Question about 2006 Dodge Ram - 1500, 4WD, Mega cab, 5.7L Hemi, with solid front axle - Complete Lift Kit
Losing antifreeze and can't find leak on 2006 dodge ram-1500 mega-cab
    New Friend:
  • 175 Answers
Check in side cab
Posted on Aug 27, 2013
How 2006 mega cab Windows switch work ?
Check switch on the console have power check fuses,
Oct 10, 2015 | 2006 Dodge Ram - 1500, 4WD, Mega cab, 5.7L...
2006 dodge ram 1500 low speed steering shudder
The 2006 Dodge Ram 1500 goes from 0-to-60-mph in just over 5 seconds with a top speed of 150 mph. Hope this helps!---------------------------------------------------------
Multi-Diag Access
Dec 04, 2012 | 2006 Dodge Ram 1500
I have a 2007 dodge 1500 mega cab 4x4, my break pedal goes down to far when i step on the breaks. I installed new rotors and pads it still goes down pass excellerator pedal
You need to bleed your brakes, check for air in the lines making sure that you keep the brake reservoir full. Check for leaks from your master cylinder also.
May 19, 2011 | 2007 Dodge Ram 2500 Mega Cab Laramie
The 5.7 hemi 2006 dodge ram 1500 losing coolant tekućinu.U hole oil emulsion is created and drops of antifreeze. At the bar there is no oil emulsion oil is clean.
II got a dodge 1500 4.7. The problem is, the oil cab is all green and im losing coolant all the time, there's smoke coming out smells bad, but no check engine at all. So I took it to a shop to check it they said, it's a water pump ,I changed the water pump but still losing coolant ............ so is it head gasket, manifold gasket, valve stem seal, piston rings, or something I don't know of??
Feb 04, 2011 | 2006 Dodge Ram 1500
2006 Dodge Ram Mega Cab 1500 4x4 needs AC Improvment Can I upgrade the AC Compressor to get better preformance
Compressor change should have no effect, presuming it is working correctly. Have a qualified shop diagnose the system, there are tons of items involved, pressures, tempratures, heating system, etc. Remember that you are heating OUTSIDE air unless you are using recirculation setting...Hard to lower outside air to cool during the short time that the air is in the evaporator coils.
Sep 09, 2010 | 2007 Dodge Ram 2500 Mega Cab Laramie
2006 Dodge Ram 1500 mega cab abs and brake lights stay on
check the sensors and connections may have loosened or knocked one loose if they look ok than have truck scanned most auto stores such as auto zone/advanced auto scan for free the trouble code will narrow the problem
Mar 24, 2010 | 2006 Dodge Ram 1500
Towing capacity
that depends on weather your using a draw tite hitch or a bumper pull
Apr 22, 2009 | 2006 Dodge Ram 1500
2006 Dodge Ram - 1500, 4WD, Mega cab, 5.7L Hemi, with solid front axle - Complete Lift Kit Logo
145 people viewed this question
Top Rancho Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Rancho Vehicle Part and Accessory Expert? Answer questions, earn points and help others
