Question about Toshiba Qosmio X870-BT3G23 Customizable : Gaming Laptop - Laptop Notebook
I have a Toshiba Qosmio X870-BT3G23 and it will not turn on when i plug it in the charger light is red instead of normally yellow
  • Toshiba Master
  • 7,627 Answers
Consider a new battery. How old is it? A battery has a Cycle Life, when it's reached it's time to replace it. If so, always replace with a genuine replacement, some aftermarket batteries don't work well at best, and COULD be a Fire hazard at worst. You could try a different Cord/Charger with the EXACT same power specs as the original.
Posted on Apr 20, 2013
  • 1 more comment
  • Michael Pam Apr 20, 2013
    I have tried draining the laptop and trying different chargers and batteries but that has not helped but my sister has dropped it from about a 1 1/2 feet from a chair.
  • max carson
    max carson Apr 20, 2013
    Rarely does anything good come from dropping a laptop from ANY distance. It may require a ride to the Computer Shop to visit a Qualified Computer Tech. Was it plugged in when it was dropped? Has the AC jack been damaged due to pulling on the cord while plugged in? The shock of the drop may have damaged components.Even the HDD may be damaged, remove and test.
  • max carson
    If you have ever opened a laptop you will see how many tiny connections their are, it only takes one to come loose and you have a paperweight instead of a laptop. If you are proficient with electronics and technically inclined you can, most likely, find the issue, if it's a loose connection.I had a Laptop that war sitting on the carpeted floor, on the edge, it fell over on the cord "brick". When I booted it it had a Black Screen, it would boot, but nothing on the screen. My point is, any drop, bump, jar, rough handling will put a Laptop out of action, they can be quite delicate.
podita
  • 324 Answers
SOURCE: My laptop Toshiba Qosmio F45- AV413 doesn't turn on
The memory is very poor, 3 things, Virtual memory, drive space, and finally check for virus
Posted on Mar 11, 2010
  • 29 Answers
SOURCE: toshiba satellite a40-s270 won't turn on
Either the power supply is not working or the battery has failed and will not hold a charge. If the laptop is 3 or more years old, the battery is the likely suspect.
Posted on Feb 12, 2010
  • 3 Answers
SOURCE: Toshiba Qosmio wont turn on
it is probobly the hardware
Posted on Nov 26, 2008
  • 162 Answers
SOURCE: Will not turn on (Toshiba Qosmio)
Remove the Battery and connect the Computer to direct Power outlet and also remove the RAM modules once. If the same issue persists, the service will be final option.
Posted on Jul 04, 2010
gpcomputer01
  • 137 Answers
SOURCE: Toshiba Qosmio X305-Q705 Laptop screen yellow
It is not a driver or video card problem. It is the monitor.
To be sure plug a full size desktop monitor into your laptops monitor jack. Every laptop has one. If the picture doesn't turn yellow that will confirm that your LCD is bad.
Posted on Aug 16, 2009
My nokia bh503 headset not charging
Leave it plugged in for 4 hours. Yello should turn red then green when fully charged
Oct 20, 2014 | Nokia Bh-503 Bh503 Bluetooth Stereo...
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Toshiba Qosmio f20 not booting up
Dear Sir,
Try this, remove the power plug and battery, wait for five minutes and plug the computer to power with out the battery and try to start it.
Dec 31, 2009 | Toshiba Qosmio G15 Notebook
Aug 16, 2009 | Toshiba QOSMIO F15-AV201 Notebook
It wont turn on, the plug in light is blinking yellow
battery is too low to operate the screen orange light usually means it is trying to charge
Jul 29, 2009 | Toshiba Qosmio G25-AV513 Notebook
Wont turn on
Replace your AC adapter.
Jun 29, 2009 | Toshiba Qosmio G25-AV513 Notebook
Toshiba Qosmio F15-AV201 will not turn on
Remove the battery. Plug in the power adapter. If you do not see a light turn on the front of the machine, you have one of two problems. A bad AC adapter, or the pin inside the computer has come loose. Both of the issues are very common. If you go to a local computer shop, im sure they would test that for free. Pin replacement usually runs around $100 in my neck of the woods. A "GOOD" AC adapter can cost as little as 25 bucks on ebay to 150 from Toshiba. Please contact me and let me know what you decided to do. Email ThinkingComputers@yahoo.com
Dec 29, 2008 | Samsung V20 XVC 2400 Notebook
Toshiba Qosmio X870-BT3G23 Customizable : Gaming Laptop - Laptop Notebook Logo
396 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
