Question about GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer
GE 5 cycle automatic heavy duty dryer overheating
The dryer no longer works on its automatic settings and it overheats to the point of scorching fabrics on its "normal" setting. We have to use it only on the timed "gentle" cycle now. Is it possibly something wrong with a thermostat?
  • Oxley St Apr 20, 2013
    there's been a mistake. This is a fairly normal sized electric dryer, not a gas extra-large capacity dryer
  • GE Master
  • 7,482 Answers
Hi Oxley St
BE SURE TO UNPLUG YOU MACHINE FROM THE WALL BEFORE YOU START ANY WORK.
Your problem sounds like it is a Thermostats/Thermistors malfunction.
This will cause an overheat condition that you describe.
You will have to locate the air tube that is going to the dryer drum. Some general area the heater is located.
Is also where you will find most of them.
They normally are round/oval shaped and have two wires connected to them. Take off the wires and with an Ohm meter set to "continuity" check your thermostat/thermistor.
If you have continuity across the terminal it is not faulty.
Be sure to check all of them.
If this is not your problem then it will be the Control board if you have one on your machine.
Please take time to rate me
Bud
Posted on Apr 20, 2013
hunter19_46m
  • 7482 Answers
SOURCE: too much heat, laundry is scorched
Sounds like you have a faulty thermostat
Posted on Sep 25, 2009
mrgreenz
  • 962 Answers
SOURCE: GE 5 cycle automatic heavy duty dryer
Turn off the electricity to the dryer.Try spraying the belt with automotive belt dressing inside that goes around the bucket.. If that does not work it is probably the bushing at the back of the dryer. you will have to remove the bucket to grease the bushing.if it is still good. judging by your details it seems good.But it could be dry.Needs lubrication.
Posted on Nov 08, 2008
  • 1122 Answers
SOURCE: GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Posted on Mar 21, 2009
RepairNinja
  • 98 Answers
SOURCE: Electric Dryer Shuts Off
During the auto-drying cycle, the moisture sensor could be the problem.
If it also shuts off prematurely during the timed cycle, the operating thermostat could be turning the heaters off before the machine reaches operating temperature. Another possibility is that the operating thermostat does not turn off the heaters at all. When the machine heats up, it gets too hot and the high limit thermostat turns the dryer off.
Posted on Apr 29, 2010
SOURCE: GE 5 Cycle Automatic Heavy Duty Extra Large
Dryers not getting hot at all.
Posted on Nov 30, 2010
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
I have the heavy duty 4 cycle Amana dryer. When I turn it on it is very loud and stops after about 20 minutes. It smells really hot so maybe it's overheating? But why?
sounds like motor bearings are failing. causes motor to overheat and cut out on motor protector. I'm afraid a new motor is in order.
Jun 15, 2010 | Amana DLE330RAW Electric Dryer
Whirlpool GGW9250PW Automatic Cycle not working
We are sorry to hear of the problem with your Whirlpool dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 04, 2017 | Whirlpool GGW9250PL Gas Dryer
How do I get to the heating elements in my dryer. It is a ge model 5 cycle automatic heavy duty extra large cap
there is a metal panel on the back that bolts on remove it then you will see a metal tube and it will have wires to it and a place to remove 2 or 4 screws to remove the area with the wires these wires attach to heating elements its easy to spot once back is off
Oct 26, 2009 | Dryers
Too much heat, laundry is scorched
Sep 22, 2009 | GE Dryers
Mar 19, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Aug 21, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer Logo
253 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
