Question about Vehicle Parts & Accessories
VW electric fuel tank not opening - Vehicle Parts & Accessories
    New Friend:
  • 7 Answers
Yiu could use a straight screwdriver to open it
Posted on Apr 20, 2013
P0452 ,P0305 aurora 3.5
P0452 means fuel tank pressure sensor circuit low pressure. Possible symptoms:
- Fuel Tank Pressure Sensor harness is open or shorted
- Fuel Tank Pressure Sensor circuit poor electrical connection
- Faulty Fuel Tank Pressure Sensor
The code 0305 means cylinder 5 misfire detected. Possible symptoms:
- Faulty spark plug 5
- Clogged or faulty fuel injector 5
- Faulty ignition coil 5
- Fuel injector 5 harness is open or shorted
- Fuel injector 5 circuit poor electrical connection
- Ignition coil 5 harness is open or shorted
- Ignition coil 5 circuit poor electrical connection
- Insufficient cylinder 5 compression
- Incorrect fuel pressure
- Intake air leak
Read more: http://engine-codes.com/p0305_pontiac.html#ixzz2d8l8VHWe
Read more: http://engine-codes.com/p0452_pontiac.html#ixzz2d8kXRa8w
Aug 27, 2013 | 2001 Pontiac Grand Am SE
Gas tank flap stuck open
if the flap is intact you can try spraying some wd-40 on its hinge. If its missing you need a filler neck for your fuel tank.
Oct 27, 2017 | Volkswagen Cars & Trucks
Fuel pump problem. I removed the inline fuel pump and it is bad. I need to know if this '90 VW Cabriolet has a fuel pump in the tank as well and if it can be accessed and removed by taking out the...
you don't have to remove the back sit to get there, just pull it and it will fold it's in the seat behind the passenger seat. there you will see a black cover with 3 bolts, remove them, disconnect the hoses, then you will see a black cap turn it counter clockwise there the white part will come out with the inner fuel pump.It should have a transference fuel pump that it works with about 8 psi.
Jun 23, 2011 | Electric Eyeware Onan 1492592 Electric...
Remove fuel pump from 1999 jetta
It's on top of the fuel tank so fold the rear seat bottom out of the way,pull back the floor cover and remove the panel covering the top of the tank. The fuel delivery assembly is removed as a unit. First remove the electrical connectors and fuel lines. Cover the fuel lines with a cloth as pressure will let some fuel spurt out of the line. Remove the retaining ring. VW has a special tool for this but you can make something that will work. Lift the unit out of the tank. Some units ( 2.0 BBW ) have the retaining ring bolted and the nuts have to removed to get the unit loose.
Dec 28, 2010 | 1999 Volkswagen Jetta
Where is the feul pump on a 2002 VW Passat?
the fuel pump is electric and it is located inside the fuel tank.
Aug 24, 2010 | Volkswagen Passat Cars & Trucks
FUEL PUMP REPLACEMENT. NEED MANUAL OR GUIDE or DIAGRAM
Most fuel pumps are electric nowadays. Often, they are located within the fuel tank itself, though some models of cars may have 2 pumps.
Locate your fuel pump. If it is in the fuel tank there is usually a circular inspection cover held down with screws.
Disconnect your battery (but remember the radio code will have to be reinstalled..)
Undo the screws.
Make a note of the coloured wires and which connections they go to. Undo the wires.
Different cars have different fittings to attach the fuel pump. You will need a wrench or two to undo/disconnect the fuel line and pump retaing bolts.
Again, with an in-tank fuel pump, it is easily lifted out. It is not a big or difficult job. What you see in front of you will be self-explanatory.
Other locations for an electric fuel pump:
Close to the fuel tank
Underneath the car (just follow the fuel line from the engine..)
In the engine bay.
Years ago I owned a VW Golf Estate (think they're called station wagons in the States..). The fuel pump was in-tank beneath an inspection cover. It was very easy to change.
You will be able to do the job within an hour, irrespective where the pump is. Just remember to disconnect that battery first ...
Aug 16, 2010 | Volkswagen Beetle Cars & Trucks
Is theira manual way to open petrol cap on golf gti turbo mk4
look in boot space on the same side Rear fender where the fuel tank cap lid is located where the fuel tank cap is located exactly on the same side inside the boot you will find cable which unable you to operate or open the fuel tank cap lid mechanical from inside when you pull the cable it let's open the fuel tank cap from outside see for the instruction manual for more detail or just visit the nearest VW authorised service centre for hazel free driving do keep in writing for more queries
Feb 28, 2010 | 2001 Volkswagen Golf
Replace fuel tank seals VW T25 vanagon
Dropping the fuel tank is rather involved. Beyond this sort of Q&A format.
I suggest you get a Bently Workshop Manual and a seal kit from gowesty.com or similar.
Also plan on replacing fuel hoses and a new filter would be a good idea.
One word of caution. The plastic overflow tanks in each wheel well have nipples for the fuel lines that become quite fragile so BE CAREFUL! The tanks are not available new.
Feb 12, 2010 | 1986 Volkswagen Wagon Camper
Gas Tank will not open
OPEN THE TRUNK,ON THE RIGHT HAND SIDE IS A PLASTIC ROUND DISK,REMOVE IT,PUT YOUR HAND INSIDE GRAB THE CABLE AND TUG ON IT THIS WILL OPEN THE FUEL CAP.I HAD THE SAME PROBLEM.
Jan 01, 2009 | 2000 Volkswagen Beetle
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
