Question about HP 48gx Calculator
Disassembly of HP 48gx
Put parts apart
2 Suggested Answers
  • 8016 Answers
SOURCE: HP 48GX problem
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.
Hope it helps.
Posted on Nov 07, 2009
Somone took this apart and now i have to put it together, i have rotor to put back on , how do i do it?
Need just a little more info to help you. Is it a brake rotor? Distributor rotor? What was taken apart?
Dec 26, 2012 | Transmission & Drivetrain for Nissan 200SX
Electric pole saw was put togeather wrong and can't take pole apart.
check for a small button in the connecting parts of the pole press it in and slip the parts
on reassembly make sure that that button lines up with a hole and clicks in
Sep 16, 2012 | Earthwise 10" Cordless Lithium Pole Saw
What company manufactured lid switch PS350434 FOR WHIRLPOOL WASHER
3949247 is the actual part number for that lid switch, and you won't find a blow out of the thing taken apart because its a molded part and not designed to come apart/
Jun 03, 2012 | Whirlpool Washing Machines
Laminator Jammed! I have a fellowes saturn 125 laminator. there is an item stuck inside that is not sticking out on either side, so cannot be pulled out, even when the reslease lever is pushed. can i...
once you take it apart it voids all warrants if you have any.
if you do not have any warrant parts than that the only way you are going to fix the issue.
here is what some one gave me some tips on disassembly of equipment. draw a picture of the device, mark the area of screw layouts, after separating the 2 parts draw diagram of each part, make foot notes on what you did, screw locations, parts removed, parts cleaned, PUT EVERYTHING IN A LINE IN THE ORDER OF REMOVAL PARTS, than work backwards and put everything back the way you took it apart, you should not have any extra parts and it should work fine. than if it every happens again you have your notes and information on hand to help you. you could try this site.
www.ask.com/
www.manualonline.com/
/mfg.name/make/model#/
www.mfg.name.wow/manuals/service/
www.manuals.wow.com/make/model#/service/repair/
www.disassembly.wow.com/mfg.name/make/model/instructions/
Mar 22, 2012 | Fellowes Saturn SL 125 12.5-Inch Laminator
I would like to take my homelite vac attack apart and clean it and change oil and change spark plug and clean the gas line and other parts and put it back together. So I need a list of how you clean the...
go to www.ereplacmentparts.com for a diagram. just pay attention when taking apart. its not hard. even lable parts if you need to. an air compressor will be useful in cleaning. and brake cleaner does good on oily parts.drys quick and leaves no residue.
Jul 09, 2011 | Homelite Leaf Vac Attack
I took it apart and can't put it back together
WOW!! What a hard question to answer. Without more datails, I don't know....How far did you take it apart? Did you undo the casing, and then lose the screws? Or did you take out more parts and can't remember where they went? If so, what do the parts look like? Why did you take it apart in the first place? Do you have a Service Manual to help you put it back? Send me as much info as you ca, and I'll try to help again.
Mar 25, 2011 | Bose Wave Radio
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
Sony vaio aw11m- took it apart now cant put back
You need a technician to reassemble it. There are no diagrams detailing every screw.
Good Luck!
Oct 30, 2009 | Sony VAIO VGN-AW110J/H 18.4-Inch Laptop...
Garmin Charger fell apart
Yes. Call Garmin up and tell them the pieces came off they will send you free pieces (covered under warranty) just tell them that you know how to put it back together and you can see images online of how it should loo kafter it's put back
Jul 14, 2009 | Garmin nuvi 205 GPS Receiver
HP 48gx Calculator Logo
69 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
