Question about RCA F35317 35" TV
Looks like a lightning bolt when I turn on the TV.
I have an RCA Model #F35317 Chassis #CTC203CA9. The power at my house flickered a few times during a storm 2 weeks ago. The following day I turned on the television and I had no picture but I had sound. I changed the input to the S-video input and the screen was still blank. I turned it off and unplugged it and then plugged it back in after a few minutes. When I turned on the television it looked like a lightning bolt shooting down the screen and crackling sound came from the back of the television. Any advice??? Is this something that I can look into myself?
  • 6,784 Answers
Unfortunately, this is what we call in the industry total meltdown due to merging circuitry. you will have to replace the entire circuit arrangement in this set. the audio ic's are probably the only components that are still operational. this repair will cost quite a bit to be honest. you may be better off purchasing a new set. sorry for the bad news there.
Posted on Mar 11, 2009
RCA TELEVISION MODEL F35317 SCREMATICS
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 08, 2014 | RCA Televison & Video
We took a lightning strike and my RCA 20f510td has no indication of power. Is there a fuse that needs to be replaced?
Hello
The faults occurs during lightning strike is not predictable. At present, the power supply inverter section of your RCA ahs damaged. A thorough chekup must be done to detect whether there is any other faults also occured or not during this time. OK.
Apr 10, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
Recently purchased a rca tv model F35317, parental code from previous owener locked need to bypass
If you forget your password, press and hold TV on the remote and the
MENU button on the television
simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls.
Make sure you aim the remote at the TVs sensor while you press the TV button, and hold the menu button in on the front of the television.
Hope this helps you out. Thanks
Jan 03, 2011 | RCA F35317 35" TV
The TV was on when I lost power to the house during a lightning storm. When the power came back on, the TV would attempt to turn on, the light would flash, but it would not stay on. Any ideas? Its a $50...
By what you are stating it could be that the power supply board could have been burned on your tv because of the black out, plus if your tv was still on when the power came back on the suddent bust of power could have coused the power supply board to burn out among other parts on your tv.
Jul 22, 2010 | RCA 20F424T 20" TV
Can get to the input channel on my RCA F35317
You have to use the TV's remote control. Press the TV button at the top first, then press input button.
There you go!
May 23, 2010 | RCA F35317 35" TV
My 52" PANASONIC PT-52LCX35 does not come on after a power surge went off due to lightning. I press the Power Button to turn TV on, but green light just blinks a few times then stop without any sign of...
Remove the Lamp and look for a white fog inside. It is bad if it looks that way.
If thats not it, Call a good TV Tech to troubleshoot the problem. Lightning can do about anything to electronics.
Jul 29, 2009 | Panasonic PT-52LCX66 Projection Television
Tv won't come on
Typical reset sequence is: unplug the set, press the power button a few times ( Yes, with the set unplugged ). Then, hold the power button down and at the same time ( maybe with your other hand ) plug the set in. If that doesn't do it, there may be a button marked reset on the back of the set. If there was a lightning strike nearby, your set is probably toast. The antenna or cable brings it into the house.
Dec 26, 2008 | RCA R52WH76 Television
TV won't turn on after cable outage
No your set would not be like the HD52W19 model ,your model number is on back of tv year,chassis & Model # being 10 yrs old ptk195 model------- older Rca ptk169 these sets are 16yrs old.My guess without hands on chassis Bad Flyback Transfomer.
Dec 02, 2008 | RCA D52W19 52" Rear Projection Television
RCA P52920BL
i'd like to help.that model# looks familiar.but that chassis num you gave looks more like a serial num all my rca prints go buy chassis # is there anothe num like ctc197 exet or ptk19 doc
Aug 25, 2007 | RCA P52921 52" Rear Projection Television
RCA F35317 35" TV Logo
124 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
