Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AWW top loader washer
My machine stopped at 11 minutes. I lifted the top to see if the tub was spinning ccw or cw. It wasnt spinning at all. I replaced the clutch assy and it ran fine thru two washes. Now it is spinning slowly, the tub wabbles errtically (none of the tub hardware was touched) and there is now water leaking from the bottom of the tub.
  • 335 Answers
Double posting, are you still having the issue, did reseating the clutch clear the issue?
Posted on Mar 17, 2009
  • roupa Jan 05, 2011
    I had the exact same issue...replaced clutch, and now machine is leaking water !
I Have A Neptune Washer Model FAV6800AWW Have error code of LR Lock rotor? what is bad? control board ot motor or both?
Motor for the most part is bullet proof has a 10 yr warranty
I would start with front panel removal and see if you can rotate the Clutch Pulley CW the Wash/agitate direction and CCW the Spin direction. Make sure nothing is seized.
It could be an issue with the Control Board or the Motor Controller. I have working spares for all and that makes troubleshooting easier.
If you decide to troubleshoot further and try a Control Board swap (in the console) or a Motor Controller swap I would buy parts from a supplier that will allow you to return the part for refund with no questions asked.
Google this ""Neptune TL Washer FAV6800AWW"" a forum where I help owners of the FAV6800A and FAV9800A machines.
This is a sticky on a DIY forum at the 5th post down you can link to the FAV6800A/FAV9800A Service Manual. You can post in that forum in the Maytag washer forum for additional help. You will find a link to parts supplier.
I link you to a post on this forum where I was working with an owner who was troubleshooting issues and started throwing a LR error code. He ended up replacing both the Motor Control Board, my 1st suggestion and that did not resolve the issue. A Control Board swap in the Console resolved the issue. Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin ... I won't troubleshoot any further on this forum it's just difficult for me. Can't edit, search post and sometimes pics don't attach. There are better DIY forums out there for working on the FAV6800A/FAV9800A......just mu opinion.
Your machine more than likely is ready for an Tub Seal replacement.....Google this FAV6800A/FAV9800A Outer Tub bearing replacement Another forum I help owners with FAV6800A/FAV9800A machine issues........good luck.
Sep 06, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My neptune tl fav6800aww starts, then I believe at th first spin cycle starts then stops. Then it starts a loop of this process and never continues on. No error codes are displayed. When I open the lid...
Open the washer lid and see if you can rotate the wash basket CCW this is the Spin direction.
The wash basket should not rotate CW. If the the wash basket will not rotate CCW then I feel the One-Way Roller Clutch bearing is seized. If you place the washer cycle in a Spin Only cycle I believe you may see the same fail process with no error code.
If you want to DIY the fix Google this Neptune TL Washer FAV6800AWW. That will take you to a FAV6800A Sticky.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
I feel you will find that the Clutch has failed due to a leaky Tub Seal. A replacement Clutch Pulley will more than likley get you back in service. Once you have the Service Manual you can pull the front cover off drop the Clutch Pulley out and inspect.
I won't offer any more help on this site it is just to difficult to work issues. You can see by past ratings I know the machine and have helped owners. If you are not the DIY type then callin in a Service Repair will cost $65 to $90 range and more than likely they will not have a clue. Go thru the FAV6800A forum here and search the post. i.e. this is typical repair service result for support........ http://www.fixya.com/support/t8683813-6_year_old_maytag_neptune_tl_washer_just
Not hammering service people, most just don't have the hands on knowledge to diagnose machine issues. Once you know the fail point anyone that has very basic mechanical skill sets can repiar the machine. Go to the forum that has the Sticky and open up an issue in the Maytag washer part of that forum and I will help. I scan the forum a few times a day. If you are not into a DIY fix just disregard this post.
Apr 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
GETTING DC ERROR CODE WITH A GRINDING SOUND AND THEN IT STOPS COMPLETELY
The DC error code is 9 time out of 10 caused by a Clutch Pulley malfunction. The grinding may ne Outer Tub Bearings but need more info. Open the Washer Lid. Spin the wash basket CCW. Do you hear and grinding noise?
The noise may be coming from under neath the tumblers. Further troubleshooting is required.
Do you have basic DIY mech. skills and do you want to save your $1K machine?
If so Google Neptune TL Washer FAV6800AWW
Good luck.
Mar 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My washing machine makes a grinding noise when it is spinning. It drains alright and seems to work ok, but I`m afraid the grinding noise could lead to bigger problems.
