what could be the problem and what could be the solution ?
Posted on Jun 16, 2011
fixya167
  • 119 Answers
SOURCE: what is gas/oil mix for homelite model UT60526 gas cultivator?
16 to 1
Posted on Apr 11, 2012
Homelite 42cc model ut10580 high low jet set settings?how to ajust
try 1 1/2 turns from shut then adjust to get highest revs and richen it a bit till rpm slow. too rich is highest revs. and will burn piston if continued at too lean.
Nov 30, 2016 | Homelite Garden
I have a Homelite 2 cycle cultivator UT 6.0526 it worked yesterday but will not start today.
You might want to refer to the troubleshooting section in the Homelite UT60526 Manual. The troubleshooting guide starts at page 13.
Feb 07, 2013 | Garden
Homelite ut60526 pull cord seems detached inside
If that is the case, then disassembly will be required. That is the only way to fix it. If you choose to do so, here are the instructions:
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Post back if needed.
Apr 09, 2011 | Homelite Consumer Products Tiller...
I need an Operators instruction manual for a Homelite HBC26 SJ brushcutter/strimmer
hi i have a homelite hbc26 strimmer and it will only rev up if choke is almost fully on if choke is moved to run position it will only idle have cleaned carb and no better,daveywarren@live.co.uk
Aug 21, 2010 | Homelite Garden
Manual for Homelite model#ut60526
Apr 23, 2010 | Homelite Consumer Products Tiller...
Homelite leaf blover run with choke soon when chokeis off ,cant rev up and die
if he put fuel in it dump it out & put yours in it , if problem persist there are 2 screws on the carberator turn the 1 on the right or th bottom 1/4 turn to the left!
Jun 02, 2009 | Homelite 'Yard Broom' Leaf Blower
Problem oil doenst arrive at chain Homelite model CSP 4016 40cc
Remove your bar and free rev the engine, check that the oiler hole is pulsing and free from debris.
Feb 22, 2009 | Homelite Garden
Homelite CSP 3314 Chainsaw
starts no prob will not rev , just stalls when you try
Feb 11, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
