Question about Procter & Gamble 50975 66Ct Spr Mead Tide Pod
Put the pod in the dispenser
Instead of throwing the pod in the drum i placed it in the dispenser a few times how do i fix this the washer is working
How do I fix the problem with water spraying out the hose that's for the soap?
the warbler is just a cam action for the pump plungers so there will be no timing
I would think that you have the spring on the wrong side of the valve for the soap line and instead of shutting off that line when using the pressure wand it is by-passing pressure up that line to the dispenser.
It should be a one way valve to work under low pressure from the dispenser.
Sep 13, 2015 | Garden
Our Model WM2487H*M detergent box fills with water as the washer is working. We are using Tide pods in the drum.
The detergent dispenser is flushed with water during the wash cycle to remove residue. The flushing occurs automatically regardless of the type of detergent used, liquid, powder, or pods.
Jan 19, 2015 | LG Washing Machines
Water does not drain from dispenser into tub/drum fast enough
pull out the dispenser,check inside where the dispenser goes into,i found in two washers the white circle piece that's inside the cap to detergent,when water would go in the cap would block the fill tube,if you checked the dispenser and water flows through you have something blocking the fill tube,hopefully the washer and dryer are not stacked,you might have to take the top lid off to get at the fill tube or fill hose to clear it.good luck with your washer
Dec 25, 2014 | Washing Machines
The coffee does not dispense
When you insert a pod there is a sharp pin like piece of plastic that punctures the pod to allow water to flow into it. Right next to that puncture-pin there is one or more little tubes where the water is pushed out of. Take a paper clip and shove it up there and move it around to unclog it. There are most likelycoffee grinds stuck up there. You should put a paperclip up there to loosen the grinds/unclog it and then run it without a pod. You may need to do this a few times but you should notice coffee grinds passing through into the cup with the hot water even when you run it without a pod for a few times. You will notice the water coming out faster and stronger; now you can use it as your normally would.
If this solution is helpful please rate/vote for me.
Mar 01, 2011 | Keurig B60 Coffee Maker
The water runs up out of the soap dispenser and not in the drum
Try removing the dispenser drawer and with the door open pour some water into the dispenser housing and see if it runs into the drum, if it DOES run into the drum the you have a dispenser housing issue.if it DOES NOT run it to the drum their is a plastic pipe that runs from the dispenser housing to the rubber boot that lets the water into the basket,a few times I have seen these get cloged with a item of clothing preventing water from draining into the washer Good luck
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
While washing water is leaking out of the soap drawer out of our 1st Addition Washer/Dryer Please help
Probably a soap blockage in dispenser, or washer is overfilling, or the drum is turning too fast on wash.
Check the dispenser to make sure it is clear of powder.
The drum should turn fairly slowly, or other wise it will throw water up to the diepemser if it is turning too fast.
Jan 11, 2010 | Hotpoint Washing Machines
Put powder directly in the front load drum instead of the dispenser. What will happen?
not effectively. run the machine for a long cycle to clean any excess detergent out. the add normally through the dispenser
May 25, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Neptune stackable washer...
I went to Sears today and asked!  They said use high efficiency detergent (marked HE on the label) and put it directly in the washer with the clothes.  Mystery solved!
Jul 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water Building up Inside Front Load Washer when not in use
Okay, it is normal to hear water sloshing around inside the wash tub when the washer is not in use. A small amount of residual water remains in the wash tub under the wash basket (stainless steel tub), and resides in the drain line and drain pump. That's why it is important to keep the door slightly open when not in use to allow the drum to air out. The water will not evaporate, but it will help reduce the build up of odors, mold and mildew.
Now...if your washer is slowly accumulating water in the wash basket area over time, your water inlet valve is probably starting to fail. The leak can be very subtle and you may not notice it. The water only comes from one source - the fill valve via the dispenser. If you wish to replace it, the part is available at searspartsdirect.com. Just type in your model number and the part you need can be found under the "Dispenser" heading as item number 1. The replacement is very simple if you follow these steps:
1. UNPLUG the washer and turn off water supply.
2. Remove both fill hoses.
3. Remove the top panel of the washer by removing the screws that hold the panel in place in the rear of the washer.
4. Slide the top panel back, then it lifts off.
5. The water inlet valve is located in the left rear of the washer as facing from the front.
6. Remove the rubber hose leading from the valve and the electrical connections.
7. Remove the mounting screws holding the inlet valve in place.
8. Re-install new valve using these steps inthe reverse order given.
I hope you find this information helpful. If you have further questions, please post back and let me know.
Jun 06, 2008 | Kenmore Elite 45986 Front Load Washer
Procter & Gamble 50975 66Ct Spr Mead Tide Pod Logo
19 people viewed this question
Top Procter & Gamble Washing Machines Experts
Are you a Procter & Gamble Washing Machine Expert? Answer questions, earn points and help others
