Question about Garden
Murray 17.5 HP oil change, how much oil? - Garden
5 Suggested Answers
bargainbin2
  • 123 Answers
SOURCE: my murray 17 hp 42 inch cut hydrostat mower will
Hydrostat transaxles are very picky like the trans in your car. It must have clean fluid and be full of fluid. I am not saying to fill that transaxle to the top but make sure it is to the top of the fill line. Also it needs to be changed every few years and keep it clean to help it stay cool. If it has a filter make sure to change it when you change the fluid in the transaxle. That fluid is nothing more than 20-50W motor oil.
Posted on Sep 01, 2009
  • 2418 Answers
SOURCE: murray 17 hp briggs and stratton will run on
You need to take the fuel system down, to see whats is going on. The fuel line from the tank to the carb is it clear? will gas pour out if disconnected? If yes now you will have to take the carb off and take it a part to clean it. That should fixit.
Posted on Oct 31, 2009
SOURCE: need to know the model number for a murray 17 hp
I think that would be a 16 hp with a 46" cut. If thats what you have then the model number would be something like this...402707.
I am looking for a belt diagram for that very same model.
Posted on May 23, 2010
  • 6468 Answers
SOURCE: murray 42 in 17 hp doesnt start
i would look at the safety switches that being the most common cause
Posted on Jun 17, 2012
Murray select hp
Mathieu. It sound like you have overfilled it with oil. Drain most of it out the leave it level. A lawnmower will run better with it not being overfilled. Clean the spark plug and heat it gently to completely remove traces of oil. John
Jul 02, 2013 | Garden
12.5 hp Briggs and Staton Murray 42 in cut will not move and smoked when put in gear
check the tension of the drive belt sounds like the belt is slipping also check it for oil if you have a oil leak and the oil got on the belt that will make it slip as well
Jul 06, 2012 | Murray Garden
Murray 42 in 17 hp doesnt start
Jun 16, 2012 | Garden
What type oil and what level should I put in my 6-7yr old Murrary riding garden tractor. Model=?, but 25 HP, 2cyl 52 inch deck.
You didn't specify what engine is on your Murray, but most of them were either Briggs & Stratton or Tecumseh. Both of these engine take SAE HD30 weight motor oil. Appoximately 48 ounces will fill these from a complete drain.
If your Murray has an imported engine (honda or kawasaki) then they would use 10W30 oil.
Aug 30, 2010 | Garden
I have a Murray 6.0 hp 20 inch push lawn mower. How much oil do I put in when changing oil.
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
May 20, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
I have no rpm's mower only runs slow. plugs foul with black carbon after 30 minutes. This is a murray 6.5 hp brigs any solutions
CARB NEEDS TO BE REBUILT. FLOAT IS STUCK.. AND CHANGE OIL AFTER REPAIR OIL WILL HAVE GAS IN IT AND IT WILL JUNK THE MOTOR IN NO TIME ... VOTE !
May 20, 2010 | Briggs & Stratton Garden
My murray 17 hp 42 inch cut hydrostat mower will barely go uphill
Aug 31, 2009 | Garden
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