Stone,
All owners are heading toward this issue. I feel your FAV6800A or FAV9800A is at the end of service lifew for the Tub Seal
If you open the washer lid and spin the Washer CCW and hear the noise (Outer Tub Bearing noise) then it's time to role up your sleeves.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800A top load machine.
Google this FAV6800A/FAV9800A Outer Tub bearing replacement to see what is involved in doing an Outer Tub Rebuild.
Good Luck
Mar 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Nuptune fav6800aww won't spin. I followed the directions to replace the clutch, but that didn't fix it. The tub will not rotate in either direction. I have taken the transmittion out and it...
Maybe the Outer Tub bearings are seized. With the Clutch Pulley removed the wash basket should rotate within the Outer Tub bearings with one finger in CCW and CW direction does it?
"" I followed the directions to replace the clutch, but that didn\'t fix it. "" Was it my post Clutch Fix post? If your FAV6800A used the Upper Bearing One-Way roller clutch bearing ring do you feel on reassembly the parts are seated correctly.
What are the first two digits of you s/n of your machine?
Was the Clutch Pulley One-Way Roller clutches bearing rusted up severely or only slightly? I'm trying to get a feel for a Tub Seal leak........Rich
Oct 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
FAV6800AWW is very loud in the spin cycle only, the basket does move freely and the belt is in good condition. the noise does not seem to be from the clutch,
Derek,
What are the first two digits of you serial number of you FAV6800A or FAV9800A? It will digits 10, 11, 12,thru 17.
In spin Cycle the Wash Basket rotates in the Outer Tub bearings in the CCW direction. I1f you spin the wash basket CCW by hand as fast as you can the Wash Basket should cost several revolutions to a gentle stop. Does it?
Do you hear and bearing noise/grinding sounds as the wash basket coast to a stop? If so I would drop the clutch out and inspect for traces of a Tub Seal leak.
My Clutch Fix will help you disassemble and let me know if can help. I have …….Rich
May 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag FAV6800AWW TL washer is throwing error code uC even when running empty cycle. It sounds like there may be a bearing going bad as it is more noisy than it should be when spinning. It stopped at 12...
Don,
I ask folks to give me some feedback when troubleshooting dC/uC errors with a feel for Wash Basket CCW/Spin direction drive system resistance.
It sounds like the Outer Tub Bearings are going which means you have a Tub Seal Leak that took them out. The Clutch One-Way Roller clutches are probably contaminated. I would bet a bit rusty and are sticking not locking up completely in Spin Cycle causing tumbler movement at the start of Spin Cycle. See my Clutch Fix post I go into a lot of detail for a fix and just what is causing the unbalance errors in Spin Cycle
You could drop the clutch out and see if you can clean up the bearings and relieve the dC/uC unbalance errors for a while longer.
Replacing the bearings is a bit more work see these post for what is involved. If your series is a 12 or above you may have to do as this forum member did.
http://www.fixya.com/support/t3973659-fav6800aw_sn_15_top_loader_r_nunit
Series 10 & 11 from what I have learned use the upper One-Way Roller Clutch bearing ring and not the integrated Lower Outer Tub bearing as in I believe the Series 12 and above do.
Series 10 Outer Tub Bearing work I and another forum member are working on. The links will give you some direction if you DIY. http://www.fixya.com/support/t4028403-just_replaced_new_clutch_fav9800aww
What are the first two digits of your Serial Number? Will be 10 through 17.
Post back if we can help I’m an owner like you not a repair person. I feel the cost to have the Outer Tub Bearing replaced will trigger you to make a replacement decision……Rich
Mar 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Spin cycle locks up
it is the clutch and be repalced fairly easily
Oct 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Tl washer
Mike, Sorry to hear that, is there any water around the clutch pulley?  With the front panel removed and you put the washer in a Spin Only cycle with no clothes in the wash basket.  View the Clutch pulley turning CCW and see if is turning true with no wobble? Mine spun off twice before I got it seated properly, and it was in wobble mode until I got it seated properly.   With the water leak issue maybe you can view with the front panel off and a partial fill the leak source. You can always do a quick tub pump out in service mode. As you know unplug the 120VAC to the machine before you poke around in there.  Do you still have the original clutch?  Did you remove the plastic cover and inspect the roller bearings, clutch spring and coupler? Good luck and let’s see what you find. Rich
Mar 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
320 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
